I Think I Know Why - The Sequel
Discussion in 'Hangout Lounge' started by hogfiddles, Oct 14, 2017.
  1. hogfiddles
    xj550 carbs -
    They don't seem too bad......
    Let's peek inside---
    WHOAH!!!!!!
    2hrs later
    So...... amazingly, I was able to finish the complete tear down after the last pic here, and I was able to extract every jet, o-ring, valve, screw, etc... without marring a single thing. Just for fun, I'm going to bring this rack back to life, and am thinking to go full-bling with it just to take this rack in this condition all the way to the top.
    You probably won't see an update for awhile, but somewhere along the line I'll post it again here.
    Dave
    ecologito and wgul like this.
  2. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    When I saw the picture of the inside the carburetor I thew up in mouth a little. ;)
    ecologito likes this.
  3. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    It looks like Dave threw up in the carb a little...
  4. XJ550H
    should have added a viewing warning to those with a weak stomach:confused:
  5. hogfiddles
    One bowl almost ready to clean....
  6. MattiThundrrr
    Ha. Almost ready to clean.
  7. Jetfixer
    Ahh a little seafoam and spray carb cleaner good as new??? HAHA ....
  8. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Where did you find this set, the titanic wreck site?
  9. Franz
    Look like they are rusted but not busted.
  10. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    This picture is great. It clearly shows the jet that causes so many problems while trying to clean.
  11. bigfitz52
    I dunno what all that crap was but doubtful it was actual rust. Rust requires ferrous metals; there really aren't any in an XJ carb. Neither brass nor alloy rust; the amount of "rustable" metal in a carb is not enough to have been the source of that mess.
  12. hogfiddles
    But the whole inside surface of the tank is ferrous ...... it maybe I should say “WAS”
  13. Fuller56
    Fuller56 Well-Known Member
    Geez Dave, that set is almost as bad as the set I gave you from the flood bike Seca 650. At least this set didn't have the hats rusted through.
    John
  14. hogfiddles
    Agreed, John........ and I haven’t done anything more with that yet— I still have one rack I’m I’m finishing up that has turned into a hassle for me. It’s almost done and will be able to send it out soon though. Then I can play with that nasty rack for a bit again
