How I changed my fuse box without moving it on xj1100j
Discussion in 'XJ Technical Chat' started by jamings67, Sep 11, 2009.
  1. jamings67
    jamings67 Member
    CT USA
    Hello I changed my fusebox today and thought I might show people how I did it. I wanted to keep the box on the side of the battery box so I had to cut off the original bracket that held the fuse box. I then drilled holes in the battery box that fit the new fuse block. This gave me the clearance needed to mount the side cover. I painted the Battery box and mounted the fuse box and cut the bolts flush so the battery can't get busted. Hooked up the wires and coated the connections with liquid tape. That's all there is to it.
    Here are the pictures
  2. MadCowInk
    MadCowInk Member
    I noticed that you (and everyone else on this forum) seems to be using the 6 fuse block. Is this because the 4 fuse version will only take 50 amp max combined, or was it just the only one you could get?
  3. jamings67
    jamings67 Member
    CT USA
    It was available and I figured that I can use the other two for anything I add later. I also use the extra slots for backup fuses. No worrying about finding a fuse when I need one the most.
  4. jamings67
    jamings67 Member
    CT USA
    If anyone knows where I can get a replacement fuse sticker for my bike let me know.
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    What is the red stuff on the wire ends? Good work!!
  6. jamings67
    jamings67 Member
    CT USA
    That is some liquid electrical tape. I thought it was black when I got it. It can not be seen with the cover on and they are all hot so that is the way it will stay for now.
  7. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Nice job, now I can do mine :)
    MN
  8. jamings67
    jamings67 Member
    CT USA
    OK good! Here is what you will need and I omitted above.
    Fuse box of course
    Eight 1/4 inch Female connectors size 14-16 works well. Get a extra or two just in case you miss crimp one. I HATE having to go back to the store for a 20 cent thing. OK rant over.
    I used non weather resistant type connectors planing to solder them but they fit so tight it did not need solder. The liquid tape seals it better but is thin and somewhat messy. Get black! lol
    Bolts nuts washers, paint, drill, cutting wheel, and electrical pliers for striping and crimping.
    I marked the wires with a black marker. I used one two and three lines and left the blue wires unmarked. I also did one side at a time just to keep it simple and f... up proof.
    Have fun and enjoy years of I AM NOT THINKING ABOUT MY FUSE BOX ANYMORE! :wink:
  9. c21aakevin
    c21aakevin Member
    Macomb, MI
    Help.
    Where did you find the fuse block?
    I have been looking all over, and can't find a thing.
    Thanks,
  10. wizard
    Nice job, good looking bike BTW.
    jamings67 likes this.
  11. ktcubed
    ktcubed Member
    St. Augustine, FL
    I got mine from DelCity. Funny, they sent me the wrong bottom half twice. They must have had the part in the wrong bin. Eventually, the sales guy I was talking to finally walked down to the wharehouse and selected it himself.
    Got all the electrical parts I needed from them.
