Rear disc set up installed.......
Discussion in 'XJ Modifications' started by robawf, Dec 1, 2015.
  1. robawf
    robawf Member
    jayrodoh and Kickaha like this.
  2. robawf
    robawf Member
    I'm no purist. If you are read no further.
    Bandit under slung caliper.
    R6 master cylinder.
    Suzuki GS wheels.
    Xj 600 Swingarm.
    More pictures will be posted soon.
  3. k-moe
    Shiny!!
    More stoppy is a good thing. I like drum brakes just fine, but more stoppy gets really expensive with drums (eve moreso when the drum is part of the wheel casting).
  4. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    More stoppy, more springy, more dampy, you got a lot goin' on back there!
  5. quebecois59
    Nice bike !
    I dont think your disk drilling pattern is optimal though, the holes aligned in radial rows like this may lead more easily to straight cracks.
  6. robawf
    robawf Member
  7. robawf
    robawf Member
    They are Kawasaki discs. I didn't drill them. It's the same drilling pattern that Kawasaki used during the late 70's and early 80's. I liked them better than solid discs or the swoop pattern. Good point though.
  8. hogfiddles
    Yet I've seen a lot of rotors drilled that way
  9. hogfiddles
    Oops, didnt see the later posts..... That explains why ive seen it a lot......
  10. k-moe
    More of a myth than a point. Steel and iron are very tolerant of holes. Cracking is usually caused by casting imperfections that grow over time.
  11. hogfiddles
    That why we can drill holes and bolt things together, right? Lol
  12. quebecois59
    Very funny...one hole is a thing, a row of holes with the last one close to the edge is somethiing else. I can envision that the distance between the last hole and the edge of the disk may make a big difference, though.
  13. chacal
    Very tasteful mods.
  14. robawf
    robawf Member
    20151205_092427.jpg 20151205_092445.jpg 20151205_093041.jpg Better pics.....
    Alan63 likes this.
  15. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    These rotors are scientifically drilled.
    +1. Very professionally done.
    Gary H.
  16. quebecois59
    Now that I see better pics, I have to agree that the drilling pattern is a lot better than I thought first. The distance betwwen the outer holes and the edge of the disk is obviously appropriate.
  17. robawf
    robawf Member
    I finally rode it today. Very different, very responsive and comfortable ride. After some adjustments to the suspension it stops.....now! No skidding, no wobble, no fade.
    rocs82650 and k-moe like this.
  18. specialk
    specialk Active Member
    Ontario
    Bike looks gorgeous, how do you like the RFY shocks? I have a pair on order for my XJ550R.
  19. robawf
    robawf Member
    I, like most, was attracted to the RFY shocks cause they look cool and they are reasonably priced.
    So here my take on them:
    > Satisfactory design and materials.
    > Unsatisfactory or incomplete assembly and packaging of product.
    > No product literature, nothing.
    Bottom line is they come with little or no shock oil (different from fork oil). Air pressure is incorrect or there is none. (75-140PSI)
    So carefully take them apart, put in new quality oil, reassemble,and equally charge with nitrogen or air. After you have completed this small task you actually have some decent functioning shocks that perform adequately for the riding most people do.
    quebecois59 likes this.
  20. quebecois59
    I didn't even know they could be taken apart.
