HOW TO: Change your fork seals
Discussion in 'XJ DIY How-To Instructions' started by Gamuru, Mar 9, 2008.
  1. Gamuru
    Gamuru Guest
    Granite Falls, WA
    (Note: These intructions were developed while working on a 1981 XJ650H and should be adequate for all 650 models up to 1983. Other models will very in design.)
    You noticed it sometime back, but ignored it hoping it would go away. But, it hasn't. In your embarrassment, you quickly wipe off your fork tubes when meeting friends for fear that they might say something. Worse yet, it's gotten so bad that your front brake pads have become contaminated with fork oil and you've got oil spatters all over the front of your riding pants.
    Well, my friends, it's time to do something about it. Today, we're going to tear into those troublesome forks and replace those pesky seals. And then you can ride in confidence knowing that you've got a clean looking machine.
    Today we'll be working on my trusty steed:
    I ride an '81 XJ650H Maxim.
    ...and here's the problem:
    Before we get started, let's quickly review all the parts to a front shock:
    (Click this image for a larger version.)
    As I step through the directions, I'll refer back to this image by placing in brackets each part's corresponding number. For example, if I say to remove the cap bolt, I'll follow it with [15] so that you can look at this picture for clarification.
    Here are the steps...
    1. Place the bike on a level surface and on its center stand.
    2. Using a jack, raise and support the bike so the front tire is off the ground.
    Note: you will want to make sure the bike doesn't rock back and forth on the center stand with the front wheel off the ground.
    3. Remove the front axle cotter pin and discard. Loosen and remove the axle nut and washer.
    4. Slide out the axle, tapping gently with a hammer if necessary.
    5. Remove the speedometer gear and remove the tire.
    6. Remove the bolts holding the front fender and the brake caliper(s). See arrows for locations.
    Moving to the top end of the forks, we'll next need to remove the handlebar to gain access to the cap bolts[15], circlips[17], etc. Note: if you have a fairing, you may need to remove it to complete the following steps. Also, on some models, removal of the handlebar isn't required as it doesn't cover the end of the fork tubes. If this is your case, skip to Step 9. Another option is to break the shocks down after removing them from the bike. If you choose this option, skip to Step 13. You may need to refer to Steps 9, 10, 11, and 12 for information on removing the fork springs[11].
    7. Remove the plastic center cover and the handlebar clamp bolt dust covers. Loosen and remove the handlebar clamp bolts and clamps.
    8. Remove and set aside the handlebar.
    9. Remove the fork caps[16] covering the cap bolts[15] and circlips[17].
    Note: On some models, the cap bolts[15] will have an air valve for filling the shocks with air. If you have this style, you will want to let the air out by depressing the valve before removing the cap bolt[15].
    10. Using a clamp, compress the fork spring[11] by pushing down on the cap bolt[15]. This will allow you to pry out the circlip[17].
    11. Remove the cap bolt[15]. Replace the o-ring[12] if it has become damaged. Remove any rust that may be present on the cap bolt[15].
    12. Slide out and set aside the fork spring[11].
    13. Remove the drain plug[18]. Drain the fork oil into a suitable container. Raise and lower the shock several times to remove any remaining oil. Replace drain plug[18] when finished.
    14. Next, we'll need to loosen, but not remove the upper and lower shock pinch bolts.
    15. Using a wedge or large-bladed screwdriver, pry apart the lower pinch clamp to allow the shock to slide down and out.
    16. Insert your cylinder holding tool (or something similar) into the fork tube. This tool can be purchased from chacal or one can be built from scratch using a spark plug socket turned upside-down.
    17. Flip the assembly over and remove the cylinder securing bolt[20] from the bottom of the fork assembly.
    Here you can see the three separate parts of the shock assembly:
    18. Remove and discard the old dust seal[6], oil seal clip[4], and oil seal[5], being careful not to damage the outer fork tube[2] in the process.
    Here are the new parts we'll be installing:
    (Thanks, Len!)
    19. Clean the outer fork tube[2], then install your new oil seal[5], oil seal clip[4], and dust seal[6].
    20. Clean the inner tube[7]. Lubricate the newly installed seals with a light oil and slide the inner tube[7] into the outer fork tube[2].
