IN THE CHURCH OF CLEAN
Discussion in 'XJ4Ever - Supporting Vendor' started by chacal, Dec 28, 2008.
Thread Status:
Not open for further replies.
  1. chacal
    CARB REBUILDING TRICKS:
    Introduction:
    NOTE1: unfortunately, the title above is somewhat mis-leading, for there are no real "tricks" to rebuilding these carb sets correctly.......just having the proper knowledge, the proper tools, and the organizational skills, persistance, and a dedication and determination to doing the job right! These things aren't magic. They aren't due to luck. Having your carbs perform properly is not akin to winning the lottery, i.e. some people get lucky and others don't and that's just life.
    If you dig deep, if you could stand over the shoulder of those who are successful and those who aren't, the ways in which success is determined are pretty clear-cut and straight-forward, as outlined further below.
    As are, unfortunately, the ways in which a lack of success are achieved.
    This guide aims to help you achieve the former.
    NOTE2: these guidelines are written specifically with the following carbs in mind:
    * the Hitachi HSC-32 and HSC-33 series carbs used on the XJ650 (except Turbo), XJ700 non-X (air-cooled) models, and all XJ750 models (except "X" models), and.....
    * the Mikuni BSxx series of carbs used on XJ550, XJ650 Turbo, XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
    Although many of the same thoughts and priciples will apply to other similar carbs used on other Yamaha models, some minor (or major) differences may apply to other model bikes and carbs.
    NOTE3: between research, reading, learning, studying, and then actually DOING the carb removal, rebuild, re-installation and tuning tasks, expect to spend a good 16-20 total hours during your first go-round. And at least 2 of those hours are going to be spent on simply removing and then re-installing the carbs back onto the bike, and then another 2 hours performing the after-install start-up, synchronization, and tuning efforts. If you don't leave yourself enough time to do the job correctly, you will end up rushing, taking shortcuts, and breaking Commandment #1 (further below), and typically horrible results and outcomes can be expected.
    Take your time, be prepared, do it right, and it's a fairly simple process. Do it in any other manner, and you'll chance living the old Fram oil filter commercial warning and slogan:
    "You can pay me now, or you can pay me (a lot more) later........."
    NOTE4: after reading all what's written below, you might be immediately tempted to:
    a) doze off to sleep.
    b) go running, screaming, head in hands, to the nearest bar or pub.
    or
    c) go out and purchase guns and ammo.
    RELAX! Although it seems long.....a lot longer than the 5-6 pages that the factory service manual chapter devotes to the entire "carb rebuild" topic....that's because it's more inclusive and includes all of the things that they "forgot" to include (or didn't even realize would be necessary after 25+ years). Service manuals are designed for experienced service technicians, and are designed to guide them through the complete process, but only with the most basic steps necessary to accomplish the job while also beating the "flat-rate manual" time allotted for the task.
    What is detailed below is basically not only a more (much more!) exhaustive and thorough "rebuild" procedure than the factory would ever dream of specifying, but they're also written in a manner to help guide a non-experienced wrencher thru the process CORRECTLY the first time around, and will explain not only the "basic service", but also how to almost "blueprint" your carbs to good-as or better-than-new condition.
    So break out your favorite beverage and spend a little time reviewing this info. At the bottom of this section are a few great links to some pictorial guides on both the Hitachi and Mikuni carbs, that, when used along with the suggestions below, may allow you to visualize all the dirty little details mentioned below much more easily.
    HOWEVER, as we mention elsewhere, this is not a step-by-step instruction manual! So please make sure that you also have available a factory or aftermarket workshop manual to guide you along your journey to carburetor Nirvana (there will be 4 dancing, almost-virgin carbs waiting for you there.........). :D
    Good luck! But, with what you now have at your disposal, luck will perhaps not play even a minor role anymore in the success of your carb rebuild project!
  2. chacal
    IN THE CHURCH OF CLEAN:
    Introduction: A Few Thoughts We Hold to be Not-So-Self-Evident
    a) If you don't plan on checking and correcting (if needed) the valve shim clearances, then don't bother cleaning and rebuilding the carbs.
    b) If you don't plan on synching the engine when you're done, why bother cleaning and rebuilding the carbs?
    c) If you don't plan on using a colortune plug to properly tune the carbs when you're done, what difference does it make whether they're clean and rebuilt?
    d) You will never, Ever find anyone who is willing to do as thorough a job in cleaning your carbs as you are.
    e) Probably a good 50% of the posts on these forums (and others) revolve around the subject of "My bike doesn't run right." or "won't idle correctly" or "it won't start when cold" or "it idles fast" or.......well, you get the picture. Almost all of these issues are carb-related issues, and their causes, although many and varied, all boil down to one thing:
    Your carbs are out of adjustment, internally dirty (probably filthy, actually), and in critical need of not just "cleaning", but of REBUILDING. You might want to consider that CLEANING the carbs----inside and out----is just one of the many steps (a very imporant one, for sure) in the overall process of REBUILDING the carbs.
    The Gospel of Clean:
    But all of the above is actually the good news! Because now you've isolated the performance problems down to one specific component.
    But that's also the bad news. Because a proper rebuild and re-tuning of these carbs, while not mechanically difficult, can hold quite a few surprises for the un-experienced, the un-wary, and especially for the lazy or sloppy rebuilder.
    Our basic scripture in regards to carb rebuilding (or any other project, for that matter) is this:
    Do it once, completely, thoroughly, and correctly.
    Because: that's how you save yourself money, time, frustration, and aggravation.
    Today's Sermon:
    To that end, I offer you this short sermon titled CARB REBUILDING GOTCH-YA'S in order to make your carb rebuilding experience easier, sexier, to take some of the mystery out of the process, and hopefully allowing you to be more fully prepared to tackle AND TO SUCCEED at the task at hand.
    NOTE PLEASE NOTE: what follows is not, nor is it intended to be, a complete step-by-step, blow-by-blow guide to carb rebuilding. It is intended to be a "helpful assistant" which may help you prevent making the most common mistakes that you will most likely make during your first attempt at this project! Think of it as a "Supplementary Guide" which will try to give you some of the details that Yamaha and Haynes left out of their typical non-specific "assembly is the reverse of dis-assembly" type of instructions when it comes to the carbs.
    More complete step-by-step procedures can be found in other posts in these forums and in the factory and aftermarket service manuals.
    The At-The-Pearly-Gates Question: To Break or Not-To-Break?:
    While many people claim that dis-assembling the carbs from the rack during the rebuild process is NOT necessary, we'll respectfully disagree.
    Although that statement may be true in a few specific instances, it is my opinion that such a course of action is "false economy"---in return for less effort now, you're going to be sitting on ticking time-bomb of future problems just waiting to happen, and waiting to be mis-diagnosed ("hey, I already cleaned the carbs and still have these problems, what now?"), and thus additional time & expense.
    The devil normally resides in all of the details, right?
    "Breaking the rack apart" means taking off the 8 upper and 8 lower rack screws, and then gently "prising" (as the Haynes manual likes to say) the carb bodies apart from each other.......once the rack bracket screws (upper & lower) are removed, the only thing holding the bodies together are:
    * the fuel supply rail connectors (these have o-rings on their ends and fit into the fuel supply bore holes in the carb bodies).
    * the starter enrichment ("choke") circuit pivot rod and their carb bracket attaching set screws.
    * the "overlap - interplay" of the throttle shaft arms between one carb and the next.....look carefully at an assembled rack (where the SYNCH ADJUSTING SCREWS are) and you'll see how the lever arm of each carb's throttle shaft "intercourses" with the corresponding one on the adjacent carb(s) (note that one carb does not have this overlap).
    This overlap between the throttle arm brackets is not a mechanical connection; it is just that, an overlap. You "disconnect" one carb from the other by gently pulling them apart from each other, with some twisting action normally required to get fuel supply connector tubes to break loose from one or the other carb body fuel tube bore.
    That's it! Takes about 10 minutes total additional time to do. Be aware that the factory used some type of thread locking compound on the rack screws so they may need some persuasion to get them moving.
    Our experience has led us to the conclusion that not fully rebuilding these somewhat finicky carb sets while you have them off the bike----and lets face it, the removal and re-install process is one of the most time-consuming and tricky parts of the whole process, and has to occur no matter how much or how little "rebuilding" goes into the carbs while they're off the bike!----is not the correct way to proceed.
    Atonement: If You Break, You Must Then Repent and Un-Break Your Rack, Too:
    After you finish you carb rebuilding procedures, you have to put Humpty-Dumpty all back together again, and the major goal of this part of the process----the one that seems to scare most people off---is getting the carbs back together IN PROPER ALIGNMENT with each other.......but, it really isn't tricky to do, at all. The key is to simply hook all four carbs back up to each other----meaning the fuel supply tube connector pipes and the "overlap" between the synch screw arms (and trust me, it's easier to do than it looks!)----BEFORE you start to install the upper or lower rack brackets and their screws.
    You'll then take this un-bracketed "rack" of carbs and put them, intake-manifold "throat" face-down, onto a REALLY, ALMOST-PERFECTLY FLAT piece of "something". The factory manual recommends using a piece of plate glass, or you can purchase our specially made rack alignment plate produced specifically for this job.
    You'll also discover that putting a board (a 1 x 2, etc.) across the top of the carb intake ports (the airbox "throats", which will now be facing straight towards the ceiling since the intake-manifold throats are against the alignment plate), which will allow you to put some hand pressure on the carbs, which is necessary to keep the carb throats in constant and complete contact with the alignment plate as you are installing and tightening the screws. KEEPING THE CARB INTAKE-MANIFOLD THROATS IN FLAT, CONSTANT CONTACT WITH THE ALIGNMENT PLATE IS WHAT "INSURING PROPER CARB ALIGNMENT" WHILE TIGHTENING THE RACK BRACKET SCREWS IS ALL ABOUT. Believe me, it's not rocket science!
    The individual carbs will automatically align themselves properly in their side-to-side alignment as the rack bracket screws are introduced---that is insured by the drilled holes in the carb bodies aligning with the drilled holes in the rack bracket. It's the perfect front-to-back alignment or slight "twisting" of the carb throttle shaft overplay that might cause the front (or rear) spatial mis-alignment, and that's the purpose of the alignment plate......to make sure that the carbs stay aligned in ALL their dimensions as their brackets and screws are re-installed and tightened.
    Otherwise, if the carbs do not stay in such alignment, the throttle shafts and thus, the throttle (butterfly) valves will never be truly aligned, and this situation will cause you untold amounts of grief down the road.
    As with any other multi-fastener installation procedure, tighten each screw a bit at a time, maybe in an odd-even pattern, first the top bracket screws, then the bottom bracket screws, then back to the top, etc.
    Remember to use some semi-permanent thread locking fluid on both the upper and lower rack screws.
    If you're saying to yourself by now----"gee, that sounds pretty simple"----well, you're right! The devil is in the little details as mentioned elsewhere, mostly pre-prep work and the marking of the component pieces. The re-alignment of the carbs back into a completed "rack" is easy-cheesy! Believe me, the mechanical "nuts and bolts" aspects of breaking the rack apart are SIMPLE; it's mostly the meticulous attention to the small details BEFORE YOU EVEN START that holds the keys to success or the trap of failure for this project.
    Those 10-20 minutes of inspection and notations you made before you break the rack or the individual carbs apart takes care of that issue........things like, note the way the throttle arm brackets overlap. Note the way the throttle return springs are located on their stop pegs. Note where the hose and cable clips are located, and in which direction they are oriented, etc. Those kind of details.
    Here, let me help bang this point home: without a lot of pictures or drawings or etc., how well do you think you would be able to deal with this issue:
    http://xjbikes.com/forums/index.php?threads/18093
    or this?:
    http://www.xjbikes.com/forums/index.php?threads/enrichment-rod-spring.51779/
    how about these --- are you going to "remember" how all these throttle shafts and springs fit together with each other?:
    http://xjbikes.com/forums/index.php?threads/first-time-taking-apart-carburetors-lots-of-pics.48063/
    Case closed.
    Scripture:
    So please, consider doing a Full and Complete Carb Rebuild procedure when you have the time. Given the age of the bikes, the lack of attention that the previous owner paid to them, and the sloppy level of work that dealership service departments do (or may have done in years past)----give your carbs the proper attention that they deserve. You'll learn alot, you'll solve most of the carb related problems with these bikes, and you'll have the pride, knowledge, and experience of having done it yourself.
    And your carbs will thank you.........
  3. chacal
    Genesis, a/k/a IN THE BEGINNING........:
    Have ALL parts and supplies you can even imagine or consider replacing already ordered and received.
    - at the end of this guide there is a semi-complete list of parts that you'll need, besides any that you discover to be missing, damaged, or unusable.
    Have ALL of the tools, special or common, that you'll need. Stopping and starting not only wastes time and effort and is frustrating, but it leads to confusion or shortcuts, both of which are 4-letter words in the carb-rebuilding biz....
    - at the end of this guide there is a semi-complete list of tools that you'll need.
    Obtain (beg, borrow, but do not ever Steal) a Factory Service Manual and/or an aftermarket Haynes or Clymer Owners Workshop Manual and read through it before you begin. Try to make sense of the pictures and procedures IN YOUR MIND before you even remove the carbs.
    Especially if this is the first time you've attempted a carb rebuild, this "pre-learning" will most likely be invaluable training for you.
    Have a pad of paper and a pencil and take AT LEAST 5 pages of notes, sketches, and diagrams. That's five 8-1/2" x 11" pages. If you don't fill up five pages, you have either:
    a) done this at least 10 times before, or.....
    b) you're going to hate yourself in about 2 days time.
    Better yet, have a digital camera and a friend available for at least the entire 2 hours carb rack removal and dis-assembly steps. Count on taking at least 100 pictures.
    Think I'm joking? I'll place 10-to-1 odds that you'll be cursing like a drunken sailor AND THROWING THINGS within 36 hours if you don't take the above advice! Here, let me help bang this point home: without a lot of pictures or drawings or etc., how well do you think you would be able to deal with this issue:
    or this?:
    Case closed.
    Exodus, a/k/a PRE-DISASSEMBLY:
    NOTE: Memorize this!: the #1 carb is the left-most carb, as you're sitting on the bike (clutch lever side of the bike). #4 carb is the right-most carb (brake lever side of the bike). Carbs are "numbered" starting with the #1 (far-left) carb and then progressing, left-to-right, to #2, #3, and finally #4 (the far-right carb).
