1982 XJ650 stock to bobber project - on a budget
Discussion in 'XJ Modifications' started by crath, Apr 13, 2008.
  1. crath
    crath Member
    Peoria, IL
    I've always built custom street rods and show trucks, and wanted to give the bike thing a try. I got my first bike (07 Honda Shadow Spirit C2) last summer and fell in love with riding. Now for the past few months I have wanted to do my own metric chopped bobber. I started looking on ebay, craigslist, forums, etc. to find a good platform to work with at a low cost. I'm looking to do this on a budget only because I have too many other automotive projects taking up funds as it is.
    I felt lucky when I found an 82 Yamaha 650 Maxim locally on craigslist for $250. The owner claimed it ran, but when I went to pick it up, it only cranked with spark. It hadnt been ran in 10 months so the carbs were obviously gummed up. Since the bike was complete with just under 24k miles, I figured it was a deal. And if I couldnt get it to run, no big loss.
    Here's what it looked like when I picked it up. I only snapped this one pic before I started tearing it down (regretted this later).
  2. leadboots
    leadboots Member
    aylmer ontario canada
    good deal for 250 looks like its in good shape
  3. crath
    crath Member
    Peoria, IL
    As soon as I got home, I started to tear the bike down. Within an hour, I was left with what you see here and a few boxes of parts.
    I also pulled the carbs off for disassembly, rebuilding, and cleaning.
    Here are some tenative plans. If anyone has any suggestions or tips along the way, they would be appreciated.
    -hard tail frame
    -drop rear 6 or 7 inches, stock front ride height
    -make new handle bars
    -keep stock tank, exhaust, fenders, forks, headlight, wheels and tires
    -may or may not keep guages??????
    -solo seat
    -pod air filters
    -stock exhaust with baffles cut out.... maybe???
    -plain jane handle bar grips
    -no turn signals
    -new tail light
    -semi flat black paint
    -....that's about it for now
  4. crath
    crath Member
    Peoria, IL
    A few views from the front showing the stance of the frame, ignoring the handlebars
  5. crath
    crath Member
    Peoria, IL
    If anyone needs any parts, let me know. I still have the seat, rear shocks, and tail light assembly
  6. Ease
    Ease Member
    NL, Canada
    That's a cool seat for a cheap bike!!
    Someone should grab that up!
    (or you could e-bay it and make back half the cost of the bike)
    Lookin forward to the build.
    A few chops floating around. Looking forward to another person's view of what a cool maxim bobber should be.
  7. crath
    crath Member
    Peoria, IL
    I cut the rear frame rails today. I also drained the oil and got a little on the floor. Seems the sparks from the plasma cutter ignited the oil on the floor. That kind of surpised me, lol. Thank goodness I had a fire extinquisher handy.
    Also, when going this low in the rear on a shaft drive; the flange between the output shaft of the transmission and the driveshaft hits on the driveshaft housing. I carefully trimmed this back with a dremel tool. I only needed a few millimeters of additional clearance.
    I also shortened the kick stand. The completely removed the other kick stand and bracketry to increase ground clearance. I still have to weld the spring tab back on and get a shorter spring from the hardware store. (the bottom of the kick stand looks pretty grimy after sitting in the oil dry and oil after I cleaned the garage up a bit)
    I'll be doing the new frame rails tomorrow.
  8. leadboots
    leadboots Member
    looking pretty good keep the pics going
  9. kevineleven
    kevineleven Member
    Columbus, Ohio
    Watch your shaft angle.
  10. Hillsy
    Hillsy Member
    Gas in the tranny perhaps??
  11. Timetonut
    Timetonut Member
    Philadelphia, PA
    What was the regret you mentioned in the very first post? Was it that you only took one pic of the beginning spot?
  12. Ease
    Ease Member
    NL, Canada
    Yeah I think that's what he was saying Timetonut.
  13. wuggawugga
    wuggawugga New Member
    Toronto
    PM'ed you :D
  14. MrShake
    MrShake Member
    Normal, IL
    Odd coincidence...
    I also saw this bike on Craigslist... I had setup an appointment with the guy to see it, from what he said, you showed up and left about 5 minutes before I did. Though he did claim it ran, but I was skeptical!!! I think you got quite the deal man!
  15. willierides
    willierides Member
    NY
    So, you CAN cut the side stand and re-weld it? I need to shorten mine JUUUUST a tad and that would be my preferred method.
    I could scour ebay for a spare kick stand to experiment on, I suppose.
  16. maximuschop
    maximuschop Member
    Indy
    I cut and rewelded mine. Works great.
  17. crath
    crath Member
    Peoria, IL
    Kevinelevin
    I think the shaft angle should be ok, I have rode it last weekend without any problems....the progress I am showing in this thread is pretty far behind... by about a week ...I have got quite a bit more done from what you see here.