    From here, you'll just need to reverse the process to finish reassembling the fork assembly.
    If you discover the taper spindle[9] has fallen out while working with the shock, don't panic. Hold the tube at a slight angle and slide it back down the tube. As illustrated, the tapered end faces up and fits into a boss at the end of the outer fork tube[2]. After you get it facing right-side up, push it into the boss with a long dowel. Also, when you're replacing the fork springs[11], you'll notice there's a difference in spring pitch, i.e. one end is wound tighter than the other. This tighter wound end faces up or goes in last. (Unfortunately, I forgot to take a picture of it.)
    As you're reassembling the shock, you'll need to put oil in it. This should be done before you slide the fork spring[11] back in after it has been remounted on the bike. On my '81 Maxim, the factory service manual calls out for 262cc (9.24 oz) of Yamaha Fork Oil 10wt or equivalent. On later models, I presume with air-assist, the factory service manual says to use 278cc (9.4 oz) of oil. I used Castrol 10wt Non-Detergent in mine. Also, if you do have air-assist, the factory service manual says to fill with, but not to exceed, 1.2 kg/cm² (17 psi) of air using a manual air pump. Of course, you'll want to adjust this air pressure to suit your riding style.
    Hopefully, I didn't miss anything in the directions as there were quite a number of steps. If you see a mistake or something I've left out, let me know about it so I can correct it.
    That's about it. Good luck!
  2. schmuckaholic
    California
    Looks good, although I might have specified the model/engine size in the thread title. I was wondering at first why you had to remove the handlebars...
  3. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Looks like the 81 XJ650 and the bar was in the way of using the clamp to compress and get that Circlip out I believe.
  4. Gamuru
    Gamuru Guest
    Granite Falls, WA
    That's exactly the case. Here's the question that matters: are the actual shock tear down directions correct, or are there different types of shocks that require different steps? Perhaps I need to pare down my directions, focusing just on the shocks themselves.
  5. Polock
    nice write-up Gamuru, may i add a lesson learned the hard way
    after adding the oil and before putting the springs in, work the wheel up and down a bit to get any trapped air out
    the spring takes up a lot of volume in the inner tube, and the oil and spring better fit or it makes a big mess
    this didn't happen on a XJ, but i do it anyhow
    oh, and please don't strip the drain screws
  6. schmuckaholic
    California
    They may be correct for your 650; the 750 doesn't require the handlebars to be removed. I pulled my fork tubes and did everything on the shop bench; it's been a while since I did them, but I don't remember compressing the springs being necessary.
  7. Ass.Fault
    Ass.Fault Active Member
    College Station, Texas
    This is probably pretty obvious but I gotta ask.
    The ass'y diagram does NOT indicate any bushing/bearing/metal slide.
    (Those are the same things, just called diffrent names)
    Without those bushings I BET it is alot easier to get those oil seals seated.
  8. Altus
    Altus Active Member
    London, Ontario
    Wouldn't the whole process be easier if you just removed the forks from the triple trees first, and then disassembled? That's what I always do - that way you don't have to bother with removing the bars at all.
  9. Gamuru
    Gamuru Guest
    Granite Falls, WA
    I've edited the instructions with your suggestions. See the paragraph before Step 7.
    I'm not following you. I hate to sound ignorant, but I really don't know what youre talking about. Which bike did you find this "bushing/bearing/metal slide" thing on?
  10. Hillsy
    Hillsy Member
    Most forks I've worked on have copper bushes below the seals and at the bottom of the stanchions. Although your bike doesn't (?).
    Also, another tip with disassembly is to put the complete fork horizontal in a vise (grip the caliper / axle mounts) and undo the damper rod bolt. The pressure from the springs will hold the damper rod in place (no need to use that "special tool"). Then stand the fork up in a bucket to allow them to drain (go grab a cup of tea). Put the leg back in the vise, remove the dust seal and circlip, then pull the stanchion out of the fork leg.
    BTW - nice write up. The pics make it easy to follow 8)
  11. XJXLEE
    XJXLEE Member
    Dublin, Ireland
    I have changed the fork seals in a number of bikes, including both my Maxim X's by simply drilling and screwing a self tapper into each side of the old seal, clamping the screws in a vice grip and tapping upwards. No dismantling required, takes about 2 hours for both sides and you are back on the road. You need a Dremel of course to do this.