    Whether you're just taking the carbs partially apart, or doing a full atomic-level rebuild, it's important to remember that while some parts----such as the carb hats, screws, bowls, floats, jets, etc.----are interchangeable parts, it's still a great habit to keep them separated , since you'll eventually get around those parts that are NOT interchangeable between carbs....and if you don't take note of them BEFORE you take the individual carbs apart, then you will get confused upon re-assembly (actually, you'll eventually figure it out, but trust me, it's easier to do the 10 minutes of advance prep, study, and making notes beforehand).
    Here's some helpful tips as you dive into your dis-assembly:
    * the Carb Bodies...mark them 1, 2, 3, 4, with an engraving pen or a point punch. Although some carb bodies are marked from the factory with their number (i.e. 1,2,3,4) stamped into a flat flange surface on the body, some aren't. And if not, you'll need to mark them with some method to insure that you get it right, since:
    a) the butterfly shafts and valves MUST to be returned to their original bodies, and.....
    b) although you can tell carb bodies #1 and #4 apart from each other even if they are not marked, on some models carb bodies #2 and #3 are identical to each other but their throttle shafts and valves need to go back into their correct bodies.......and this is why you mark the carb bodies 1, 2, 3, 4.
    You can mark them with a point punch (1 dot per carb body number), or an electric engraving pen, or a set of number punches and just whack them onto the flat surface near the lower carb mount boss.
    * Mark the throttle shaft - arm units with an engraving pen 1, 2, 3, 4.........there are actually three similar-but-different arms, and you want to make sure you assemble the correct shaft back onto its proper carb body!
    * Mark the removable throttle shaft end brackets with an engraving pen 1, 2, 3, 4.......there are actually three similar-but-different arms, and you want to make sure you assemble the correct one back onto its proper carb body!
    * Butterfly valves....mark them 1, 2, 3, 4 on the side facing the airbox with an engraving pen. Scribe an arrow so that you'll know which way is pointing up or down (doesn't matter which, as long as you're consistent) so that the butterflies can go back into their proper carbs, and oriented the same way they came out. If you don't get this right, expect big troubles later!
    * Carb bowls, there are left-side (#1 or #2) and right-side (#3 or #4) bowls. No need to number them, as it is obvious which is which, but just remember which are which when doing re-assembly.
    * Make some type of mark on one end and write it down (#1 end or #4 end) of the starter circuit rod (use a small saw mark or point punch one end).
    By the way, have I mentioned how handy an electric engraving pen ($10 or so at Wally World) is when working on these carbs?
    * The tightly-wound throttle return springs.......mark them or bag them individually, there's 3 different ones. Note where and how the spring end hooks are oriented in relation to the throttle arms and the carb body retaining tangs before taking them off the carbs! Make a sketch! You'll never remember this later!!!!
    * The various cable and hose Routing Brackets and Clips on carb hats and on the upper rack bar........make a diagram of which one goes where, and how - which way it is oriented when installed.
  4. chacal
    40 Minutes in the Desert, a/k/a/ DIS-ASSEMBLY:
    This is the easy part! But make absolutely, positively sure that you take as many notes and diagrams as you need NOW, so that you'll remember all the important "little things" LATER in regards to what order in which the parts come apart, where they are located, what their orientation is, etc.
    Although it is more time-efficient to take all the carbs apart all at once, and then move onto the cleaning and rebuilding tasks and do all of that as a "batch", if this is your first Carb Rodeo we suggest you take one carb completely apart first, make your notes, etc., and then immediately (skip the cleaning, etc. tasks for now) put it all back together again.
    In this manner, you'll quickly learn the things that you overlooked or "forgot" to make notes about, and you'll still have another (actually, three "others") carbs to use as a true reference point to compare against. EVEN IF YOU HAVE LIMITED MECHANICAL SKILLS OR PREVIOUS CARB KNOWLEDGE, THIS METHOD PROVIDES A FAIL-SAFE WAY FOR THE 100% SUCCESSFUL COMPLETION OF A CARB REBUILD PROCESS. This step will add maybe an additional 30 minutes to the overall total rebuild process, but might save you an incredible amount of time and grief later.........
    Here are some problems areas that you should pay special attention to, and take extra precautions with:
    - the Carb Hat Screws.........on Hitachi model carbs, there are different lengths in different positions. Almost all positions that have a clip or bracket associated with them use longer screws.
    Mikuni models use the same length carb hat screws in all positions.
    - the removal of the Idle Mixture Screws.........this can be tricky on two fronts:
    * the screws were originally covered with an anti-tamper cap, and this cap may or may not still be in place. If it is, then you must CAREFULLY remove it by drilling a small hole in the center of it (perhaps 1/8" diameter, using a slow-speed drill) until you just barely puncture through this cap. Careful!----for the head of the idle mixture screw is directly below this cap!!!
    Now, take an appropriate sized sheet-metal, drywall, or wood screw and drive it into the hole you just drilled, and then yank the cap out of it's hole. The cap is just a "friction-fit" into this hole, so it should come out "kinda" easily......
    Now you have to remove the idle mixture screw itself: these are commonly seized, and you do not want to ruin the head of this screw while trying to remove it. We offer a properly-sized idle mixture screw Screwdriver (HCP254) that fits the slot head of this mixture screw perfectly, greatly aiding in the safe removal of this screw (it's also great for performing the future mixture screw adjustments that you'll need to perform later as part of your carb tune-ups).
    To assist in the removal of this screw, use all the tricks at your disposal for extracting seized or frozen fasteners: heat, penetrating fluids, a blow to the head, a slight "tightening" force applied before attempting to loosen it.
    If the head of these screws are already (or become) damaged, then it's onto Drill Bit and E-Z Out World for some fastener surgery. IF YOU DON'T FEEL CONFIDENT PERFORMING SUCH A TASK, THEN TAKE THE CARB BODY TO A MACHINE SHOP AND PAY THEM TO EXTRACT IT. This will be alot cheaper than having to replace the carb body if, by mistake, you drill out or otherwise destroy the threads in this area!
    Once the screw is removed, be sure that the tension spring Washer and the tiny O-Ring at the bottom of the bore also come out....the o-ring, especially, can get stuck at the bottom of this bore. Use an appropriate sized bent-tip dental pick to manuever this o-ring out.
    - the Retaining Screws that hold the butterfly valve to the throttle shafts......on Hitachi carbs, they use self-locking threads and the heads strip easily. Make sure you use a proper sized screwdriver to try and remove these screws or you'll end up with a real mess to resolve!!
    On Mikuni carbs, this story goes from merely bad to worse: these screws are an absolute BEAST to remove, and it is very easy to destroy the screw heads as well as the throttle shaft threads while trying to remove them---if proper precautions are not taken. You will want to review the information in this forum thread before attempting removal:
    http://xjbikes.com/forums/index.php?threads/8011
    All other fasteners, be they bolts, screws, or nuts: they're not self locking, but they strip even easier, especially if you do not use the proper size and type screwdrivers.
    Float Pin Removal Warning: failure to heed this advice can send you straight to carb purgatory, so read carefully:
    The FLOATS are "pinned" in place via a small-diameter steel FLOAT PIN, in-between two cast upright "arms" that extend up from the carb body floor. SUFFICE IT TO SAY THAT THESE CAST FLOAT PIN SUPPORT "ARMS" ARE MORE THAN EXTREMEMLY FRAGILE! Break one of them off, and the carb body is toast......
    On Hitachi model carbs, the float pin is a straight pin, and is slightly under-sized compared to the size of the pin holes in these cast support arms......and as such, they are usually pretty easy to remove (to remove the floats and the float needle valve assembly, this float pin must come out first). Sometimes corrision and gunk can cause this pin to seize, in which case you must be very careful in your attempts to remove it. The careful application of some heat to the cast arms, in the pin hole area, will cause the slight expansion of the cast aluminum area surrounding the float pin, and can help free a stuck pin.
    On Mikuni models, you're in a world-'o-hurt before you even begin. The float pins on all Mikuni carbs are not undersized, and almost seem as if they were designed to be a "fiction fit" within the pin holes in those cast support arms......and as such, they are nearly impossible to remove easily. In addition, the Mikuni pins have a mushroomed "head" on one end, meaning they can only come out in one direction, which can present some challenges all their own if you have not broken the carbs out of their rack......
    Once again, they key is patience, penetrating oil, heat, and gentle pushing - punching on the end of the pin. IT IS INCREDIBLY EASY TO BREAK THE CAST UPRIGHT SUPPORT ARMS ON MIKUNI CARBS WHILE ATTEMPTING TO EXTRACT THESE FLOAT PINS!
    So..........IF YOU DON'T FEEL CONFIDENT PERFORMING THIS TASK, THEN TAKE THE CARB BODY TO A MACHINE SHOP AND PAY THEM TO EXTRACT THEM. This will be alot cheaper than having to replace the carb body if you break off these support arms!
    Once the float pins are driven out (using a proper sized punch) even slightly, you can grasp the exposed end of the pin with some pliers and carefully "twist-and-pull" the pin the rest of the way out. Make sure you twist and don't just "pull"!!
    And once they're out, please do polish the pin with some very fine finishing paper and remove any deformities that the punch, or the pliers, may have caused on the end(s) of the pin.
    Starter Plunger Valve Removal Warning:
    This brass starter (enrichment) circuit plunger valves are actuated by stamped steel "finger" brackets which ride on the rotating starter circuit shaft. The "finger" bracket grabs this brass valve at the "head" of the valve, in a recessed area of the starter valve shaft. This machined-down "recessed' area of the plunger valve is a weak point in the valve, and if the plunger is stuck in it's bore, you can easily snap off this head at that recessed point. This problem is most common on Mikuni carbs, but it applies to all the carbs. Be afraid, be Very Afraid!, of any starter plunger valve that is seized in the bore when you try to remove it!
    Also----on some Mikuni models, the needle tip of these starter plunger valves are embedded into the base of the plunger via a rubberized type seal, which will melt and be destroyed if immersed in carb dip. And no, the seal is not replacable, you'll need a new plunger valve............
    You're Screwed.......Or, All About Fasteners:
    * Some very useful tips for removing screws is the following:
    - always select the proper sized screwdriver for the screw head! ALL phillips-drive screws on these carbs----in fact, on the entire bike---are what are known as "JIS" type screws. JIS stands for Japanese Industrial Standards, and similar to our SAE specifications, the Japanese have their own style and specifications for various hardware and fasteners, and one of those has to do with the type of "phillips slot profile" used in screw heads. It's different than in the rest of the world and to properly remove these screws, you need to use----you guessed it!----JIS profile SCREWDRIVERS.
    - begin every screw removal task by placing the proper sized screwdriver tip into the screw head, and then giving a quick, sharp, forceful blow to the screwdriver head with hammer (or similar)......in essence, as if you were trying to "hammer" the screw, like a nail, into the object. This force goes a long way towards breaking the physical bond between the screw threads and the object it is screwed into, thus making screw removal so much easier and safer.
    - next, apply a slight TIGHTENING torque to the fastener before you attempt to loosen the screw, bolt, etc. "Slight" is the key word here! You are not actually trying to tighten the fastener any more than it already is, but you are trying, again, to break the physical bond----ever so slightly----between the threads of the fastener and the object it is fastened to. Even the tiniest bit of movement or force can have this result, which then makes the removal process that much easier and safer.
    - when encountering frozen fasteners, the use of HEAT and COLD when trying to remove them is a much better idea than simply trying to use brute force. Penetrating oils of various kinds (hint: olive oil is a great lubricant, and is basically non-flammable) works better if the part is heated. The differential expansion coefficients of dis-similar materials, including those seized-together metal parts, is a natural law of God and the Universe and is free to everyone. By HEAT, we mean a heat gun or a pencil tip torch, used very carefully (less is more). By COLD, we mean like 2-3 hours in the freezer or immersed in ice chips or water.
    - another useful trick is to heat as much of the area surrounding the stuck fastener.....but not the fastener itself.....and then take a crayon or a wax candle and apply it to the very joint of the fastener and its threaded bore hole. The wax will be wicked into the threads of the fastener and its surrounding hole. Then let it cool down to the touch and repeat twice this process twice more. The wax acts as a lubricant, and follows the heat----so put the heat where you want the wax to go. You'll be amazed.......
    - sometimes, even after Heruclean efforts, you just ain't gonna budge (or you've broken off) that puppy. Then, the world of ez-outs, left-handed (counter-clockwise rotation) drill bits, and stud extractors (extremely useful on snapped-off intake manifold bolts or exhaust flange studs) will become your best friends.
    - after fastener removal, if you encounter threads that are stripped or corroded or buggered or anything other than "pristine", you need to "clean" or re-cut the threads back to their original condition (typically called "chasing" the threads). If the thread damage occurs due to corrupted threads on the fastener itself, then you might be able to "chase" the threads back into good condition (the thread in the carb body, that is!) by using a known good screw (of the same size and thread pitch, of course) to perform this "re-threading" operation (after all, the screws are steel, and the carb bodies are aluminum, so the steel threads of the screws will tend to "cut" new threads easily in the softer aluminum of the carb body). A better way is to use a tool-steel re-threading TAP tool, as these are both harder and more precisely made than a regular screw, and are the professional method of cleaning, chasing, and/or re-cutting new threads.
    The following goes without saying, which means we need to say it anyway: Do not EVER attempt to re-use a fastener that has damaged threads by forcing it into a threaded hole!! And this warning is especially true for soft-metal objects, such as carb bodies, as the (damaged) harder steel screws will cut new, now damaged threads into the softer carb body metal.
    Everything else is simply cleaning and screwing things together, and if you can tell apart the business-end of a screwdriver from the handle, there's not that much more necessary in the way of "special skills" needed to rebuild carbs!
  5. chacal
    Towards The Promised Land: INSPECTION:
    - Check the Vacuum Piston Rubber Diaphram for even the tiniest of air holes or tears. Hold it up to a strong light and if you can see light (pin holes) in the diaphram, it may be toast. One method of repair is to use an ever-so-thin smear of the "liquid electrical tape" product to rebuild the diaphram surface, and thus block those pinholes.
