Diode Block
Discussion in 'XJ Technical Chat' started by BleedingOxide, Sep 11, 2014.
  1. BleedingOxide
    BleedingOxide Member
    Brighton UK
    Popped my block. but here's some info on the '82 Xj550rj Seca:
    Resistor colours - Grey, Red, Gold, Gold = 8.2 Ohms 5%
    Diodes - White/Blue Forward Voltage? = 338*(top) !!(middle) 336*(bottom)
    *multimeter spits this out, got no idea what the value means
    (Anode = +, Cathode = -)
    White/Green = + Diode - = White
    Yellow = + Diode - = SkyBlue (Sb)
    Green = + Diode - = Blue/White (L/W)
    Green = Resistor = Black/Red
    Having said all that, my wiring colours don't match the diode colours.
    My White/Green is presumably the white from the reg rec, going to the Headlight relay.
    My Yellow is actually Blue/yellow from the kickstand relay/clutch switch to the Neutral indicator/Starter relay/Neutral switch
    My Green is actually Black/Red presumably from the Oil light going to the Oil switch.
    So.. Have I even got the right relay? it did run until I put a freshly charged battery in..
    Links:
    http://xjdiagrams.thundervalleypower.com/
    http://xjbikes.com/Forums/viewtopic/t=4 ... block.html
  2. bigfitz52
    The "Euro" 550R and the USA-market 550R have different diode blocks.