    I also tried the dismantling route, just for comparison - no advantage to dismantling IMO.
  12. Ass.Fault
    This is on the 82 750 seca. The haynes calls it a bushing, bike bandit calls it a metal slide(trust me I had to order one), and the guy who helped my remove a stuck bushing called it a bearing.
    So as of right now I am calling it a bush-bear-a-slide :)
  13. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Wow! I just looked up that bike (XJ750RJ) in the Yamaha Online Parts Catalogue. There's a lot more parts involved than what I've got.
    Hmmm... I may need to specify, as schmuckaholic suggested, which bike(s) this applies to.
  14. Hillsy
    Hillsy Member
    The biggest problem with not dismantling a fork with a blown seal is that you won't be able to clean the crap out of the inside of it. Once the seal starts to leak the remaining fork oil will get quickly get contaminated with dirt - and this will shorten the life of the new seal if it is not removed.
    Plus using self tapping screws is just dodgy 8O
  15. tigerextra
    tigerextra New Member
    flagstaff AZ
    hey gamaru, or anyone else for that matter... I cant seem to get the circlip under the top cap (by the air valve) out... do you have any suggestions on getting that bugger out? tools? method? thanks! PS.. cant find the vise in all my moving boxes (just moved this wkend), so im using a friend to push down... will this present a problem? THANKS!
  16. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Truth be told, that little circlip about kicked my butt, too. I finally found and used an old anti-rattle clip from a brake job. I bent a small hook in it which allowed me to slide it under the circlip so I could ease it out of the hole. It about gave me fits. After I pushed the cap bolt pushed down, I shoved the circlip down into the newly made space. Then I slid the anti-rattle clip under it and slide it back up past the groove. Once I made it past the groove, I was able to pull it out of the hole.
    Just make sure that, once ejected, no one gets hit in the eye by flying parts.
      File size:
      11.2 KB
      13,627
  17. tigerextra
    flagstaff AZ
  18. turbobike
    turbobike Member
    Grand Island, Nebraska
    i get to do this shortly..
    the oil leaks out like a... i don't have a cool saying for it. sorry.
    It's just leaky.. leaky over my forks, breaks, tires, fairings...
  19. Ass.Fault
    I removed each fork. Placed it on the ground while keeping it upright.
    Take a half inch socket wrench with a 9" extention. Put this set up between the "top plug" and sholder. Apply pressure from sholder, and use both "free" hands to manuveur some electrical screwdrivers.
    Not the easiest way, but it is still a way to remove that circlip.
    Gamuru you are 100% correct by saying "Watch for flying parts"
    For the obvious safety reasons, but also that clip can go flying.
    The plug has also been know to go skyward from the spring pressure.
    Not nessisarily at a dangerous velocity, but just enough to go rolling under the frig :roll:
  20. AdamLD
    AdamLD New Member
    Houston, Texas USA
    BTW, the 1985 is way different. I did mine today and had a supper easy time of it. No circlips (I hope!) among other things. I wish I had taken pictures. Thanks for the write up, it totally got me headed in the right direction!
  21. chacal
    Gamuru does a fantastic job of these "how-to's".
    Regarding bearing/bushings/slides----all the fork tubes have them, some models use one on the bottom of each inner (chrome) tube, and all models use one on the top of each outer (lower) tube/housing (near the top, below the oil seal).
    Unfortunately, except for a few specific models, they aren't available.....
  22. 00airman
    00airman New Member
    How would one make the holder tool, upside down spark plug socket? is there something in the tube that fits a 3/8" drive 1/2"? If someone could please explain this tool that would be awesome. I alredy have my forks off and springs removed but cant get that allen bolt completely loose.
  23. Hillsy
    Hillsy Member
    Try putting your springs back in. It will tension the damper rod and should allow you to remove the damper bolt.
  24. Gamuru
    Gamuru Guest
    Granite Falls, WA
    See this post on how to make the tool.