    Note that a vacuum diaphram that does not seat completely (or that has tiny pin-holes in it) will not hold the vacuum signal as strongly as others will, and thus that vacuum piston and the main fuel needle that it controls will REACT DIFFERENTLY (more slowly) to the vacuum signal in that carb as compared to the others. This can be a big problem! Make sure that the vacuum diaphram is not truly damaged, and make sure that it can re-seat itself into that little channel properly.
    Additionally, there are plastic cinch rings both above and below the inner edges of the vacuum diaphram; these rings exert pressure against the diaphram, both locking it in place and providing a true vacuum seal between the diaphram and the outer diameter of the piston. On Hitachi models only, the top ring tends to develop a split, or even a complete fracture, over time (we've never seen a Mikuni cinch ring split, ever). As long as the rubber diapham material is no pinched or split in the vicinity of the fractured area of the cinch ring, then things will "probably" be okay.
    If there is damage to the diaphram, then the entire piston and diaphram unit should be replaced.
    Diaphrams that are in otherwise good condition could benefit from the application of our rubber Rnr Fluid, which is a specially formulated "rejuvenator" fluid that helps lubricate and keep rubber products soft and pliable.
    - Check the long, skinny aluminum Main Jet NEEDLE to make sure they are the correct size, and also to make sure that they haven't retracted from their plastic top cap.....if so, carefully push the needle cap back "flush" with the ridge near the bottom of the cap. Also check the very end of the tip for scratches, gouges, or deformation ("mushrooming") of the very bottom, pointed tip.
    Also check to make sure that all of the needles are of the correct and same size. The needle size is engraved into the needle barrell, just below that plastic top cap:
    Hitachi models:
    all USA 1980-3 XJ650 Maxim, Midnight Maxim, and 1982 XJ650RJ Seca models, all Canadian 1982-84 XJ650 Maxim models, and 1982-84 XJ650 UK/European 14R models:
    - Hitachi HSC32 carbs
    - Needle: Y-10
    - Emulsion Tube/Needle Jet: 3.2mm
    all Canadian 1980-1 XJ650 Maxim, Midnight Maxim, and 1982 XJ650RJ and RJC Seca models:
    - Needle: Y-12
    all 1980-81 XJ650 UK/European 4K0 and 4K1 models:
    - Needle: Y-11
    1981-83 all XJ750 (USA) models:
    - Needle: Y-13
    1981-83 all XJ750 (Canadian) models and 1981-84 XJ750 UK/European (11M) models:
    - Needle: Y-14
    XJ750 E-II models:
    - Hitachi HSC33 carbs
    - Needle: Y-17
    XJ750RL models:
    - Needle: Y-18
    XJ700 N/NC/S/SC models:
    - Needle: Y-20
    Mikuni models:
    XJ550 1981-83 Maxim:
    - Mikuni model BS28 carbs
    - Needle: 4GN
    - Emulsion Tube/Needle Jet: O-8
    XJ550 North American Seca:
    - Needle: 4GZ11
    XJ550L Maxim 1984:
    - Mikuni model BS32 carbs
    - Needle: 4CP7-3 on cylinder #2
    - Needle: 4CP3-3 on cylinders #1, 3, and 4
    - Emulsion Tube/Needle Jet: N-8
    1984-85 FJ600:
    - Needle: 4CP6
    1984-87 and 1989-91 XJ600:
    - Needle: 4CP7-3 (cylinder #2) and 4CP3-3 (cylinders #1, 3, and 4)
    - Needle: 4CL8-3 (German 51H models only))
    1992-98 XJ600 Seca II (USA):
    - Mikuni model BDS26 carbs (USA)
    - Mikuni model BDST28 carbs (except USA)
    - Needle: 4B10 (USA)
    - Needle: 5CT or 5CTZ (1992-95 Canada and Australia)
    - Needle: 4BC-12, -13, -14, or -15 (1996-98 UK)
    - Emulsion Tube/Needle Jet: O-4 (carbs 1 & 4) or O-2 (carbs 2 & 3)
    XJ650 Turbo:
    - Mikuni model BS30 carbs
    - Needle: 4DPS39
    - Emulsion Tube/Needle Jet: O-6 (style #318)
    XJ700-X:
    - Mikuni model BS33 carbs
    - Needle: 5FZ83 (XJ700 XNC models)
    - Needle: 5FZ82 (all models except XJ700 XNC)
    - Emulsion Tube/Needle Jet: Y-2
    XJ750-X:
    - Needle: 5FZ83
    XJ900RK, RL, and XJ900P models:
    - Mikuni model BS36 carbs
    - Needle: 4HZ22 (900RK) or 4HZ26-3 (900RL and Police)
    - Emulsion Tube/Needle Jet: Y-0 (style #318)
    XJ900 F, N models:
    - Mikuni model BS35 carbs (Switzerland)
    - Mikuni model BS36 carbs (except Switzerland)
    - Needle: 4HZ26-3 (Switzerland)
    - Needle: 5FZ62-3 (Switzerland)
    XJ900 58L, 2HL, 3NG1, 3NG2 models:
    - Needle: 5FZ62-3
    XJ900 1991-94 4BB1, 4BB2 models:
    - Needle: 5FZ10-3
    XJ1100:
    - Mikuni model BS34 carbs
    - Needle: 5GLZ-34
    - Emulsion Tube/Needle Jet: X-2
    XS1100:
    - Needle: 5GZ6/3 used on all 1978-79 XS1100 carbs
    - Needle: 51Z7 used on all 1980-81 XS1100 Standard models
    - Needle: 5GL16 used on all 1980-81 XS1100 Special and Midnight Special models
    BENNY AND THE JETS, a/k/a make sure your carb has the correct sized jets and note the positions of "which-jet-goes-where":
    The fuel jets are always located in the bottom (base) of the carb body.
    The air jets are located either on the upper side of the carb body.....underneath the vacuum piston diaphram....or, on some of the Mikuni models, in the carb throat, facing the airbox.
    NOTE: on Hitachi model carbs, the main fuel jet and the pilot fuel jet are the same size and shape.....they differ only in the size of the passage drilled in them. On Mikuni carbs, the main fuel jet has the large, "mushroom" head, while the pilot fuel jet is a long, skinny "tube" style jet.
    FUEL JETS:
    - the MAIN FUEL JET uses a copper washer underneath it, and screws directly into the removable "main needle jet" or "power valve" or "emulsion tube", and is the higher numbered (larger opening) jet. The jet size is stamped into the top face "rim" of the jets on all model carbs.
    Hitachi MAIN FUEL JETS:
    #102: XJ750E-II models (cylinders #2 & #3)
    #105: XJ750E-II models (cylinders #1 & #4)
    #106: 1984 XJ750RL Seca models.
    #107: all XJ700 non-X models.
    #110: all XJ650 North American models (except 1982-84 Canadian models), all 1980-81 XJ650 UK/European (4K0 and 4K1) models, and all XJ650 Police (37G) models.
    #112: all 1982-84 XJ650 UK/European (11N and 14R) models and 1982-84 XJ650 Canadian models.
    #118: all XJ750 Police (24L and 37H) models.
    #120: all XJ750 North American and UK/European models except the 1984 XJ750RL models.
    Mikuni MAIN FUEL JETS:
    #100 is used on:
    1985 all XJ700-X models (*see note below)
    1984-85 XJ900 F, N (Switzerland only)
    1991-94 XJ900 models with BS36 carbs
    #102.5 is used on:
    1984-85 FJ600 California models
    1992-98 XJ600 Seca II North American models (some non-North American models used #105 jets on the outer carbs)
    XJ900RK US & Canada with BS35 carbs
    XJ900RL and XJ900P (31A models) with BS35 carbs
    XJ550L (1984) on cylinders #3 and #4 (***see note below)
    #105 is used on:
    1984-85 FJ600 non-California models
    1992-98 XJ600 Seca II models (some non-North American models used #105 jets on the outer carbs and #102.5 jets on the center carbs)
    1986 all XJ700-X models and all XJ750-X
    XJ550L (1984) on cylinders #1 and #2 (***see note below)
    #107.5 is used on:
    1986-88 FZ600 models
    XJ900 most 1984-90 models with BS36 carbs (except USA, Canada, of Switzerland)
    #110 is used on:
    1980-81 XS1100 LG/LH/SH models
    #112.5 is used on:
    XJ550 all models
    XJ1100 all models
    #115 is used on:
    1980-81 XS1100 standard models for cylinders #1 and #4
    #120 is used on:
    1980-81 XS1100 standard models for cylinders #2 and #3
    #125 is used on:
    XJ650 Turbo carbs for all cylinders (**see note below)
    1980-81 XS1100 SH model
    #127.5 is used on:
    XJ650 Turbo carbs for cylinders #1 and #4 (**see note below)
    #130 is used on:
    1978-79 all XS1100 models (****see note below)
    #132.5 is used on:
    XJ650 Turbo carbs for cylinders #2 and #3 (**see note below)
    #137.5 is used on:
    #140 is used on:
    NOTES:
    * there are discrepancies between the parts manuals and the service manual information on the size of the 1985 XJ700-X main fuel jets; one source claims these carbs were equipped with #100 main fuel jets, while other sources claim a #105 size main fuel jet. Our experience leads us to believe that the correct size for the XJ700-X and XJ750-X models is the #105 size for both the 1985 and 1986 model years.
    ** there are discrepancies between the parts manuals and the service manual information on the size of the 1982-83 XJ650 Turbo main fuel jets; one source claims these carbs were equipped with #127.5/#132.5 combination of main fuel jets as described above, while other sources claim #125 size main fuel jets were used in all cylinders. Original carbs that we have explored have the #127.5/#132.5 combination of jets as shown above.
    *** although listed this way in factory service manuals, we believe this is a misprint, and the correct configuration should be:
    - the #102.5 on XJ550L (1984) on cylinders #1 and #4
    - the #105 on XJ550L (1984) on cylinders #2 and #3
    **** depending on model of carbs used, these bikes could have been equipped with either the #130, #137.5, or the #140 main fuel jets.
    - the PILOT FUEL JET has no washer and is the smaller (lower numbered) jet. Also check to make sure that all of the jets are of the correct and of the same size. The jet size is stamped into the top face "rim" of the jet on Hitachi models, and engraved into the side of the "tube" section on Mikuni models:
    Hitachi PILOT FUEL JETS:
    #36.5: all XJ700 non-X models.
    #40: all 1980-83 XJ650 USA models, 1980-81 XJ650 Canadian models, 1982 XJ650RJ and RJC Seca Canadian models, 1980-82 XJ650 UK/European (4K0) models, 1981-83 all XJ750 USA models, XJ750E-II models, and 1984 XJ750RL Seca (Canada) models.
    #41: all 1984 XJ750RL Seca (Australia), all1981-83 XV750, and XV920 models
    #43: all 1982-84 XJ650 Canadian models, 1982-84 XJ650 UK/European (11N and 14R) models, 1981-83 XJ750 Maxim, Midnight Maxim Canadian models, 1981-84 XJ750 UK/European (11M) models, and XJ750 Police (24L and 37H) models.
    #45: all XJ650 Police (37G) models.
    Mikuni PILOT FUEL JETS:
    Note that these Mikuni pilot fuel jets are recessed wa-a-a-a-a-y up inside the pilot fuel passage boss that is cast into the bottom of the carb body. In order to remove these jets, which are (of course) normally partially or fully seized, you must use a proper-sized flat blade screwdriver that will grasp and turn the pilot jet, rather than wallow around and chew up the slot in the head......which will then require tedious and dangerous surgical procedures involving ez-outs and the like to try to extract the jet without damaging the threads in that recessed, blind passge.
    #17.5 XJ600 Seca II (1992-98)
    #32.5 XJ650LK Turbo (1983)
    #35 XJ550 all 1981-83 models (except Euro), 1984-85 FJ600, XJ650LJ Turbo (1982), and XJ700-X* all models
    #37.5 XJ550 Euro, XJ750-X, and XJ900RK** USA & Canada only
    #40 XJ550L (1984) model, all XJ900RL, N/FN, and F models except USA or Canada
    #42.5 1979-81 XS1100 all models
    #45 1978 XS1100 models
    #47.5 XJ1100 models
    NOTES:
    * there are discrepancies between the parts manuals and the service manual information on the size of the XJ700-X pilot fuel jets; one source claims these carbs were equipped with #35 pilot fuel jets, while other sources claim a #37.5 size pilot fuel jet. Our research and experience shows that the XJ700-X models always used the #35 pilot fuel jets, while the XJ750-X models used #37.5 pilot fuel jets.
    ** there are discrepancies between the parts manuals and the service manual information on the size of the XJ900RK pilot fuel jets; one source claims these carbs were equipped with #37.5 pilot fuel jets, while other sources claim a #40 size pilot fuel jet.
    AIR JETS:
    - on Hitachi carbs, both the Main & Pilot AIR JETS are in the same size bores up top. The main air jet is in the "center" hole and is the lower numbered (smaller opening) jet.
    The pilot air jet is in the hole closest to the "front" of the carbs, front meaning nearest the cylinder head, and is the higher numbered (larger opening) jet.
    The rearmost hole is for the cover plate hold-down screw, if so equipped (some model carbs did not use the cover plate nor the
    hold-down screw).
    - on Mikuni carbs, the pilot air jet is located either under the diaphram cover, or on the bigger engines (700cc and up), in the carb throat, facing the airbox. The main air jet is always located in the carb throat, facing the airbox.
    Hitachi MAIN AIR JETS:
    #50: all XJ650 models except Police models.
    #55: all XJ650 Police (37G) models.
    #70: all XJ700 non-X models, XJ750RL Seca models, and XJ750E-II models.
    #80: all 1981-83 XJ750 North American models, 1981-84 XJ750 UK/European (11M) models, and XJ750 Police (24L and 37H) models.
    NOTE: the Haynes workshop manual for the XJ650 and XJ750 models has the incorrect placement noted for these air jets----the main air jet and pilot air jets are reversed in their picture and caption. Just remember that the main air jet goes directly above the main fuel jet, and is thus located in the "center" of the three holes in this area.
    Mikuni MAIN AIR JETS:
    All Mikuni BSxx series carbs do not have replaceable main jets. The main air jets on these models are in the carb throat, facing the airbox, and are a small, brass pressed-in tube that is not replaceable.
