Brake bleeding 2 days in no results
Discussion in 'XJ Technical Chat' started by 82maximXJ650Bobber, Aug 30, 2010.
  1. 82maximXJ650Bobber
    82maximXJ650Bobber Member
    New Hampshire
    Sorry about that koolaid, Right now I only have the avatar, let me see if I can get them loaded into my gallery?
  2. clipperskipper
    clipperskipper Member
    Cape Cod, MA
    An old shade tree (but effective) way is to connect a rubber tube to your bleeder and stick the end of the tube in your Dot III, open the bleed screw and now your pumping fluid both ways eliminating compressible air. Works on those stubborn Girling style rear calipers quite well.
    Busy putting everything in two sheds, a barn, and the shop.
  3. 82maximXJ650Bobber
    New Hampshire
    Here is a recent pic! Check it out Koolaid
  4. 82maximXJ650Bobber
    New Hampshire
    Left Side
  5. classicracing
    classicracing Member
    Sweet ride! :D
  6. 82maximXJ650Bobber
    New Hampshire
    Thanks classicracing !!
  7. koolaid5
    koolaid5 Member
    Chambersburg, PA
    NICE! looking a lot like mine except for the seat and fender.
  8. tsmith
    tsmith Member
    Thanks for the link! I think yours are a little to tall for my taste but still looks good!
  9. RickCoMatic
    If you nave a hard time Bleeding Brakes; you have to take a hard look at the Master Cylinder.
    See if the Master Cylinder, alone, will Pump-up.
    The Master Cylinder is Key.
    If those Seals in the Master Cylinder are tired; all the bleeding in the world isn't going to build-up good Hydraulic Pressure.
    When the Master Cylinder is working right; there's NO Problem getting the Fluid to move-out and down the Lines.
    Fill the Master half-way.
    Pull the Brake Lever.
    If you see Brake Fluid shooting up in a fountain stream from the reservoir, ... You need to Rebuild the Master Cylinder.