    Hillsy
    Yes, there was gas in the tranny. One of the carbs leaked all the gas out of the tank, into the combustion chamber of it's cylinder, and past the compression and oil rings. The bike had been sitting for a while. That explained why the gas tank was dry and the crankcase was WAY overfilled (and the no start problem). I have rebuilt the carbs since that time to resolve the problem. Luckily, I never tried to run it with all that gas in the oil. That's how the oil on the floor ignited so easily from the sparks. That incident was a little scary.
    Timetonut
    Yes, I regretted not taking more before pics. That picture was actually taken by the previous owner. Before I bought the bike, I knew what I wanted to do. My anxious hands picked up tools before they picked up my camera.
    MrShake
    Sorry to tell you, I beat you to the bike. I saw it on craigslist just after he posted it. I called the owner (joe) immediatly and set up a time right to pick it up. He said it was listed for less than an hour before I called him. He had it listed for 300, but told me if I took it then, he would take 250. I didnt even have to haggle him down on the price, he did it for me, lol. I'll let you ride it when I'm done if that would make you feel a little better :) Sorry
    Willierides
    Yes, you can reweld the kick stand all you want. I took about 2 inches out of this one
    Everyone else
    I will post more pics and narration when I get off work tonight
  18. crath
    crath Member
    Peoria, IL
    I picked up some 1" OD round tubing for the frame rails at Morris Tick Steel. I wanted to keep the front section of the frame intact so I didnt alter the geometry at the motor mounts. This will also leave room for pod filters. After the frame rails were in, I cut off the stock rear tank mount, as it will be relocated on the new frame rails. I added a cross member in front of the rear tire for strength. It will also serve as the rear solo seat spring mounts in the future
    I first mocked up then mounted the stock rear fender. I also welded all the holes and smoothed it out a bit. It's not perfect yet, but close. I went through the carbs and put them back in place also. As you can also see, the rear tank mount is in place.
    Those handle bars have got to go!!!!
  19. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    I'm just a little baffled as to why you would weld the new frame parts directly to the right side of the swing arm, and just make a bold-on end for the left. Why not just have welded both sides, or just bolted both sides?
    Aside from that, it looks exactly what I want to accomplish in the future for my 650. I commend you on your efforts.
  20. crath
    crath Member
    Peoria, IL
    I wasnt sure how I was going to do this from the get go either. I would have prefered to do this project on a chain driven bike to make it easier to weld both sides (because of the swingarm design). I would prefer to weld both sides, rather than bolting.
    Because of the shaft drive on the left side, I was very limited to the area that I could weld the steel frame rail to. The way I saw it, the best point was at the bolted location. I also kept it bolted so I could still remove the rear wheel and gear.
    I guess I could have bolted the right side also, but I wanted to have the attachment point as close to the rear axle as possible. This will help overcome the upward forces on the frame rails. And I like the look of having it welded more anyways.
    I also welded the swingarm to the frame at it's pivot points. This was done to reinforce the swingarm to the frame - keep it all in place with a heavy rider over 'less than smooth' terrain. You can see in this picture where I welded the swingarm to the frame. I used some 3/8" wide 1/4" thick steel cut in 2 inch lengths to close up the gap. I bent them at a radius to fit directly in this gap, then welded up both sides.
    Once I welded the pivot points, I was ready to cut out the stock cross member to make room for the battery box. The welded swingarm to the frame acts as a lateral crossmember. Before I cut out the stock crossmember, I also had to change the mounting point for the rear brake switch. It is originally mounted to the stock crossmember.
    I made the battery box from 1 1/2 angle. I'm going to make an aluminum tie down strap later.
    I also failed to mention that I used part of the stock rear plastic fender as a mud guard, as you can kind of see in the picture. I had to trim it down quite a bit to fit.
  21. kevineleven
    kevineleven Member
    Columbus, Ohio
    This is all very Deja Vu to me.
  22. maximuschop
    maximuschop Member
    Indy
    Looks great! You must be very meticulous (sp?) You even bondoed the welds! Very nice handywork, can't wait to see it finished.
  23. crath
    crath Member
    Peoria, IL
    kevinelevin, do you have a thread or pics anywhere of yours? I would like to get some ideas. Thanks
    maximuschop, yea, I get kinda picky about some things. Hopefully it will come out nice, it's the final paint, fit, and finish I am worried about.