    But just in case anyone is wondering, here are the sizes of these non-removable main air jets in the various models:
    #45: XJ900 all RK, RL, N/FN, and F models
    #70: XJ550 all models, 1984-85 FJ600, and XJ650 Turbo models.
    #120: XJ700-X all models and XJ750-X all models*
    #140: XJ1100 models
    Hitachi PILOT AIR JETS:
    #195: all 1980-81 all XJ650 North American models, all 1982 XJ650RJ and RJC Seca, all 1980-82 XJ650 UK/European (4K0 and 4K1) models, and all XJ650 Police (37G) and XJ750 Police (24L and 37H) models.
    #205: all 1982-84 XJ650 Maxim North American models, 1982-84 XJ650 UK/European (11N) models, 1981-83 XJ750 Canadian models, and 1981-84 XJ750 UK/European (11M) models.
    #210: all XJ700 non-X models.
    #225: all 1982 XJ650 UK/European (14R) models, all 1981-83 XJ750 USA models, XJ750E-II models, and XJ750RL models.
    Mikuni PILOT AIR JETS:
    Pilot air jets on the Mikuni BSxx series carbs are replaceable and are located under the diaphram cover on all XJ550 models and XJ650 Turbo models, and in the carb throat, facing the airbox, on all XJ700-X, XJ750-X, XJ900RK, and XJ1100 models.
    #140 XJ700-X and XJ750-X models
    #145 XJ600 Seca II models (1992-98)
    #155 XJ550L (1984) models, 1983 XJ650 Turbo models (*see note below)
    #160 1984-85 FJ600 models, and all XJ900 all RK, RL, N/FN, and F models
    #165 XJ550 Maxim models (1981-83), 1982 XJ650 Turbo models (*see note below)
    #170 XJ550 Seca, XJ550 Euro, XJ650 Turbo*, and XJ1100 models
    #180 1978-79 XS1100 models
    NOTE: *the yamaha parts books reference the use of #165 pilot air jets for the 1982 XJ650 Turbo models, and #155 pilot air jets for the 1983 XJ650 Turbo models. Original carbs that we have explored have the #170 jets as shown above.
    AIR COMPENSATOR JETS:
    On Hitachi HSC-32 model carbs, there are also two air compensator jets----one on each side of the carb throat, facing the airbox----which are always a #36 size on those models which use them. The HSC-33 model Hitachi carbs, used on the XJ700 non-X models and XJ750E-II and XJ750RL models, do not use air compensator jets.
    Mikuni carbs also do not use air compensator jets, but, the main air jet and, on some models, the pilot air jet are located in this position.....in the sides of the carb throat, facing the airbox.
  6. chacal
    Entering The Kingdom of Clean: CLEANLINESS IS NEXT TO U-KNOW-WHAT-LI-NESS:
    Please be aware that quite a few----perhaps 60-70%----of "first time" carb cleaning/rebuilding efforts end in frustration and failure, and it's mainly due to NOT doing a thorough enough job of internally cleaning the tiny, miniscule fuel passages within the carb body. Although the air passages within the carb body are (relatively) huge, and thus do not normally accumulate fuel sludge and varnish, the fuel passages---particularly the pilot fuel circuit passages---are tiny beyond belief and even a "speck" of old varnish, grit, crud, etc. will cause problems.......in essence, that restriction becomes an "unintended" fuel metering jet, with very real consequences. This is why you want to get really, really anal in cleaning them. Many times, simply "dipping" or "boiling" the carbs out is NOT sufficient; you have to do all that AND mechanically probe (scour) these passages with tiny, fine wires to loosen such material, and THEN blast it away under pressure with carb cleaner, compressed air, etc.
    And you might have to repeat that process a few times to truly get them clean.
    And the fuel supply tubes and their passages inside the carb body.....which are rather large......these also get filled up with accumulated junk and debris, and thus also require mechanical intervention to loosen and remove such build-up.
    The absolutely worst outcome that can occur is that your "cleaning" efforts results in loosening, but not fully removing, such stuff within the internal passages; and once you get fuel and vacuum pressures working through the carbs again, all that gunk THEN starts moving again, and re-clogging things up (fuel circuits, float needle valves, etc.).
    So don't be fooled by having the VISIBLE areas of the carbs clean; although that's important, too, it's the invisible areas that matter most, and they had better be spotless, too.......or you'll probably soon be undertaking Carb Rodeo #2, after many frustrating hours spent trying to "tune" a set of carbs that no amount of tuning will ever set right!
    Here are some typical problem areas that are deserving of your special attention:
    - Clean the Emulsion Tubes thoroughly. This means inside and out, and every one of those tiny little holes along the bore must be completely clean, and whatever you do, DON'T ENLARGE THE SIZE OF ANY JET HOLES WHEN CLEANING THEM!
    - Remove every piece of rubber diaphram or o-ring and gasket material before soaking in carb dip, as carb dip will eat them up and make a gunky mess of things.
    - Clean all passages, both in the component parts and in the carb and bowl bodies, ultra-thoroughly: overnight carb dip, then ultrasonic, then wire brushes of various sizes and metal wire probes, then spray cleaners, then compressed air, then do it with spray and compressed air over and over again until you're DARNED CERTAIN THAT THE PASSAGE IS CLEAN. Then it wouldn't hurt to do it once or twice more, just to be sure.
    Hint: don't overlook those fuel supply tubes (in-between the carb bodies) and their seating area and fuel supply passages within the carb bodies.....they are usually full of junk!
    How will you be sure that your passages are "zestfully clean"? If compressed carb cleaner blown into a passage does not exit the other end of the passageway FREELY and FORCEFULLY, then that passage isn't clean.
    - Clean the Carb Bowl Starter Jet and its pickup tube thoroughly: overnight carb dip, then ultrasonic, then wire brushes of various sizes and metal wire probes, then spray cleaners, then compressed air, then do it spray and compressed air over and over again until you're DARNED CERTAIN THAT THIS PASSAGE IS CLEAN. Then it wouldn't hurt to do it once or twice more, just to be sure. This jet, because of it's non-removable nature and it's deep, almost-inaccessible location deep within a well down in the carb bowl, is the hardest-to-clean passage in the entire carb!
    And the failure to completely clean this starter jet will cause your choke to be barely or non-functional, and is the answer to the oft-asked question: "Why is my bike so hard to start?". In reality, assuming that the rest of your engine is in good condition (good battery, good compression, good coils, good plugs, and getting fuel), your bike should start up almost INSTANTLY even in sub-freezing temperatures.
    So how will you know when your starter jet is really, truly, zestfully clean? One of two ways, and I recommend using BOTH:
    a) shine a strong penlight or mini flashlight into the bottom of the bowl, where this jet passage "intake" is located. Look through the top of the bowl down into the jet passage "outflow" passage (this is the passage that the brass suction tube in the bottom of the carb body actually fits down into). Focus your eye carefully on the jet opening and make sure it's clean. P.S. it helps to do all this while in a darkened area....
    a) put the spray tip (you may have to gently shape the end of it to a fine point) of a can of carb or brake cleaner into the intake opening of the starter jet and let rip a spray. A STEADY AND POWERFUL STREAM OF FLUID SHOULD COME OUT OF THE OUTFLOW PASSAGE ON THE TOP OF THE CARB BOWL IF THE JET IS PERFECTLY CLEAN AND OPEN. I mean this stream will absolutely spit out a good 5-10 feet. If the stream isn't powerful and laser-like precise coming out of the jet, then the jet isn't zestfully clean.....
    By the way, when using the spray-stream method of checking the jet, don't even THINK of putting your eye or face anywhere even NEAR the jet outflow path, unless you'd like a painful and potentially serious trip to the emergency room.
    This is what you'll want to see when you're done! (throttle-blip to Gamuru for the exceptional write-up and video!):
    http://xjbikes.com/forums/index.php?threads/8918
    - GENTLY polish the Vacuum Piston with 1000-grit or finer sandpaper until it's smooth as a babies bottom. And always use some type of lubricating fluid while "polishing".....be it WD-40, brake fluid, cutting fluid, etc. Do NOT attempt to remove any "discoloration" from the vacuum piston, these pistons are actually aluminum with a very thin brass anondized outer coating, and if you remove this coating, Very Bad Things will happen. The discoloration is normal and not harmful in any way.
    - GENTLY hone and then polish the Vacuum Piston BORE in the carb body starting with 600-grit sandpaper and work your way up to 1500-grit or finer.........until it's smoother than a babies bottom. And always use some type of lubricating fluid while "polishing".....be it WD-40, brake fluid, cutting fluid, etc. You want the vacuum piston to be able to fall within this bore in a nearly "frictionless" manner, able to pass the infamous "CLUNK TEST" with flying
    http://xjbikes.com/forums/index.php?threads/1640
    and
    Now, you're probably thinking that we're going a little overboard about this whole cleaning and polishing routine-----and you could have a point there-----but you'll feel like kicking your own butt if you go to all this work, put the carbs back together, and then discover that it still doesn't run correctly because they're still dirty/clogged inside. AND THAT'S THE MAIN REASON WHY FIRST-TIME "REBUILDERS" DO ALL THE WORK AND STILL HAVE CARB PROBLEMS----because they didn't really take the time, and make the effort, to get those carbs INTERNALLY "operating-room clean".
    OPTIONS FOR CARB BOWLS AND BODIES BEFORE FINAL INTERNAL PASSAGE CLEANING:
    The carb bodies are an aluminum alloy, while the carb bowls (most of them) seem to be a more pure aluminum or magnesium. Carb cleaner "dip" and ultrasonic cleaner solutions may "stain" these metals and make it a dark grey color, perhaps even with some runny, ruddy "streaking". If you want them to look like new, here's what you do:
    a) glass bead blast them. This is has the unpleasant side-effect of REALLY clogging up all the tiny passages, so an unbelievably thorough cleaning is necessary afterwards. Better to plug up all the internal passages (screw a carb hat on top, and a bowl onto the bottom, and tape/plug up as many internal access openings as possible before doing this). However, they will be REALLY bright once done, and with a velvety finish.
    NOTE: do the carb dip and ultrasonic cleaning BEFORE you blast them, or they'll just turn dark grey again!
    After blasting, you'll be cleaning the carbs with carb or brake cleaner and compressed air ONLY, in order to prevent staining them again.
    b) metal shot tumble the bodies. In an industrial tumbler. Not a home version that you buy at Harbor Freight for $49.95. It will take 45 days of tumbling per carb body to do it that way. Find an industrial metal processing place in your town and have them tumbled with the proper size metal shot and, after about an hour or so, they'll come out looking almost like they've been chrome-plated. Price vary, locally we can get a complete set done for about $95 down here, slightly less if multiple sets are done at the same time. P.S.: by "industrial" we mean a tumbler that's about 12 feet in diameter and uses 440V 3-phase electrical service to run, and shakes the whole 10,000 square-foot warehouse room that it's in.
    P.S.S.: we use custom-made passage block-off plates and rubber plugs of the appropriate sizes inserted into all "blind" screw and passage holes before tumbling, so that no metal shot can get up into such passages or holes, cause if they do, you'll never get them out, and you will hate yourself forever for allowing such a mistake to occur.
    NOTE: do the carb dip and ultrasonic cleaning BEFORE you tumble them, or they'll just turn dark grey again!
    - If you want to PROTECT your blasted or tumbled carbs afterwards, use some fuel-resistant clear coat. Allow for three coats with dry time in-between. So plan on a day of spray time.
    - If you're going this far, you might as well replace or re-plate your chrome carb hats. And re-plate or spray "gold cad" paint on your brackets, throttle arm levers, etc. Zinc cad (silver) spray works great on upper and lower rack bars, starter circuit finger levers, etc.
    - If you do all of the above your carbs will look so great upon re-assembly that you will probably want to go to an art supply store and get a shadow box and permanently mount them in there and display them on your mantle, etc. You can then buy another set of used carbs off eBay and rebuild them for daily use on your bike..........
  7. chacal
    The Few Commandments: RE-ASSEMBLY AND RESURRECTION:
    Rule #1: never, EVER rush.
    Rule #2: use anti-seize on all bolts during re-assembly, except for upper and lower rack bolts, which use semi-permanent (purple) thread locking compound.
    Use anti-seize on all bolts, screws, etc. during re-assembly.
    USE ANTI-SEIZE ON ALL BOLTS, SCREWS, ETC. DURING RE-ASSEMBLY.
    USE ANTI-SEIZE ON ALL BOLTS, SCREWS, ETC. DURING RE-ASSEMBLY!
    Rule #3: use 100% pure Silicone Grease (and NEVER, EVER A PETROLEUM-BASED GREASE) to hold o-rings and the vacuum piston diaphram in place during re-assembly.
    The Rest of the Rules:
    - Do not over-torque anything.
    What Goes Where?:
    Well, we certainly hope that you took our earlier advice----the one about taking pictures, or notes----about what items go where before you took the carbs apart. But if not, here are some guidelines about where most of the brackets and clips are located. Remember, carbs are number # 1 thru #4 starting on the left (clutch lever) side of the engine, and "inner" refers to the side of the carb that is closer to the bike's centerline:
    Hitachi HSC32 carbs (all XJ models with Hitachi carbs except XJ700 air-cooled):
    #1 inner rear: fuel line bracket
    #2 inner rear: vacuum line clip
    #3 inner front and rear: throttle cable bracket
    #4 inner front and rear: choke cable bracket
    NOTE: clutch cable clip is located on upper rack bracket, #3 carb, outer screw position.
    Hitachi HSC33 carbs (all XJ700 air-cooled models):
    #1 outer front and rear: decorative end cap
    #2 inner rear: fuel line bracket
    #2 inner front: vacuum line wire clip
    #4 outer front and rear: decorative end cap
    NOTE: vent hose clip is located on upper rack bracket, #1 carb, outer screw position.
