New speedo
Discussion in 'XJ Modifications' started by PainterD, Jan 21, 2008.
  1. PainterD
    I just got done fabricating the new speedometer mount for the bobber. I'm using an old Honda speedo and an aluminum mount with LED lindicator lights I fabricated. It should look alot better than the old gauges I took off.
    For some reason, Radio Shack doesn't carry a blue LED, so I'll just have to do with a red one for the highbeam indicator till I find one that matches the others.
    The speedometer seems to be mounted a little crooked (just temperarily mounted for the photo)
  2. Gamuru
    Gamuru Guest
    Granite Falls, WA
    That looks sharp! Very clean; very simple.
    Can I get you to pop over to my thread and lend me your expertise?
  3. PainterD
    Gamuru, I PM'd you with some suggestions. >PD<
  4. philbrewer
    philbrewer Member
    Livonia, MI
    PD, can you give some insight on the wiring setup?
  5. willierides
    willierides Member
    NY
    That looks nice!
  6. PainterD
    Philbrewer,
    My wiring setup is no more than;
    1st - cutting all those plastic connectors out and soldering the wires together.
    2nd - cut all the wires to the speedometer/tachometer and marking them to what they are used for.
    3rd - made the speedometer mount with LED lights in it for signals, high beam and nuetral.
    4th - connected the proper wires to the LEDs for the signals, highbeam, nuetral indicator and speedometer backlight.
    5th - turned on the key to check and see how everything worked...and it worked perfect.
    There appears to be about 12 wires that I don't use any more, so I just labled them (incase I need some of them in the future) , sealed the ends off with heat shrink tubing, and tucked them under the tank with zip-ties to hide them.
    If I do anything more to it, I may just re-do the entire wiring harness and elliminate the wires I don't use any more. PD
