brake upgrade
Discussion in 'XJ Modifications' started by mainexj550, Apr 23, 2006.
  1. mainexj550
    mainexj550 Member
    maine
    hey everyone,
    I have an 82 xj550 maxim in excellent condition. I want to improve the stopping performance. Im thinking something along the lines of a double disc set up from a xj750. This looks like I would have to replaced part of my fork too. Anyone have any experience on upgrading thier front brakes? Know of any write ups on the subject?
  2. Hired_Goon
    Hired_Goon Member
    Oz
  3. mainexj550
    mainexj550 Member
    maine
    thanks. Do you know if the 550 wheel will fit in the 650 fork? It looks like there are holes in the hub so discs can be mounted on both sides.
  4. Hired_Goon
    Hired_Goon Member
    Oz
    Not sure. My 550 didn't have the original wheel on it when I bought it.
    I found it easier to just put the 650 wheel on as it came with two discs already. As far as I know there was only two wheel designs on most early XJ's so swapping keeps it looking normal.
    Some 550's for the NZ/pacific market apprently came with a twin setup so it's highly possible that a disc may bolt straight on.
  5. Injuhneer
    Injuhneer Member
    SE Arizona
    jawknee90 likes this.
  6. p51bombay
    p51bombay New Member
    USA
    The other option is to search ebay Germany and UK for a set of european fork lowers (you really only need to swap the one without the caliper mount) and swap that along with a second caliper and disc as the euro version of the 550 had twin discs as did the Japan market XJ400 from which both were derived.
  7. Joel07
    Joel07 Member
    Durham, NC, USA
    Injuhneer, beautiful job on the R1 conversion!!! Love to see some more pics of your bike too! You don't happen to still have the plans for that caliper bracket laying around, do you? :lol:
  8. Joel07
    Joel07 Member
    Durham, NC, USA
    Think I found the rest of the pics, any details on how you did the rear disc conversion?? Very nice site BTW!!!
  9. Injuhneer
    Injuhneer Member
    SE Arizona
    The rear wheel is also from an XJ900. The disc is one of the old front rotors from the bike (650 Turbo). The caliper is the rear and master from an R1/R6 (same parts back in 2003).
    I created the lower half of the bracket then milled the R6 bracket to fit. Then TIG welded them together. Then turned a spacer for the right side.
    From there it was just plumbing and mounting the master. It works well. I only need about 1" (25mm) before the brake engages. Being a 1/2" (13mm) master it modulates nicely on such a small caliper.
  10. Injuhneer
    Injuhneer Member
    SE Arizona
    I made these jsut before I got the CNC gear installed in my 3 axis machine. I suspect they would be pretty easy to make now. They are fitted for an XJ650LJ to use R1 calipers. I'd need dimensions for other XJs.
    For some folks who just want more stopping power without any changes to their bike a good semi-metal or kevlar pad will improve braking. I think EBC makes them to fir a number of XJs.
  11. Robert
    Sweet setup! Beautiful handywork Mr. Injuhneer! Doing any work on the side?
  12. Injuhneer
    Injuhneer Member
    SE Arizona
    On occasion. :)
    Typically when the YICS waiting list isn't so long... :wink:
  13. XJ550H
    XJ550H Well-Known Member
    14 year old post Injuhneer was last seen:
    Apr 7, 2018
