Carb removal made easy....well almost
Discussion in 'XJ Technical Chat' started by mlew, Feb 10, 2011.
  1. mlew
    mlew Well-Known Member
    Apex, NC
    This is for the XJ1100 but the principal would be similar for all the XJ models. I have read about some having difficulty removing the carbs from their bikes. While it does take some finesse to wiggle the carb rack through the boots it is not necessary to remove the air box boots. This is how I do it, so far it has worked well on several XJ Yamahas and some Hondas. Like everyone says “ there is more that one way to “ this way works well for me. Total time it took me from start to finish was 15 minutes and that includes taking these pics.
  2. mlew
    Apex, NC
    done
  3. mlew
    Apex, NC
    After a while in the garage messing with these carbs my cat brought me a present. Wife was not too happy, I smelled like gas and then dead squirrel.
  4. tcoop
    tcoop Active Member
    South Weber, Utah
    That’s exactly how I remove my carbs.
    Except it does not involve a sacrificed squirrel 8O :lol:
  5. pirok
    pirok Member
    Aarhus, Denmark
    Well that looks easy on the pictures. My boots on the engine side are damn tight (stiff) its almost impossible to get the carbs off, so i unscrew the boot from the cylinder head on #1 and #4 and then its not that difficult to get the carbs off the boots in the middle.
  6. Redshirt
    Redshirt New Member
    Titusville, FL
    pirok, I did that very thing last night on my xs1100. (sirt time pulling carbs for me btw).
    Good guide.
  7. JameyP
    JameyP Member
    Princeton, NC
    If only I had this guide 8 months ago when I first had to pull my carbs. Great job and Thanks!
  8. mlew
    Apex, NC
    The boots on this XJ11 are also hard, thats why I am going to replace them. It did make it a little more difficult, just a little.The hard part is geting the carbs right. I'll spend more time on them.
  9. wizard
    If I can't find a squirrel will a possum be OK ?
  10. dwcopple
    dwcopple Active Member
    bay city, michigan
    paint the airbox???
  11. mlew
    Apex, NC
    I've had those in the house also Wiz, along with birds, rabbits, snakes, frogs, bugs... anything that lives outside in our area he has brought in.
  12. thecamelman79
    thecamelman79 Member
    Havelock, NC
    Nice write up mlew!
    Just an "I'd" on the air box paint. Every one know I loth painting. A quick run against the buffer with some rouge and a soft wheel will bring some of the black back. not perfect, but of course I dont have to repaint it evertime "Salty" drips gas all over it when he takes the tank on on off either ;)
  13. Erman
    Erman Member
    Oslo, Norway
    You neglected to mention that the true reason your carbs came off so easily is due to the squirrelly sacrifice to Satan (or Stan - his informal name)...
    OT; Hate to say it but the principal is not entirely valid for the 750 Secas. The airbox there is pretty fixed to its position and won't budge.
    The only solution is to push the air intake boots into the airbox when taking the carbs off, and then wiggling them out with a screwdriver or similar when putting them back on.
  14. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    The 750 Seca has a screw on top of the air box (just behind the gas tank) that you can remove to slide the airbox back. It moves just enough to get the carbs to slide out the left side of the bike.
  15. frantic_vike
    frantic_vike New Member
    Victoria, BC
    Just followed this pretty much step for step and got my carb bank out in about 45 minutes. Considering it took me a day and half to get the oil drain bolt out I think that's pretty good progress. Pictures were incredibly helpful.
    Now to figure out why the piston in carb 3 won't move and to schedule an evening of carb cleaning. Joy.
    Cheers.
  16. Robert
    Foamy will haunt you now... squirrely wrath upon your head!
    (nice write up dude!)
  17. waldo
    waldo Member
    San Jose, Ca. 95125
    Good write up Mlew! For those who have real stiff manifolds try warming them up with a hair dryer youll be surprised how easy it is to get the carbs out and back in when you warm up the rubber.
  18. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    I'm still trying to figure out the part that that furry mammal playing in all this. I couldn't begin to count the number of carbs I've removed and this is an excellent write-up....
    but...where was Rocky(the flying sq.....) while the job was being done? In the airbox? Caught living in the muffler? Pushing from the cam chain tensioner side?
    LOL, hope peta doesn't see that, they will be carrying banners(produced by underpaid Chinese workers dying from noxious fumes) and marching(wearing shoes produced by slave labor) in front of your home before running to Mickey Dees(undocumented workers) for some nuggets.
    jeff
  19. mlew
    Apex, NC
    My cat brought the squirrel in the house while I was working on the bike , I guess he was on the hunt in the back yard.
    I am a proud member of PETA.
    P eople
    E ating
    T asty
    A nimals
  20. L.A.
    L.A. New Member
    Wyoming
    I followed this to the letter,,after reading so many horror posts, I was nervous
    and trying to think of any possible way to avoid it......
    Thanks for this,,My first attempt and it went just as described,,,,
    Except,,uh,,,I didn't get no squirrel,,,yet,,,I'm patient......
    THANKS!!
    Mjolnir likes this.