    Mikuni BS28 carbs (all XJ550 models):
    #1 forward inner and outer: choke cable bracket
    #2 inner front and rear: throttle cable bracket
    #3 inner rear: fuel line bracket
    Mikuni BS30 carbs (all XJ650 Turbo models):
    #1 inner rear: vacuum pressure sensor line clip
    #2 inner rear: fuel line clip
    #3 inner front and rear: throttle cable bracket and fuel pressure regulator L-bracket
    #3 outer front and rear: choke cable bracket
    Mikuni BS33 carbs (all XJ700 and XJ750 water-cooled models):
    #4 inner rear: fuel overflow hose clip bracket
    NOTE: fuel hose clip is located on upper rack bracket, #2 carb, outer screw position, or, #3 carb, inner screw position.
    Mikuni BS35 carbs (all XJ900RK models):
    NOTE: XJ900 non-North American models and other rest-of-the-world models which use the later BS36 style Mikuni carbs may have differing placements of the various clips.
    #2 outer rear: fuel line bracket
    NOTE: some models place the fuel line clip on the upper rack bracket, #2 outer screw position.
    #2 inner rear: vaccum line clip
    NOTE: some models do not use this clip.
    Mikuni BS34 carbs (all XJ1100 models):
    #1 inner front and rear: fuel distribution vacuum pod mounting bracket
    #4 outer front: clutch cable clip
    The Vacuum Piston and Diaphram:
    - When you re-install the vacuum piston Diaphram into it's bore, please note that the entire outer edge of the diaphram ha a round "bead" that sits within a machined recess on the top of the carb body. Over time, the diaphragms can shrink a small amount, and thus the edges of the diaphram will try to "pull out" of this recess while you are installing the spring and the chrome cover (or "hat"). A good way to prevent this from happening is to smear a bead of 100% silicone grease (and never any petroleum-based product, which will attack the rubber) into that groove, which will act as a "glue" and prevent the lip from withdrawing.
    Also, notice that the outer edge of the diaphram has a small half-circle LOCATING TAB that fits into a matching recess on the carb body, and make sure that you align that tab with the recess.
    The Idle Mixture Screw Settings:
    - Installation and initial setting of the Idle Mixture Screws:
    NOTE: idle mixture screws are also referred to as "pilot mixture screws" or "pilot screws".
    If you've never delved into the guts of your carburetor idle mixture screw port, it can sometimes be confusing. Here's the playbook for this critical area:
    If we were looking at a cut-away of the carb body/idle mixture screw bore, the order of parts, from top to bottom, would be:
    ^ TOP or UP ^
    e) the anti-tamper cap.
    d) the idle mixture screw.
    c) the tension spring.
    b) the HCP896 spring seat washer.
    a) the HCP895 o-ring
    v BOTTOM or DOWN v
    What is mostly confusing is the order of the o-ring versus the spring seat washer....which goes in the hole first? The answer is that the HCP895 o-ring does. The HCP896 washer primarily acts as the lower "seat" for the HCP6573 tension spring, while also keeping the o-ring firmly and securely in place.
    The initial setting of these screws is as follows:
    * 1980-81 XJ650 Maxim and Midnight Maxim, and XJ650RJ Seca Hitachi carbs with the coarse-threaded idle mixture screws: 1-3/4 to 2 full turns out from their fully closed (their fully seated, or "gently bottomed") position.
    * All Hitachi carbs (other than the above) which will have the fine-threaded idle mixture screws: 2-1/2 to 3 full turns out from their fully closed (their fully seated, or "gently bottomed") position.
    * All Mikuni carbs: 2-1/2 to 3 full turns out from their fully closed (their fully seated, or "gently bottomed") position.
    The Floats and their Pins:
    - Make sure that you re-install the Floats in their correct orientation.......believe it or not, it's easy to install them "upside down"!
    And of course, as per the previous discussion on the issue with the dis-assembly of the float pins, be ultra-careful when re-installing them, as you don't want to be this far along in your rebuild process and pop off one of those float pillar arms!
    The Bench-Synch Process:
    The bench synch process is great for getting the bike STARTED UP and running (even if poorly) after having had the carbs apart, allowing the motor to be started and running just well enough (which may mean: barely running, at all) so that you will have the opportunity to do a proper "running" or "real synch", along with the associated twiddling, fiddling, and setting of the idle mixture screws, idle speed screw, etc.
    BENCH SYNCH: Get your motor runnin'.......
    REAL SYNCH: Head out on the highway, lookin' for adventure, and whatever comes our way, blah-blah-blah, etc.
    - So make sure you Bench-Synch the carbs after re-assembly. This merely means that you adjust the "synch screws" on the carb throttle shaft end brackets so that you get an equal amount of butterfly valve opening (visible light passage) from each carb. This process allows the bike to start up easily after the carbs are re-installed onto the engine, and is NOT part of the further carb tuning steps that you'll need to take to actually "synch" and tune your carbs.
    The amount of light or "gap" isn't absolutely critical, but what is critical is that whatever gap is achieved is fairly equal on all four carbs. Whether you use a paper clip, a matchbook cover, a business card, or whatever.......it's not the amount of the actual gap (within reason!) that's important, it's that whatever gap is achieved needs to be nearly equal on all the carbs.
    But BEFORE you Bench Synch:
    If you have removed the butterfly valves (for whatever reason), then while reinstalling the butterflies, hold the carb up to a light source and look through it. The butterfly valve mounting holes are slotted so that the butterfly position can be fine-tuned. Assemble with the screws very lightly tightened, then hold the carb up to the light so you are looking through the throat. Adjust the butterfly valves so they make a light-proof seal all the way around it's circumference in the throat.
    If you can see light, then air will leak past at idle AND the butterfly will probably bind in the throat when things get up to operating temperature. It cannot be stressed enough that the butterfly must seat fully when allowed to close gently under spring pressure without any additional force. NOTE: if in the rack, the #3 carb must have the idle stop screw fully backed off so it does not prevent closing).
    Finally, tighten the screws fully and recheck to make sure they didn't move!
    NOTE: do not confuse the Idle Speed Adjustment Screw----that's the big huge one, facing to the "rear" of the bike, dead-center in-between the center two carbs----with the small "Synch Screws which control the at-rest throttle shaft rotational position, and thus the (butterfly) throttle valve opening positioning. These "synch screws" are on the throttle shaft end brackets, have a phillips-drive head, and are extremely fine-threaded little beats (the fine threading is what makes tiny adjustments possible), and only three of the four carb shaft end brackets have these screws (the #2 carb doe not have such a screw).
    Float HEIGHT sets the Fuel LEVEL:
    - When it comes time to Set the Float Height and thus the Fuel Level within the carb bowls, our advice is to get all the proper tools and fixtures ready, and then bribe someone who knows how to do it to come over and let them do this task for you!
    It's not rocket science, but it sure can be a messy, pain-in-the-butt, trial-and-error procedure.......especially if this is going to be your first fuel-level rodeo.
    If that's not possible, then read the manual and proceed accordingly. But please take the time to set the fuel levels correctly, not just by the float height measurements, but via the fuel level "sight tube gauge" method-----as the proper fuel level in the bowls is a critical issue in whether the carbs perform properly or not. NOTE that the "float height" measurement is just a "shortcut" method used to try to acquire the correct "fuel level" measurement, as it is the fuel level measurement and specification that must be met in order to insure that the carbs perform properly:
    * Fuel levels that are too low results in a lean mixture.
    * Fuel levels that are too high results in a rich mixture.
    In order to achieve the proper fuel level.....as measured by the "clear tube method" outlined in the service manuals......there obviously will be some particular "float height" that will achieve that FUEL LEVEL. But that actual float height can vary between various carbs due to a number of factors; for example, in the case of the Hitachi carbs, it also depends on which set of float valves and needles were originally installed by Hitachi (we've seen three different types in original carbs) AND which replacement style of needles and seats that you purchased. The factory specified "float height" is for an original carb, using the original float needle seats and valves, which may no longer be available for your bike.
    The float height determines what the fuel level within the bowl will be (since the float height determines when the float valve needle assembly "cuts off" fuel flow from the gas tank into the carb bowl), and thus an adjustment to the float height is how you adjust the fuel level. The float height is adjusted by very small amounts of bending the float TANG ARM on the float supporting structure. This tang is the central metal "arm" that contacts and supports----via the little float needle clip - hook (on most models)----the float needle itself. You would bend this tang down (away from the needle) to raise the float height (and thus raise the fuel level in the bowl), or you would bend this tang upward (towards the needle) to lower float height (and this will lower the fuel level in the bowl).
    Please note that although you typically are messing around with the float height and adjusting that tang WHILE THE CARBS ARE UPSIDE DOWN----so you can easily access the floats----the descriptive actions such as "downward" and "upward" that you may read about in various manuals are describing such directional movements in relation to the normal orientation of the carbs as on the bike! THIS CAN BE INCREDIBLY CONFUSING WHEN YOU FIRST START PERFORMING THIS ADJUSTMENT PROCESS!!!
    Also note that the fuel level check (with the sight tube gauge) must be done with the carbs oriented in the same manner as if they were installed on the bike, meaning perfectly level from side-to-side (you'll want to use a bubble-glass level to make sure they are perfectly level) and completely "vertical". NOTE: the "vertical" orientation confuses some people, as the carbs, when installed on the bike, are actually tilted a bit forward from true vertical in the normal riding position. However, when checking the fuel level with the sight tube gauge, the carbs should be in both a horizontally and vertically level orientation.
    Here are some other useful hints, culled from the factory service manual, regarding how to prepare yourself for the correct check of the float height measurement:
    - Hold the carb in an upside down position.
    - Incline the carb at 60-70-degrees so that the end of the float valve does not hang down as a result of the float weight.
    - Measure the distance from the mating surface of the chamber without the gasket in place, to the top of the float.
    - NOTE: the float should be just resting on, but not depressing, the spring loaded inlet needle.
    Well, okay! Now, although you may not have noticed it immediately, there is a very important and very cryptic passage in the above set of instructions, which is this:
    "Measure the distance from the mating surface of the chamber without the gasket in place, to the top of the float."
    The "mating surface" is, of course, the bottom of the carb body (where the float bowl gasket would be located) but without the gasket in place.......check. But the next part......the "to the top of the float" bit......well, that's a bit more mysterious, because:
    a) of course, as it with the "direction warning" issued earlier, the "top of" the floats, when viewed with the carbs being upside down in your hands (which is the only way to perform such measurements), is actually the physical bottom of the floats!
    Told you this would get interesting.......
    But that little detail aside, now we have to explore the more challenging part of that statement, which is "what and where, exactly, is the "top" of this bottom of the float?"
    This simple question is, unfortunately:
    a) not so easy to answer, and.....
    b) varies by which carb model you are holding, upside down, in your hands and trying to measure..........
    For some models, the information as to exactly WHERE to perform this measurement at the float is either not known, or incredibly confusing.....and the factory service manuals are not much of a help in this regard, what with their tiny, grainy images. It seems as though Yamaha wanted people to focus on the fuel level setting (of course, as that is the end result you're actually shooting for), and figured it wasn't worth the trouble or effort to go over the float-height-measurement procedures necessary to achieve that--------rather, they tell you what fuel level measurement to acquire, and then tell you to just "bend that tang arm" and re-measure the fuel level and just keep going back-and-forth until you get it right! And then do that messy, smelly, spill-gas-all-over-yourself with this trial-and-error procedure three more times.........
    Three Blind Carbs: See How It's Done:
    Because of all the considerations mentioned previously, and due to the importance of getting this job done once, and done correctly, the procedure that we suggest you follow is to work on achieving the proper FUEL LEVEL in any one carb.......so, install the needle and seat, install the float, fill the bowl with fuel, and measure the fuel level (although the factory gives a rather wide range of acceptable fuel level limits, such as 3mm +/- 1mm----in other words, anywhere from 2mm to 4mm----we feel that you should always strive to get that fuel level right in the center of the range (in the above example, right at 3mm).
    You'll do this by very slight bending of that central float tang arm (the one that the needle clip fits over) until you get the measured fuel level (drain and measure a couple of times, to be sure!) that it's correct.
    Now, since you know that this one carb fuel level is correct, and if you're using the same float seats and needles in all the other carbs, then simply measure the "float height" of this now known good carb.....and, you can "measure" that height in any way and at any point that you desire, preferably whatever measurement is the most consistent to perform and the easiest to see.......and then that becomes your "float height" for all of the other carbs, too. Just adjust the other float tang arms to achieve that same unique "float height", and you're done!
    BUT, I would still fill and measure each individual carb and check the fuel level, just to be sure, before you install them on the bike!
    The above may seem like a more time-consuming and "tedious" way of doing things, but it is the only way that we know of to make CERTAIN that your fuel levels are correct........rather than having a "correct" float height.......and as we stated earlier, it is the fuel level that is the end result that you're seeking, not any particular float height (except for the necessary float height needed to get to that proper fuel level, of course!).
    The proper FUEL LEVEL is a vastly over-looked, but vitally important part of having your carbs perform properly, as improper fuel levels WILL result in either lean or rich fuel mixtures, and will most likely tempt you to try to "compensate" for such a situation by other, NON-NECESSARY and perhaps COUNTER-PRODUCTIVE changes in other circuits or carb settings, which may affect and degrade other areas of the engine performance. IT IS ALWAYS BEST TO ADDRESS AND SOLVE THE "ROOT" PROBLEMS (or, to put it another way, to FOLLOW PROPER PROCEDURES AND ACHIEVE PROPER SETTINGS) in all of the basic areas.
    This method will allow you to actually save time, money, effort, and achieve more accurate, consistent, and reliable results!