  24. maximuschop
    maximuschop Member
    Indy
    Kevins thread is "cosmetic mods done", should be near the top of the thread list. You should go from beginning to end though, makes you really appreciate the work he has done on that bike. I think yours will come out great. I don't gotta worry about mine, it'll be flat black. Hope to have her painted this weekend :D
  25. pygmy_goat
    pygmy_goat Member
    Ann Arbor, MI
    I like the point of still being able to remove the rear wheel--maybe I'm missing something, but how else would you be able to get the rear end apart, if you welded the LHS?
    I like the look of this...and I especially like the attention to detail. I think that will really pay off in the final look. I'm thinking of turning mine (xj700) into something interesting, but I will probably wait until winter comes again, since I want to ride. Inspiring work, IMO.
  26. crath
    crath Member
    Peoria, IL
    Thanks for the comments guys. I cant wait to get out and ride. I've been riding my Honda, but can't wait to get out on this.
    Just a note, you have to remove the stud on the left side to get the rear end out. It's kind of a PITA, but I got it out. I'm not sure how you could weld the left side up and still be able to get it out, unless you welded the frame to the steel housing, which is a little far back in the swing arm IMO.
  27. willierides
    willierides Member
    NY
    Maybe make the left rear a slot instead of a hole? Like a bicycle drop out?
  28. crath
    crath Member
    Peoria, IL
    Yeah, that could be a good alternative.
    BTW, the seat is now sold, thanks to those who were interested.
  29. willierides
    willierides Member
    NY
    If I had a stock bike, that seat would be the nuts!
  30. Ease
    Ease Member
    NL, Canada
    Great job on the frame. I like that it's straight from the swingarm up the length. Makes it look like a solid custom frame.
    Looking forward to the rest of the build!
    (and it's no wonder that seat sold - very cool)
  31. MrShake
    MrShake Member
    Normal, IL
    Don't even worry about it, the guy woulda sold to whoever got there first I think.. I heard the same thing "Your the first to call" and all that. I even told him on the phone I would guarantee him the 300 if it checks out... He even flat out told me "the guy that left had the 300 in cash, so I took it".
    oh well, I'm glad it didn't go to a junk dealer!!
  32. crath
    crath Member
    Peoria, IL
    We'll have to go for a ride when it gets nice out
    Here's what I got done since my last post...
    I made the mounting for the battery box. Aluminum strap with threaded rods. I put the rods up on a lathe to knock the threads off where I didnt want them.
  33. crath
    crath Member
    Peoria, IL
    I got the tank back from the radiator shop. It was filthy inside. There was sand in it. It even had a pair of finger nail clippers in it!!! So they baked it, media blasted inside and out, and resealed it. After I got it back, I circled all the little dents and got to work on smoothing things out
    I also smoothed out the stock locations of the side markers. I also cut and smoothed out the mounting points for the front turn signals. Now I have these holes. Any suggestions to solve this???? I may just leave it.....
    While I had the bondo out, I went to work on a few other problem spots. I am started to get tired of body work. I think it takes a very special person to do this for a living. My patience grew short. I didnt do a perfect job, but it's better than it was. I'm not really trying to make any kind of all out show bike anyways.
  34. kevineleven
    kevineleven Member
    Columbus, Ohio
    I really appreciate someone who works on my level. Your bike is great, Crath.
    Edit-- I'm crazy jealous of your lathe.
  35. danno
    danno Member
    Union Springs,New York
    A blue dot with a clear LED behind it would cover the offensive hole left in the turn signal's wake,or perhaps a gel dome "tuning fork" emblem.You could even epoxy a quarter over the hole,if you have that kind of money to throw around...
  36. yamabobber
    yamabobber Member
    crath it looking really good, asfaras the weld on the right side of the swingarm goes i cut off the eye from some spare shocks ad welded the to the rigid strut
    mainly because i have such a large rear fender welded in place. that way i can drop the rear and get my tire off . and i love how you brought the frame
    with the full conversion of a hardtail, looks very pro.
    check out my gallery for any ideas if it will help, i'm sure i just might borrw a few from you also, thanks again
  37. crath
    crath Member
    Peoria, IL
    kevineleven
    Thanks for the encouragment. I've been slowly reading through all TWELVE pages of your thread. JEEZE, what a lot of work and changes your bike has gone through!! Big props on your project for sure. And yes, lathes kick butt
    Danno
    Great suggestions! I really like the retro blue dot idea - like what you see in old tail lights. I'm wanting to roughly follow an old school look with this bike. So nothing too fancy. So without the LED, that would stay along those lines. I think the quarter may be an even better idea!! You're right, if I can fork out the extra cash (haha), two 1982 series quarters would really compliment this 1982 Yamaha. (Like this bike, I was also born in 82'.... freakin rad)
    yamabobber
    I'll be sure to check out your gallery/posts also. Sharing ideas and suggestions is what these forums are all about.