  25. 00airman
    00airman New Member
    Thanks for the help, i got it apart, i understand the inverted socket now. I ended up putting an impact gun on a 3/8 drive allen, Definately worked but now i know how to make the tool and i can use it on the other fork. Thanks again
  26. mestnii
    mestnii Member
    San Francisco, CA
    Gamuru - thanks for the excellent write up! I used your step-by-step instructions as well as my manual to do the job on my 85 xj700n. I must say, rebuilding the seals on my 700 was a lot simpler and even more straightforward than on your steed!
    It really helped to have your instructions by my side as my manual is at times too straightforward and skips several details.
    If anyone needs advice or help doing this on their xj 700n, let me know. I can even take pictures if you need.
  27. goser
    goser Member
    Waterloo, Ontario
    Thought I'd pass this tip along after almost stripping out one of my damper rod retaining bolts, for anyone else who may be doing this alone in a less than suitable workspace...
    Holding the fork upright, I set it on top of my 8mm socket and inserted a long drift through the axle hole. By standing on the ratchet handle, and locking the drift between my ankles, I was able to push down on the damper rod retaining tool while turning it, thus breaking it free with a minimum of stress on the bolt head.
    For my 650 maxim I couldn't find a spark plug socket that would work in reverse, but a 1/2" threaded rod with two nuts on either end fit perfectly.
  28. bumpinugs
    bumpinugs New Member
    I made it to the part with the allen wrench and am having some troubles. The inverted spark plug socket works and holds the inside (if I don't hold the "special tool" it will spin freely), but the bolt just won't come out. I see no progress and can't remove it. Could something be stripped? or am I missing something?
  29. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Sorry to pull up old post. But do you use those fork seal bullet to install the fork seal? Thanks
  30. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Not really sure what that is.
  31. vincentmoy
    vincentmoy Member
    Anchorage, Alaska
    Something like this
  32. Gamuru
    Gamuru Guest
    Granite Falls, WA
    Dunno. Never seen one before.
  33. sausage-fingers
    sausage-fingers Member
    Scunthorpe, Lincolnshire, UK
    Is this procedure the same as on the XJ550?
    Mine are very weak so I need to re-oil. What oil do you use, and what quantity in each damper?
    thanks
  34. plansea
    plansea Member
    Hi, Don
    I just did my 82 650 Seca front fork oil and dust seals using your instructions and everything went fine. I didn't have to remove my handlebars but everything else was the same. I put on a new front tire and new fork seals and I am now ready for some serious fall riding. I can not believe how much dirt and sludge was in the bottom of my forks and how dirty the oil was. The last bit of oil out was just like valve grinding compound. I was tempted not to disassemble the forks completely but I am glad I took the time to do it right.The new seals wouldn't have lasted long with all that dirt.
    I also took advantage of the rainy day to replace the exhaust gaskets to cure some annoying exhaust leak noise.
    Your clear instructions make me a bit less worried to work on my bike
    Thanks!
  35. wizard
    Don, sorry to disagree, but that is entirely the wrong way to go about it, put the rebound spring on the damper rod, slide d.r. down inner tube & fix off, then fit the seals, sliding them over the lubricated chrome inner tube.
    (ducks behind rock)
  36. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    the instructions are very close for the 550. i did not have to pull the handle bars at all on mine. as for the holding tool, i used a craftsmen 5/8" sparkplug socket inverted with the rubber removed. the craftsmen is not machined on the inside like some of the others which would not allow the extension to be installed backwards ie my snap-on has a collar on the inside. pm chacal for fork oil (good price) i can't remember the amounts off hand, i'll check later and repost.
  37. plansea
    plansea Member
    For Canadians here is the list of Canadian Tire parts I used to make the dampening rod holding tool
    The rod is long enough to be cut in half and the parts are packaged to give you enough material to make two tools.
  38. bigfitz52
    I gotta go with Wiz on this one. This method ensures the seal "lips" are pointed in the right direction when you're done. Trying to insert the inner tube into the leg with the new seals in it risks getting a lip turned under.