    Fuel Level Cheat Sheet:
    Hitachi all HSC32 series models:
    NOTE: all of the following models used HSC32 carbs:
    XJ650 Maxim, Midnight Maxim, XJ650RJ Seca (non-turbo), XJ650 Euro all use HSC32 carbs (various versions)
    XJ750 all USA 1981-83 models use HSC32 version 5G200 (Seca) and 15R00 (Maxim and Midnight Maxim)
    XJ750 all Canadian 1981-83 models use HSC32 version 5H200 (Seca) and 15T00 (Maxim and Midnight Maxim)
    XJ750 UK/Europe 11M models, XJ750 Police models 24L and 37H use HSC32 version 5N100
    -Fuel level measured via the clear-tube gauge: 3mm +/- 1mm (.12 +/- .04 inches)
    Hitachi HSC33 series (XJ700 air-cooled models):
    -Fuel level measured via the clear-tube gauge: 1.0mm +/- 1mm (.039" +/- .039")
    Hitachi HSC33 series (XJ750E-II model):
    -Fuel level measured via the clear-tube gauge: 5.0mm +/- 1mm (.197" +/- .039")
    Hitachi HSC33 series (XJ750RL models):
    Mikuni BS28 (all XJ550 except XJ550L):
    -Fuel level measured via the clear-tube gauge: 2mm +/- 1mm (.08 +/- .039 inches)
    Mikuni BDS26 (USA all 1992-98 XJ600 Seca II):
    USA: 4 - 6mm (.016 - 0.24”) below float chamber line
    -Float height:
    USA: 6.2 - 8.2mm (0.24 - 0.32”)
    Mikuni BDST28 (non-USA all 1992-98 XJ600 Seca II):
    1992-96 Canada and Australia: 3 - 5mm (0.12 - .0.20”) above float chamber line
    1992-95 UK: 3 - 5mm (0.12 - .0.20”) above float chamber line
    1996-98 UK: 8.5 - 9.5mm (0.34 - .0.37”) above float chamber line
    -Float height:
    1992-96 Canada and Australia: 11 - 13mm (0.43 - 0.512”)
    1992-95 UK: 11 - 13mm (0.43 - 0.51”)
    1996-98 UK: 8.8 - 10.8mm (0.35 - 0.42”)
    Mikuni BS32 (all XJ550L, 1984-85 FJ600, and 1984-87 / 1989-91 XJ600):
    Mikuni BS30 (all XJ650 Turbo):
    -Fuel level measured via the clear-tube gauge: 2mm +/- 1mm (.08 +/- .04 inches)
    -Float height: 21.0 +/- 0.5mm
    Mikuni BS33 (all XJ700-X and XJ750-X):
    Mikuni BS35 (all XJ900RK):
    -Fuel level measured via the clear-tube gauge: 5mm +/- 1mm (.20 +/- .04 inches)
    Mikuni BS36 (all XJ900F, FN, N, etc):
    Mikuni BS34 (all XJ1100 and 1980-81 XS1100):
    Mikuni BS34 (1978-79 XS1100):
    -Float height: 25.7mm +/- 1mm (1.012 +/- .04 inches)
    Okay, the fuel level measurement is done via the clear-tube gauge method, and this tube should be positioned along the SIDE of the carb body being measured (not along the front or the back of the carb body), and along the centerline of the carb body, basically in-line to where the main fuel jet would be located. The fuel level is most critical to the performance of the main fuel jet, so that is where the fuel level in the bowl should be measured at.
    The actual fuel level measurement (which reads something like "3mm +/- 1mm") refers to the level that the fuel in the tube is located below the bottom edge of the carb body where the carb bowl is bolted to the carb body. NOTE: as fluids like to do, the "top" of the fluid level in the tube will not form a perfectly straight "top" in the tube......instead, it will be somewhat "u-shaped". The proper measuring point is the lowest level of the fluid in the tube.
    Whew! I told this is a tedious process; luckily, once you get the float heights (and thus the fuel levels) set correctly, it doesn't change very much over time, so you don't have to go through this procedure very often, or maybe even ever again!
    Unless...........something occurs that physically bends that float tang arm, and thus changes the float height and thus the fuel level in the bowl. Besides "time" and "metal fatigue", the main culprit that can bend this tang arm is excessive pressure on this arm, typically caused by a stuck, seized, or jammed float needle, which holds the needle open and lets fuel keep coming into the bowl....thus the fuel level rises, pushing the float upwards, and the tang arm exerts excess pressure against the float needle, and ends up bending the tang arm due to such excess pressure.
    Float needles can become stuck due to defects in the needle itself, the cylinder bore of the needle seat, or perhaps a piece of gunk from your fuel tank made it through the filters and gets lodged into the needle seat, seizing the needle open or preventing the needle from ever closing fully against the seat. Then fuel keeps flowing into the bowl, the float level rises, excess force is applied to the tang arm, etc. A worn needle tip.....which may also prevent full closure of the seat opening.....can also cause high fuel levels.
    Also, please note that on models on which the float needle has a spring-loaded "tip", that this tip should NOT depressed when setting the floats, nor should it be seized open nor closed. That needle tip is a "shock absorber" and does not and should not be depressed----at all----when setting the float heights. If that spring-loaded tip becomes seized shut, then the floats will have to be set very "high" before they ever rise far enough to exert enough pressure on the collapsed tip to force the needle closed, and thus will cause bowl flooding.
    So: if your carbs flood, then the tang arm can bend, and even if you solve the flooding problem, you may find that after such an event you may have a continual fuel level problem.
    Moral of the stories: check your fuel levels periodically (you can do this with the carbs still on the bike) and adjust them into specification if they are not!
    Okay, if you've read all of the above and are not fully confused, well, it means that you just haven't been paying enough attention..........
  8. chacal
    The Book of Numbers: FASTENER TORQUE VALUES:
    NOTE: upper & lower rack screws and butterfly-to-throttle shaft retaining screws use semi-permanent thread-locking fluid; all other fasteners use anti-seize.
    HOWEVER:
    a) make sure anti-seize compound doesn't get into a passage where it will undo all your careful attention to cleanliness, and....
    b) disregard the torque specifications of the fasteners. I draw your attention to Yamaha's standard passage regarding torque specs (included in every Yamaha service manual):
    "Unless otherwise specified, torque specifications call for clean, dry threads. Components should be at room temperature."
    If the specification is for lubed threads (and anti-seize grease is a "lubricant") on a particular bolt, then the Yamaha torque chart will have a little oil can symbol beside it.
    c) therefore, applying full (dry spec) torque to a lubed bolt may well strip your expensive aluminum casting or brass jet. As a rule of thumb, reduce the specified torque by at least 10% if you have applied anti-seize compound to the threads of the bolt.
    Hat Screws:
    none given, and not much is needed! Become familiar with the concept of the word "snug".
    Plastic slide piston needle retaining nut:
    none given, use "snug".
    Enrichment (starter) circuit brass fitting:
    40 ft-lbs (???---that's what the manual states, but it sure seems excessive!)
    Float seat:
    22 ft-lbs (???---again, that's what the manual states, but it sure seems excessive!)
    Jets:
    Pilot fuel jet: 3.5 - 4.5 ft-lbs.
    Main fuel jet: 3.5 - 4.5 ft-lbs.
    Air compensator jets: 4.5 ft-lbs
    Pilot air jet: 4.5 ft-lbs
    Main air jet: 4.5 ft-lbs
    Air jet cover plate mtg: none given.
    Upper rack mounting screws: 3.5 - 4.5 ft-lbs.
    Lower rack mounting screws: 4.5 ft-lbs
    Bowl-to-carb mounting screws: 3.5 - 4.5 ft-lbs.
    Bowl fuel drain screw: 4.5 ft-lbs
    Throttle shaft nuts: none given.
    Fuel Tank and Petcock Torque Values, Just For Fun:
    Petcock mounting screws to tank: 4.5 ft-lbs
    Gas cap mounting screw to tank: 3.5 - 4.5 ft-lbs.
    Sender unit to tank: 4.5 ft-lbs
    Tank emblem screws: none given
    The Book of Job: QUALITY IS ALWAYS JOB #1:
    TOOLS NEEDED:
    * time.
    * patience.
    * paper, pen, and a notebook.
    * ZIP-LOCK BAGGIES OF VARIOUS SIZES.
    * a clean, semi-uncluttered, well-lit and well-ventilated area to work in.
    * a strong flashlight.
    * a magnifying glass.
    * a digital-cam would be a huge bonus.
    * haynes or clymer workshop manual.
    * yamaha service manual.
    * xjbikes.com threads already bookmarked.
    * paper towels and shop rags.
    * access to ultrasonic cleaner.
    * access to tumbler or glass-bead blaster.
    * Flat & phillips head screwdrivers, various sizes. JIS phillips-drive screwdrivers should be used.
    * wire tube brushes, various sizes, for cleaning internal passages.
    * brass & steel wire toothbrushes, for cleaning the outside surfaces.
    * mini, mini-plus, or man-sized passage cleaning wires set.
    * Engraving pen or punch to mark carb bodies, bowls, throttle shafts, etc. Ink won't do, even "sharpie" style permanent ink markers, since carb dip and spray cleaners will remove them.
    * Hammer.
    * METRIC open-end wrench and socket assortment
    * pry bar or soft mallet.
    * channel locks, vise grips, pliers---needlenose and otherwise.
    * dental picks.
    * mini drill bit for carb bowl starter jet cleaning.
    * e-z outs and/or LH drill bits.
    * small pencil torch or a heat gun.
    * vise.
    * drill & drill bits.
    * float height ruler or gauge.
    * fuel level sight tube.
    * a 6" or 12" bubble level.
    * a carb rack Alignment Plate, necessary as you re-assemble the individual carbs together and tighten the upper and lower rack bar screws. The four carbs must be placed on a perfectly flat surface as the screws are tightened or mis-alignment will occur, and life gets really un-fun if that occurs.........
    * 100% silicone grease. Any petroleum-based grease will attack rubber.
    * anti-seize fluid.
    * semi-permanent (purple) thread locker fluid.
    * brake or carb cleaner (and lots of it).
    * carb dip or access to it.
    * Fine sandpaper, automotive paint grade, 400-, 600-, 800-, 1000+ grit.
    * restoration paints and coatings, if you are so inclined to do such detailing.
    * synch sticks.
    * YICS block-off tool, if your bike is has a YICS passage.
    * YICS port passage cleaning tool, if your bike is has a YICS passage.
    * gun brushes or similar.
    * gun cleaner or similar.
    * colortune plug.
    PARTS NEEDED:
    Carb rebuild:
    * throttle shaft seals (if you split the carbs from the rack).
    * fuel supply tube o-rings (if you split the carbs from the rack).
    * float needle seat rebuild kit (seat, needle, clip, seat washer).
    * bowl gaskets.
    * idle mixture washers & o-rings, screws if damaged.
    * jets, if damaged or incorrectly sized.
    * carb bowl fuel drain screws.
    * new replacement carb hardware (screws, etc.)---now is the time to upgrade to stainless steel and/or allen-head fasteners if so desired!
    Valve shim replacement:
    * shims as needed.
    * shim bucket tool.
    * feeler gauges, .002" - .012" (inches, not metric!)
    * 19mm open end wrench.
    * valve cover gasket and end caps seals as needed.
    * valvecover bolt pressure washers.
    * glue for valve cover gasket.
    * valve cover gasket.
    * crankcase oil pump cover gasket.
    * small flat-bladed screwdriver or pointed pick tool.
  9. chacal
    Original Sins, a/k/a/ Carb Specifications Consolidated: THE CHEAT SHEET:
    Here are all the different stock carb specs (carb model numbers, jet sizes, tune-up info, etc.) consolidated into one happy little group of information, so you can print this out easily when you are working on your particular set.
    XJ550 Models:
    Years & Models: 1981-83 XJ550 Maxim North American models
    Carb Manufacturer: Mikuni
    Carb Series: BS28
    Carb Model ID: 5K500
    Main FUEL Jet Size: #112.5
    Pilot FUEL Jet Size: #35
    Main AIR Jet Size: #70 (non-removable, in carb throat)
    Pilot AIR Jet Size: #165
    AIR COMPENSATOR Jet Size: not used.
