confused about cam lobe position when checking valve clearance.
Discussion in 'XJ Technical Chat' started by Alan_Vega, Jul 4, 2016.
  1. Alan_Vega
    Alan_Vega New Member
    France
    I own a 750 SECA (11m) and I checked valve clearance but there seems to be two different views on the cam lobe position when checking the valve clearance:
    - according to the tutorial i found on that very site and the haynes manual the lobe should point skywards, 90 degrees opposite the shim
    - according to some other tutorial I read that the intake and exhaust lobe should be pointing to the exterior (opposing each others)
    Now I'm confused because I don't get the same measurements at all when doing both method (basically second method gives me correct clearance and first one gives me tighter measurements).
    So what is the correct way of measuring the clearance on a 1982 XJ750 SECA (11m) ?
    Thanx in advance.
  2. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Point the lobe away, 180*, from the shim and bucket.
  3. Alan_Vega
    France
    like explained in a thread as "If you think of the flat surface of the shim on the lifter as being the x-axis, then the lobe would be pointing 90 degrees away from the x-axis/shim surface and be the y-axis. If you think of the stem of the lifter then you are 180 degrees away from the direction the stem goes when the valve is opened."
    Right ?
    Sorry It seems I cannot insert a picture or link, I got a "spam error" and cannot post reply when I try.
  4. hogfiddles
    NO!!!
    90 degrees
    from the face of the shim.
    Lightcs1776 and Jetfixer like this.
  5. hogfiddles
    Mostly yes----
    The lobe center axis will be dead parallel with the stem center line.
  6. Alan_Vega
    France
    ok thanx that's what I meant
  7. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
  8. k-moe
    In a way he's correct. The nose of the lobe is pointed 180º from the shim face (where it would be pointed when the valve is af full lift). I dont think he's saying that the lobe nose should be 180º from the plane of the shim face.
  9. wink1018
    Muncy, Pennsylvania
    I point the cam lobe AWAY from the shim when I am removing the shim or taking my measurements. It is a surefire way to make sure you are not anywhere near the slope ramp up or ramp down of the lobe. It ensures that the cam is at its short radius of the lobe.
  10. wink1018
    Muncy, Pennsylvania
    Deleted....
  11. hogfiddles
    That is EXACTLY THE WAY YOU ARE SUPPOSED TO DO IT
  12. Polock
    Alen might find this useful
    https://drive.google.com/file/d/0B4j6bf_0WGweSkhkNENSSmdxNzg/view?usp=sharing
    print this, cut out the big circle, cut out the center circle, it should fit almost exactly on the ignition disk, get the first valve in position.
    now line up one line with your pointer and tape or glue it to the ignition disk. when you do the next valve, just watch the lines
    no more estimating, if it's on the line it's right
    Stumplifter and waldreps like this.
