XJ650 spark plug gap
Discussion in 'XJ Technical Chat' started by ouchie, Sep 19, 2011.
  1. ouchie
    ouchie Member
    Hey gang!
    Well did a search and looked in my Yamaha manual but oddly enough I can't seem to find the proper gap setting for the XJ650.
    Little help please? :D
  2. moellear
    moellear Member
    Lima, Ohio
    IIRC, its around .75mm (.7 ~ .8)
  3. Mr.Etobicoke
    Mr.Etobicoke Member
    Toronto, Canada
    The plug is a NGK BP7ES and gapped at 0.7-0.8 mm or 0.023-0.032 inch.
    Kenneth
  4. ouchie
    ouchie Member
    'preciate the help gents!
  5. bigfitz52
    They only widen with the miles; I generally start at .025"
  6. xj_mark
    xj_mark New Member
    Chicagoland Illinoise
    Fitz,
    Is that the gap you set for all bikes or just the 650?
    XJ550? NGK DR8ESL
    Thanks.
  7. bigfitz52
    I use the same "starting" gap on the 550s, yes.
    And you should be running NGK D8EA in the 550, not DR8ESL's. Especially with the stock plug caps, you don't need resistor plugs too.