    Starter FUEL Jet Size: #35 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4GN
    Main needle JET Size: #O-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 2mm +/- 1mm (.08" +/- .039")
    Idle RPM's: 1,200 rpms
    Vacuum reading at idle: not specified
    Vacuum, allowable difference between cylinders, at idle: not given
    Although not part of your carbs, your valve clearances should be considered as part of your "intake system", so here are those specs, too. Note that valve clearances should be measured with the engine "cold", meaning 70-degrees Fahrenheit or less:
    Valve Clearance Intake: 0.11 - 0.15mm ( = 0.004 - 0.006")
    Valve Clearance Exhaust: 0.16 - 0.20mm (= 0.006 - 0.008")
    Years & Models: 1981-83 XJ550 Seca North American models
    Carb Series: BS28
    Carb Model ID: 4U800
    Pilot AIR Jet Size: #170
    Main jet NEEDLE ID: #4GZ11
    Years & Models: 1981-83 XJ550 Euro models
    Carb Series: BS28
    Carb Model ID: 4U900
    Pilot FUEL Jet Size: #37.5
    Main jet NEEDLE ID: #4GZ3
    Years & Models: 1984 XJ550L Maxim models
    Carb Series: BS32
    Main FUEL Jet Size: #105 (cylinders #1 & 2)
    Main FUEL Jet Size: #102.5 (cylinders #3 & 4)
    Pilot FUEL Jet Size: #40
    Pilot AIR Jet Size: #155
    Starter FUEL Jet Size: #42.5 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4CP7-3 (cylinder #2)
    Main jet NEEDLE ID: #4CP3-3 (cylinders #1, 3, and 4)
    Main needle JET Size: #N-8 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3mm +/- 1mm (.118" +/- .039")
    1984-85 FJ600 Models:
    Years & Models: 1984-85 FJ600 models
    Carb Series: BS32
    Carb Model ID: 49A00 non-California models
    Carb Model ID: 51K00 California models
    Main FUEL Jet Size: #105 non-California models
    Main FUEL Jet Size: #102.5 California models
    Pilot FUEL Jet Size: #35 according to Yamaha or 40 according to Clymer
    Pilot AIR Jet Size: #160
    Main jet NEEDLE ID: #4CP6
    Fuel Level in float bowls: 3mm +/- 1mm (.012" +/- .039")
    Vacuum at idle: 175mm +/- 5mm Hg (6.89 +/- 0.197" Hg or 23.3 +/- 0.667 kPa)
    Vacuum, allowable difference between cylinders, at idle: 10mm Hg (0.394" Hg or 1.33 kPa)
    Valve Clearance Intake: 0.11 - 0.15mm (= 0.004 - 0.006")
    1984-87 and 1989-91 XJ600 Models:
    Years & Models: 1984-87 and 1989-91 XJ600 models
    Carb Series: BS32
    Carb Model ID: 51J01 (1984)
    NOTE:
    Main jet NEEDLE ID: 51H (Germany) model used #4Cl8-3 needles on all four carbs
    Idle RPM's: 1,150 - 1,250 rpms
    1992-98 XJ600 Models:
    Years & Models: 1992-98 XJ600 Seca II models
    Carb Series: BDS26 (USA)
    Carb Series: BDST28 (Canada, UK, Australia)
    Carb Model ID: varies
    Main FUEL Jet Size: #102.5 (some non-North American models used #105 jets on the outer carbs and #102.5 jets on the center carbs)
    Pilot FUEL Jet Size: #17.5
    Main AIR Jet Size: 1.5 (USA)
    Main AIR Jet Size: 1.4 (1996-98 UK)
    Main AIR Jet Size: #70 (1992-95 UK and 1992-96 Canada and Australia)
    Pilot AIR Jet Size: #145 (most models; some 1996-98 Euro models used #130, #135, or #140 jets)
    Starter FUEL Jet Size: #20 (USA)
    Starter FUEL Jet Size: #47.5 (UK, Canada, Australia)
    Main jet NEEDLE ID: #4B10 (USA)
    Main jet NEEDLE ID: #5CT or #5CTZ (1992-95 Canada and Australia)
    Main jet NEEDLE ID: #4BC-12, -13, -14, or -15 (1996-98 UK)
    Main needle JET Size: the main needle JET is also known as the "power valve" or "emulsion tube"
    USA: ]: #O-4 (carbs 1 &4) and O-2 (carbs 2 & 3)
    1992-96 Canada and Australia: O-4
    1992-95 UK: O-4 or O-9
    1996-98 UK: O-0
    Float Height:
    Idle RPM's:
    USA: 1,200 - 1,400 rpms
    1992-96 Canada and Australia: 1,150 - 1,250 rpms
    1992-95 UK: 1,150 - 1,300 rpms
    1996-98 UK: 1,200 - 1,300 rpms
    Vacuum at idle:
    225 – 230mm Hg (8.86 - 9.06" Hg or 30 - 30.7 kPa) USA
    260 - 270mm Hg (10.24 - 10.63" Hg or 34.58 - 36.91 kPa) Canada and Australia
    260 - 270mm Hg (10.24 - 10.63" Hg or 34.58 - 36.91 kPa) most 1992-95 UK models
    220 - 230mm Hg (8.66 - 9.06" Hg or 29.26 - 30.59 kPa) 1993-95 UK CH and A models
    230mm Hg (9.06" Hg or 307 kPa) 1996-98 UK models
    Vacuum, allowable difference between cylinders, at idle: not specified
    Valve Clearance Intake: 0.11 - 0.15mm (= 0.004” - 0.006")
    Valve Clearance Exhaust: 0.21 - 0.25mm (= 0.008” - 0.010")
    XJ650 Models:
    Years & Models: 1980-1 XJ650 Maxim, Midnight Maxim, and XJ650RJ Seca USA models
    Carb Manufacturer: Hitachi
    Carb Series: HSC32
    Carb Model ID: 4H700
    Main FUEL Jet Size: #110
    Main AIR Jet Size: #50
    Pilot AIR Jet Size: #195
    AIR COMPENSATOR Jet Size: #36
    Starter FUEL Jet Size: #40 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-10
    Main needle JET Size: #3.2mm (the main needle JET is also known as the "power valve" or "emulsion tube").
    Idle RPM's: 1,050 rpms
    Vacuum at idle: 180mm Hg (7.09" Hg or 24 kPa)
    Vacuum, allowable difference between cylinders, at idle: 5mm Hg (0.197" Hg or 0.667 kPa)
    Years & Models: 1980-1 XJ650 Maxim, Midnight Maxim, and XJ650RJ and RJC Seca Canadian models
    Carb Series: HSC32
    Carb Model ID: 4H800
    Main jet NEEDLE ID: #Y-12
    Years & Models: 1982-3 XJ650 Maxim USA models
    Carb Series: HSC32
    Carb Model ID: 5N800
    Pilot AIR Jet Size: #205
    Years & Models: 1982-4 XJ650 Maxim Canadian models
    Carb Series: HSC32
    Carb Model ID: 5N900 or 5U900
    Pilot FUEL Jet Size: #43
    Years & Models: 1980-1 XJ650 4K0 and 4K1 models (UK/Europe)
    Carb Series: HSC32
    Carb Model ID: 4K000
    AIR COMPENSATOR Jet Size: unknown
    Main jet NEEDLE ID: #Y-11
    Years & Models: 1982-4 XJ650 11N models (UK/Europe)
    Carb Series: HSC32
    Years & Models: 1982 XJ650 14R models (UK/Europe)
    Carb Series: HSC32
    Pilot AIR Jet Size: #225
    Years & Models: 1982-3 XJ650LJ/LK Turbo Seca North American models
    Carb Series: BS30
    Carb Model ID: 16G00
    Main FUEL Jet Size: #127.5 (cylinders #1 & #4)
    Main FUEL Jet Size: #132.5 (cylinders #2 & #3)
    NOTE: the yamaha parts books reference the use of #125 main fuel jets. Original carbs that we have explored have the #127.5/#132.5 combination of jets as shown above.
    NOTE: the yamaha parts books reference the use of #165 pilot air jets for the 1982 models, and #155 pilot air jets for the 1983 models. Original carbs that we have explored have the #170 jets as shown above.
    Starter FUEL Jet Size: #30 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4DPS39
    Main needle JET Size: #O-6, #318 style (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 2mm +/- 1mm (.08 +/- .04 inches)
    Vacuum at idle: 185mm (7.28” Hg or 24.7 kPa)
    Vacuum, allowable difference between cylinders, at idle: +/- 10mm Hg (+/- 0.394" Hg or +/- 1.33 kPa)
    XJ700 Models:
    Years & Models: 1985-6 XJ700 air-cooled models
    Carb Series: HSC33
    1985 Carb Model ID: 1FG00 (N models) or 1JJ00 (NC models)
    1986 Carb Model ID: 1NH00 (S models) or 1NK00 (SC models)
    Main FUEL Jet Size: #107
    Pilot FUEL Jet Size: #36.5
    Pilot AIR Jet Size: #210
    Starter FUEL Jet Size: #36 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-20
    Fuel Level in float bowls: 1.0mm +/- 1mm (.039" +/- .039")
    Vacuum at idle:
    Vacuum, allowable difference, at idle:
    Years & Models: 1985 XJ700-X XN/XNC water-cooled USA models
    Carb Series: BS33
    Carb Model ID: 1AA00 (XN models) or 1FL00 (XNC models)
    *Main FUEL Jet Size: #100 or #105
    **Pilot FUEL Jet Size: #35 or 37.5
    Main AIR Jet Size: #120 (non-removable, in carb throat)
    Pilot AIR Jet Size: #140
    Main jet NEEDLE ID: #5FZ82 (all except XNC model)
    Main jet NEEDLE ID: #5FZ83 (XNC model)
    Main needle JET Size: #Y-2 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Fuel Level in float bowls: 3.0mm +/- 1mm (.118" +/- .039")
    Vacuum, allowable difference between cylinders, at idle: below 5mm Hg (below 0.197" Hg or below 0.667 kPa)
    NOTES:
    * there are discrepancies between the parts manuals and the service manual information on the size of the main fuel jets; one source claims these carbs were equipped with #100 main fuel jets, while other sources claim a #105 size main fuel jet.
    ** there are discrepancies between the parts manuals and the service manual information on the size of the pilot fuel jets; one source claims these carbs were equipped with #35 main fuel jets, while other sources claim a #37.5 size main fuel jet.
    Valve Clearance Intake: 0.11 - 0.20mm (= 0.004" - 0.008")
    Valve Clearance Exhaust: 0.21 - 0.30mm (= 0.008 - 0.012")
    Years & Models: 1986 XJ700-X XS/XSC water-cooled USA models
    Carb Series: BS33
    Carb Model ID: 1NW00 (XS models) or 1LT00 (XSC models)
    XJ750 Models:
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca USA models
    Carb Series: HSC32
    Carb Model ID: 15R00 (Maxim, Midnight Maxim)
    Carb Model ID: 5G200 (Seca)
    Main FUEL Jet Size: #120
    Main AIR Jet Size: #80
    Main jet NEEDLE ID: #Y-13
    Years & Models: 1981-3 XJ750 Maxim, Midnight Maxim, and Seca Canadian models
    Carb Series: HSC32
    Carb Model ID: 15T00 (Maxim, Midnight Maxim)
    Carb Model ID: 5H200 (Seca)
    Main jet NEEDLE ID: #Y-14
    [Vacuum at idle: 185mm (7.28” Hg or 24.7 kPa)
    Years & Models: 1981-4 XJ750 11M UK/Europe Seca models
    Carb Series: HSC32
    Carb Model ID: 5N100
    AIR COMPENSATOR Jet Size: unknown if used.
    Years & Models: 1983 XJ750E-II models
    Carb Series: HSC33
    Carb Model ID: 29R00
    Main FUEL Jet Size: #105 (cylinders #1 & #4)
    Main FUEL Jet Size: #102 (cylinders #2 & #3)
    Starter FUEL Jet Size: #43 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #Y-17
    Fuel Level in float bowls: 5mm +/- 1mm (.197" +/- .039")
    Years & Models: 1984 XJ750RL Seca models
    Carb Series: HSC33
    Carb Model ID: 41Y00
    Main FUEL Jet Size: #106
    Pilot FUEL Jet Size: #41
    Main jet NEEDLE ID: #Y-18
    Fuel Level in float bowls: 1mm +/- 1mm (.039" +/- .039")
    Years & Models: 1985-6 XJ750-X XN/XS water-cooled Canadian models
    Carb Series: BS33
    1985 Carb Model ID: 1FL00 (XN models)
    1986 Carb Model ID: 1MY00 (XS models)
    Vacuum at idle: 180mm Hg +/- 5mm Hg (7.09" Hg +/- 0.197" Hg or 24 kPa +/- 0.667 kPa)
    XJ900 Models:
    Years & Models: 1983-4 XJ900RK/RL and XJ900P Police models
    Carb Series: BS35
    Carb Model ID: 31A00
    Pilot FUEL Jet Size: #40 NOTE: some sources claim #37.5
    Main AIR Jet Size: #45 (non-removable, in carb throat)
    Starter FUEL Jet Size: #32.5 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #4HZ22 (900RK) or 4HZ26-3 (900RL and Police)
    Main needle JET Size: #Y-0, style #318 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Float Valve Seat Size: 2.0mm, uses a longer float valve needle and the needle is not clipped to the float arm.
    Fuel Level in float bowls: 5.0mm +/- 1mm (.197" +/- .039")
    Idle RPM's: 1,100 rpms
    Vacuum at idle: 225 - 235mm Hg (8.86 - 9.25" Hg or 30 – 31.3 kPa)
    Years & Models: XJ900 model 58L
    Carb Series: BS36
    Carb Model ID: 58L00
    Main FUEL Jet Size: #107.5
    Main jet NEEDLE ID: #5FZ62-3
    Float Valve Seat Size: 2.3mm, uses a shorter float valve needle and the needle is clipped to the float arm.
    Fuel Level in float bowls: 5.0mm +/- 1mm (.118" +/- .039")
    Vacuum at idle: 215 - 225mm Hg (8.46 - 8.86" Hg or 28.7 – 30 kPa)
    Years & Models: 1984-90 XJ900 models 2HL, 3NG1, 3NG2
    Carb Series: BS36
    Carb Model ID: various
    Years & Models: 1991-4 XJ900 models 4BB1, 4BB2
    Carb Series: BS36
    Main jet NEEDLE ID: #5FZ10-3
    Float Valve Seat Size: unknown.
    XJ1100 Models:
    Years & Models: 1982 XJ1100 models
    Carb Series: BS34
    Carb Model ID: 10M00
    Pilot FUEL Jet Size: #47.5
    Main AIR Jet Size: #140 (non-removable, in carb throat)
    Starter FUEL Jet Size: #25 (non-replaceable, in float bowl)
    Main jet NEEDLE ID: #5GLZ-34
    Main needle JET Size: #X-2 (the main needle JET is also known as the "power valve" or "emulsion tube").
    Vacuum at idle: not specified
    Vacuum, allowable difference between cylinders, at idle: below 10mm Hg (below 0.394" Hg or below 10 kPa)
    Valve Clearance Intake: 0.11 - 0.15mm (= 0.004" - 0.006")
    Valve Clearance Exhaust: 0.21 - 0.25mm (= 0.008 - 0.010")
    1978-79 XS1100 Models:
    Years & Models: 1978-79 XS1100 models
    Carb Series: BS34-11
    Carb Model ID: 2H7-00 (Standard models)
    Carb Model ID: 3H3-00 (Special models)
    Main FUEL Jet Size: ****
    Pilot FUEL Jet Size: ***
    Pilot AIR Jet Size: **
    Starter FUEL Jet Size: #40 (1978)
    Starter FUEL Jet Size: #32.5 (1979)
    Main jet NEEDLE ID: #5GZ6/3
    Float Height: 25.7mm +/- 1mm (1.012 +/- .04 inches)
    Idle RPM's: 950 - 1,050 rpms (1978)
    Idle RPM's: 1,050 - 1,150 rpms (1979)
    ** the Yamaha service manual specifies the #180 size pilot air jet for all 1978-79 models, while the parts books specify the #210 size for 1978 models and the #180 size for the 1979 models.
    **** depending on model of carbs used, these bikes could have been equipped with either the #130, #137.5, or the #140 main fuel jets. The #137.5 size seems to be what was equipped from the factory on North American models.
    *** although all 1979-81 XS1100 models uses the same #42.5 size pilot fuel jet, the jet type differs due to the presence (or not) of the fuel inlet holes in the shaft of the pilot jet. It is critical that you verify which style carbs you have:
    http://www.xs11.com/forum/showthread.php?t=35964
    Valve Clearance Intake: 0.16 - 0.20mm (= 0.006 - 0.008")
    1980-81 XS1100 Models:
    Carb Series: BS34-111
    Carb Model ID: 3H5-00 (1980 Standard model)
    Carb Model ID: 3H5-01 (1981 Standard model)
    Carb Model ID: 3J6-00 (1980-81 Special and Midnight Special models)
    Pilot AIR Jet Size: #185
    Main jet NEEDLE ID: #51Z7 (Standard models)
    Main jet NEEDLE ID: #5GL16 (Special and Midnight Special models)
    *** although all 1979-81 XS1100 models uses the same size pilot fuel jet, the jet type differs due to the presence (or not) of the fuel inlet holes in the shaft of the pilot jet. It is critical that you verify which style carbs you have:
    ***** there is quite a bit of discrepancy between the service manual and parts diagram specifications for the correct size(s) of the 1980-81 XS1100 main fuel jets:
    Service manuals:
    1980-81 Standard models: #115 jets on the outer carbs and #120 jets on the center carbs.