  38. crath
    crath Member
    Peoria, IL
    Here's the seat I got off ebay for only 40 bucks. It came with 2 inch springs and a bracket. I will be using a set of 3 inch springs instead.
    Not a whole lot of room for it. I forgot to snap some pics of it mounted and together, but I will tomorrow. I also put a slight radius in the seat to get it to fit a little closer to the frame rails. The seat was fairly flat to begin with.
    I made a license plate bracket also. I had to notch out the left side to allow the rear brake and wheel to come off. Kind of a tight fit there. I also drilled and tapped all four holes to make it a little easier to mount the plate - less hardware too.
    I also made my own handlebars today. I started out with a spare length of 1" O.D. for mockup purposes only - I 'professionally' zip tied in place since the bike only accepts 7/8" O.D. I didnt want to hack up my only piece of 7/8" and then not like the way it came out.
    I liked the way the first set with 1" O.D. came out, so I went with that. I used an angle finder to match the angles side to side and between both sets of bars. Anyone need a set of 1" O.D. bars??? I got em'
    These two pictures were taken prior to cutting the overall length of the bars down by 3 inches - just a little to long for my taste.
  39. crath
    crath Member
    Peoria, IL
    I also forgot to mention relocating some of the electronics. The ignition module and the other little black box (whatever it does, lol???) One is mounted upside down just in front of the battery. The other is 8 inches farther forward, upside down, above the carburetors. I welded studs in place for the modules to bolt in place to.
    I snapped these pictures of my seat mounts as well. I used threaded studs to allow for a slight amount of adjustability, depending on rider weight.
  40. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Just a thought, but are those bars going to hit the tank?? Hard to tell from the pics, but they don't look like they have much rise.
    Other than that, the bike looks like its coming along great, I wish I had the shop and gear (and talent) to really tear min apart like that
  41. earz_cd
    earz_cd Member
    Jefferson city, MO
    I don't know what size that hole is but you might be able to use something like this
    http://www.powersportrider.com/CGI-BIN/ ... age=263.00
  42. crath
    crath Member
    Peoria, IL
    Ace
    you're right, the bars are REALLY close. If I dont have them angled just right in the mounts, they do hit. Tonight I removed the controls on the left side to give me some more clearance. I ditched the choke cable and horn all together. I'm going to relocate a new hi/lo headlamp switch under the tank. I have to orientate the controls a little differently on the right side, not much, just a little.
    I thought about doing some type of riser, but I don't have any idea where to get them for this bike.
    earz_cd
    frame plugs!! never have seen those before. Sweet, thanks!
  43. maximuschop
    maximuschop Member
    Indy
    Crath, The bikes looking great! At this rate, you'll be done in no time! What paint scheme you going with?
  44. crath
    crath Member
    Peoria, IL
    I took the bike for a ride around the parking lot today while it was still nice out. Very fun, but a bit of a rough ride. I didnt have the spring loaded seat mounted, so I was sitting right on the frame rails. That made it a little worse. (This was just before I mounted the seat permantly)
  45. danno
    danno Member
    Hey,crath.Glad you liked my suggestions. I have an extra set of blue dots/bezels that I will donate to you in exchange for a mention in the build credits.
    BTW,I have socks older than you...perhaps a wardobe update isn't a bad idea...
    I will be watching your progress!
    Dan
  46. RickCoMatic
    I do something like putting a thick nylon washer and a stainless flat washer with a stainless cap screw in those empty signal mounts.
    You'd have to cut the cap screw down to make the inside clearance; but it would good if you did that and did stainless cap screws on all the other cases; too.
    Stainless with polished covers.
    Sweet!
    http://s254.photobucket.com/albums/hh10 ... teWk_L.jpg
  47. kevineleven
    kevineleven Member
    Columbus, Ohio
    Look at any hardware store for those plugs that go in the empty ends of furnature. They are a heluva lot cheaper than thos frame plugs and are essentially the same thing. I think sears hardware sells them for less than a buck a pop.
  48. crath
    crath Member
    Peoria, IL
    I went to the hardware store today to get some nuts and bolts. I looked and found some of the generic plugs you are talking about kevinelevin. If I would have measured the ID before I left, I would have been able to pick them up. I think I'll go with the plastic ones I saw today for 35 cents, assuming I can get the right size. I am just wanting to go clean, simple, and nothing to flashy with this bike, so they will do the job. Thanks guys!
  49. philbrewer
    philbrewer Member
    Livonia, MI
    Anymore progress on this? I am planning on chopping my fram exactly the way you did this winter.
  50. Anthony14
    Anthony14 Member
    Mississauga, Ontario
    Looking good! I wish I had your welder so then I could have done extensive frame mods like you have done. Lets see more pics!