  39. plansea
    plansea Member
    Hi, Wizard and Bigfitz52
    Our shop foreman at work watched me changing my seals and expressed the same concern about installing the inner tube after installing the seal and the fact I was not using a seal installation tool to make sure the seal lips didn't get turned or damaged. I found a hydraulic fitting that was the perfect size to press the new seal in straight in the bore but I could not leave my inner tubes on and use them as a guide because I have some small rust spots up near the handlebar end from years of riding in the rain and leaving the bike out in the rain forest here.
    The foreman offered to machine up a seal installation tool for me but I was too impatient to get riding again. I hope I won't have early seal failure now and have to get that tool made up after all and suffer from "I told you so" :)
    Seals were Yamaha part number 4ES-23145-00 and were made by NGK part number BR4712E
  40. maxhog650
    maxhog650 Member
    Boulder, Colorado
    Hey all, I know this is a pretty old post but im finnaly getting around to my fork seals and ive hit a dead end. i picked up some red oil seals from chacal, thanks. and some new dust seals but i cant seem to get them both to fit. there is a metal lib sitting in the way and i cant bend the oil seal around it. I dont think this is the circlip because i know what that looks like and removed it. heres a pic........... what do i do, is this thing removable
  41. bigfitz52
    If it's what I think it is, that's the oil seal. Dust seal, circlip, then oil seal. It looks like the oil seal is still in there, or at least part of it.
  42. maxhog650
    maxhog650 Member
    Boulder, Colorado
    thanks fitz, thats what im starting to think. all the seals were pretty shredded when i got in there. i can not get this thing out though, its soaking in PB but tottaly stuck
  43. plansea
    plansea Member
    Hi, maxhog650
    I had the same problem with one on my seals. The metal ring you are seeing is the metal backing inside the old seal. There is a spring plus the metal piece you are seeing. One of my seals came out fairly easily but the other one ended up looking like yours. The seal was glued in with a yellow substance and I ended up taking the seal out in bits like you are doing. If you are real careful with a chisel you can cut and bend the metal band without marking any of the seal seating area and start it coming out that way. My old seals were as hard as rock and it looks like you are experiencing the same trouble I had.
    With care and patience it will all come out, take lots of breaks and don't get frustrated and mark the soft aluminum. Everything below the groove for the seal retaining clip has to come out before you fit the new seal
  44. chacal
    Wouldn't the up-and-down movement of the fork tubes have the same effect?
  45. maxhog650
    maxhog650 Member
    Boulder, Colorado
    Thanks plansea, exacly what i needed. Ive tried PB, Deep creep, and boiling water. nothing yet but i am able to rip out little pieces. I guess i'll be sitting with this a while
  46. plansea
    plansea Member
    Hi, maxhog650
    Concentrate on getting the metal ring out, cut it with a chisel or good heavy side cutters, once the metal ring is out the rest is easy.
    Eric
  47. plansea
    plansea Member
    Hi, Chacal
    You said" Wouldn't the up-and-down movement of the fork tubes have the same effect?" and I agree, there is way too much thinking going on here :)
    After riding my bike a bit and enjoying my new front fork action, I think I was stressing too much about installing the new seals. Next time I would just follow Don's advice to the letter. The new seals are soft and you don't need to worry about the lip of the seal getting bent. Just get the new seals pressed in straight, put a bit of fork oil around the seal, put the circlips in, and put the fork back together.
  48. wizard
    Some models have a bush around the bottom of the inner fork leg, this makes it impossible to pass through the oil seal.
  49. chacal
    Thanks plansea.
    Excellent point Wiz!
  50. joshua
    joshua Member
    Lake Worth
    ok i got this problem as well but mine are the 'HARDER' version because they are the seca forks with more parts and the anti dive addition. are the procedures much the same as the 650 forks? i got these parts on order and am waiting to rip it apart but now it seems i may need to go ahead and get em opened up to prepare for adverse conditions as the left fork has been leaking a while and all the "BAD THINGS" you first described are present on my bike. Got my xj cd handy and printer printing these instructions out so i can have em handy by the bench. i am concerned about the 'bushing' i have heard about and wonder if they are available on this model as chacal was quite specific in sayin they are NOT available for most models...........hmmmmmmm sounds eeeeeerrrily problematic. i paid a jerk to do em and he screwed the pooch and me too, so now its up to me to do it right. sigh. guess i will be in touch soon.