    1980-81 Special models: #110 jets on the outer carbs and #120 jets on the center carbs.
    1980-81 Midnight Special models: #110 jets on the outer carbs and #120 jets on the center carbs.
    Parts books:
    1980 Special models: #120 jets on the outer carbs and #125 jets on the center carbs.
    1981 Special models: #110 jets on all four carbs.
    1980-81 Midnight Special models: #110 jets on all four carbs.
    If you're going to be getting fancy and modifying your intake or exhaust system, then you're going to be spending a lot of time re-tuning (re-jetting) your carbs in order to attempt to get them to run properly......and thus all the jetting size information from the above lists becomes somewhat useless (all the other specs will still be valid, though). Here's a few insights:
    WHAT ABOUT RE-JETTING FOR PODS, ETC?:
    Before we even start down this bumpy road, let's get this out of the way: changing the mufflers (only) will generally not require re-jetting, as the stock mufflers are pretty darn free-flowing as it is. The major airflow restrictions (by design) in these engines is on the INTAKE side (the airbox system and its pleated paper filter). Changing to a high-flow air filter (like a K&N) will definitely require increased fuel jet sizing.
    That being said, all of these bikes were jetted a bit lean from the factory, in order to satisfy EPA emissions requirements of that era. So even a stock engine can benefit from slightly larger fuel jets; for example, a stock XJ650 non-Turbo USA model, increasing fuel jet sizes to #112 on the mains (from the stock #110 size) and to a #41 on the pilot (stock is a #40 size) can be beneficial. Note that the pilot jet size is not as critical as the main jet size, since the pilot circuit mixture screw allows you to “open up” the pilot circuit independent of the jet size.
    But what about when you do make other intake/exhaust system changes? It's a question we get asked often and unfortunately, one that we cannot answer honestly about your specific bike besides with "it depends".
    Which is a nice way of saying "you're about to enter the seventh circle of hell......."!
    Carb jet tuning required by aftermarket modifications is somewhat of a black art, part science, part skill, part luck. It depends on the current state of tune of your engine, your altitude, the mix of aftermarket parts on your bike, etc........a lot of variables.
    The best advice we can offer is: Just Say No. Don't do it! Leave everything stock!
    But, since most people---with good reason, I might add---don't always listen to our well-intentioned advice, then the next best recommendation we can offer is: "if you want more power get a bigger bike!".
    And since that doesn't cut it with many owners, either, for the remaining stalwarts out there who insist on "experimenting" with aftermarket intake and exhaust systems, here's the best information that we've come across to give you some GUIDANCE, which you should take as just that, and not as ANSWERS, because it isn't!
    MAIN FUEL JET SIZE CHANGES NEEDED PER TYPICAL MODIFICATION:
    Typical Exhaust Changes:
    +2 main fuel jet size for custom 4-into-2 exhaust
    or
    +4 main fuel jet sizes for 4-into-1 exhaust
    or
    +4 main jet sizes for no muffler (open headers)
    Typical Intake Changes:
    +2 main fuel jet sizes for single K&N filter (inside a stock airbox)
    or
    +2 main fuel jet size for drilling holes in the airbox with stock filter
    or
    +4 main fuel jet sizes for individual pod filters (no airbox)
    Additional changes:
    - Add up all the main fuel jet size increases and subtract 2 sizes.
    - Decrease main fuel jet size by 2 sizes per every 2000' above sea level.
    - Under a mis-match condition, such as when using pod filters with a 100% stock exhaust, or 4-into-1 header with stock filter and air box, then subtract 2 main fuel jet sizes.
    PILOT FUEL JET SIZES CHANGES NEEDED PER TYPICAL MODIFICATION:
    Pilot fuel jet size changes are related only to the change in main fuel jet sizes according to the main fuel jet size formula described above. Note that this pilot fuel jet rule is for the main fuel jet size change BEFORE any main fuel jet altitude compensation is factored in:
    Increase the pilot fuel jet size +1 for every +3 main fuel jet size increases.
    Additional changes:
    - Decrease pilot fuel jet size by 1 for every 6000' above sea level.
    PRECAUTIONS:
    - Make sure your carbs are in perfect working order before making ANY jet changes....meaning fully cleaned internally and rebuilt, operating properly in their stock configuration, proper sized air jets and needles, etc. Otherwise, you'll like find that all of your efforts are going to be a HUGE waste of time.
    - Check plug color often and adjust as needed, 2 main fuel jet sizes at a time and 1 pilot fuel jet size at a time. Bright white plug insulators are a sign of an overly lean fuel mixture condition and WILL cause damage to your engine over time, up to and including engine seizure!
    - Synch the carbs after each jet change.
    - Make sure the floats are set correctly
    - Seriously consider purchasing a Colortune Plug Tuning kit.
    - You may find it necessary to make changes to the size or shimming of the main jet needle. There are no guidelines on what or how to do these changes, this is true trial-and-error tuning!
    EXAMPLE:
    A 1982 XJ750RJ Seca using an aftermarket Supertrapp 4-into-1 exhaust and a single K&N air filter in the stock, unmodified airbox. Bike is primarily operated at an altitude of 2600 feet above sea level.
    XJ750 Seca Stock Hitachi HSC32 Carb Jetting:
    #120 Main Fuel Jet
    #40 Pilot Fuel Jet
    #50 Main Air Jet
    #225 Pilot Air Jet
    Y-13 Needle
    MAIN FUEL JET SIZE CALCULATIONS:
    Changes made:
    Exhaust:
    4 into 1 with Supertrapp = +4 Sizes Main Fuel Jet
    Intake:
    K&N Pod Filters = +4 sizes Main Fuel Jet
    Equals: +8 main fuel jet sizes above baseline
    Subtract: -2 main fuel jet size per formula above
    Equals: +6 main fuel jet sizes due to modifications, thus:
    Stock main fuel jet size is: #120
    + 6 additional sizes
    = a #126 main fuel jet size
    Subtract: -2 main fuel jet sizes for Altitude of 2500' Average
    = #126 calculated from above
    -2 jet sizes for altitude adjustment
    = a #124 main fuel jet size.
    PILOT FUEL JET SIZE CALCULATIONS:
    The formula is: +1 pilot jet size increase for every +3 main jet sizes increased.
    Stock pilot fuel jet size is: #40
    + 2 additional jet sizes (since we went up +6 main fuel jet sizes before the altitude compensation was factored in):
    = a #42 pilot fuel jet size.
    Note that no altitude compensation is needed on the pilot fuel jet since our elevation is less than 6000' a-s-l.
    RESULT:
    A #124 Main and #42 Pilot is A GOOD STARTING POINT.
    Note that the above calculations do NOT take into account any possible changes in the sizes of the main or pilot air jets, the main needle or main needle jet size, and thus are additional variables and opportunities for tuning excellence. These are areas which are largely unexplored by most tuners, but logically should allow for additional fine tuning or additional rage and frustration.........
    Normally, changing to an aftermarket exhaust does NOT require re-jetting, (or minimal re-jetting) as almost ALL of the airflow restriction in the airflow path thru the engine (meaning: ATMOSPHERE > AIRBOX > FILTER > AIRBOX BOOTS > CARBS > INTAKE MANIFOLDS > CYLINDER HEAD PASSAGES > EXHAUST SYSTEM > BACK OUT INTO THE ATMOSPHERE) is within the intake side of this air flow path, and primarily within the stock airbox/air filter. Your stock EXHAUST system can already flow more air volume than the stock INTAKE system allows.
    Thus changing only the stock EXHAUST system, with no changes to the intake side of the heads, normally makes NO DIFFERENCE IN TOTAL AIRFLOW, and "no difference in total airflow" means "no difference in TOTAL FUEL FLOW" either, and thus bigger jets are not needed.
    But once you start freeing up the INTAKE side of the entire system, you will produce more system airflow, even with a stock exhaust system (because, the stock exhaust system has the capability to flow more air through it than what the stock intake system allows).
    This is why re-jetting is usually needed even if you keep the stock airbox and the stock exhaust, but use a K&N low-restriction filter, or even if you drill holes in the stock airbox, or leave the filter lid off.
    All such actions free up the intake side airflow restrictions; the stock exhaust will move this additional airflow, and without providing addition FUEL flow to match the increased airflow (within limits, an engine will gobble up the maximum amount of airflow that it can; an internal combustion engine is actually just a self-powered AIR PUMP) then the engine will run "lean"---meaning not enough fuel to match the amount of airflow that the engine can (and now will) gulp.
    Most pod type filters allow for vastly increased airflow, and thus require fuel re-jetting, and although no one really talks much about it, probably also require AIR JET changes to match the additional fuel flow, but since no one likes to deal with two parameters at once, it becomes a "tuning nightmare".
    BUT, when you read all of the common symptoms of people who use pods, you quickly come to the conclusion that it's not possible to reproduce the stock "smooth in all rpm ranges" engine response. The reality is that you SHOULD be able to match it pretty darn closely, even with the increased airflow through the system, but ONLY changing the fuel jets isn't going to accomplish that. There are also air jets in the system, and they are there for a reason, as well as needle tapers and vacuum piston responsiveness issues.
    For further insights and understanding, the Holy Grail (meaning: the whole miserable, un-varnished truth of what a real chore carb tuning is going to be, written by people who actually know what they're talking about, rather than by people who are trying to sell you something) can be found at:
    www.factorypro.com
    and then click on the "Product Support/Technical Support" link at the top of the page, then on the "Motorcycle Tuning Tech" link, and then the "CV Carb Tuning" link........and then read, weep, study, and do....if you still dare to! HINT: if reading through it makes you think to yourself "sheesh, this sounds like an incredible amount of effort!", well, you're right! That's just some of the joys (and pitfalls) of getting to play "tuning engineer", which is what you're going to be doing. Yamaha probably has 10 of those types of guys on staff, and millions of dollars of test equipment, both physical and computer-aided, that allowed them to get the mixture settings just right---from an overall drivability AND power output standpoint----and now, since you're changing the airflow parameters thru the engine, you'll have to figure it all out "from scratch", but WITHOUT the benefit of 10 trained engineers and all that test equipment and experience.
    That's why we warn you that setting up a bike for pods can be quite a bit of trial-and-error procedure. You can make the calculations according to what is shown in that guideline and then order the jets that the "formula" recommends, and that should serve as a good STARTING POINT............you may (or may not!) have to do more tuning and trial-and-erroring substitution of different jet sizes, etc. to get it performing to you satisfaction, with the recognition that you may ALWAYS end up with a situation that has some kinds of trade-offs.....lazy at the lower end but runs well at mid/upper-ranges, or runs well at the lower end but a "flat-spot" at some other rpm range, etc. Unfortunately there is no magic formula........you might want to read through the factorypro.com article that I list at the end of that section, and you will get a better understanding of what is involved to get the carbs set-up properly in a non-stock configuration.
    As one of our favorite experts says about pod filters: "Get a Rubik's Cube instead.....it's less trouble and actually has an eventual solution!"
  10. chacal
    Revelations: JOURNALISM AT ITS FINEST!:
    Graven Images Which Tell a Thousand Words:
    Hitachi carb pictures and rebuild instructions, a big celebratory wheelie goes out to contributor Alive:
    http://xjbikes.com/forums/index.php?threads/3649
    And a high-side Ole'! to Da'Schmuck for his exceptional Hitachi carb rebuild write-up:
    http://www.xj4ever.com/hitachi throttle shaft seals.pdf
    Mikuni owners should also remember Alive in their nightly prayers:
    http://xjbikes.com/forums/index.php?threads/3690
    Big Fitz gets medieval with his Valve Clearances, and shows how easy and important it is to actually get this task done on all air-head model engines:
    http://xjbikes.com/forums/index.php?threads/14827
    and 85MaximXX takes you water-head owners by the hand, and leads you into the promised land of Valve Pad Replacement on those models:
    http://xjbikes.com/forums/index.php?threads/16298
    And the Fishmaster has a nice video of a vacuum diaphragm passing the CLUNK TEST with flying (or rather, "falling") colors:
    And the reason you want your vacuum pistons to operate as closely as possible to a "zero-resistance" state is because they must be able to perform, constantly, in the following manner; and if not, tuning and performance becomes troublesome or downright impossible:
    and
    https://www.youtube.com/watch?v=PoEo-KrMTA0
    Gamuru shows you how to clean that starter jet properly:
    http://xjbikes.com/forums/index.php?threads/8918
    And not to be outdone, Gamuru also shows how-to bench-synch a set of carbs using the easy, painless method:
    http://xjbikes.com/forums/index.php?threads/6366
    Definitely not Academy Award quality, but these two video presentations show a Colortune Plug in action:
    http://www.gadgetjq.com/Vulcan_1500_Idle_Mixture_Test.wmv
    and
    http://www.gadgetjq.com/Vulcan_1500_Mixture_Test.wmv
    and here's a few more:
    going from orange (rich) to blue:
    showing the blue to orange to blue changes:
    showing a colortune being hooked up incorrectly (arcing):
    Please remember, though, that a Colortune is NOT used to set your carbs at anything other than idle rpm's!!
    And here's a great tutorial on using the Carbtune Synch Gauges:
    http://www.youtube.com/watch?v=CYgN2-96Ik0&feature=related
    SOME FINAL THOUGHTS:
    Conclusions: A Few Observations That We Hope Are Now Self-Evident
    a) If you don't plan on checking and correcting (if needed) the valve shim clearances, then don't bother cleaning and rebuilding the carbs.
    b) If you don't plan on synching the engine when you're done, why bother cleaning and rebuilding the carbs?
    c) If you don't plan on using a colortune plug to properly tune the carbs when you're done, what difference does it make whether they're clean and rebuilt?
    d) You will never, EVER find anyone who is willing to do as thorough a job in cleaning your carbs as you are.
Thread Status:
Not open for further replies.
