fusebox quicky
Discussion in 'XJ Technical Chat' started by turtlejoint, Aug 18, 2008.
  1. turtlejoint
    turtlejoint Member
    does the xj typically have 2 fuse boxes? I have 4 fuses under the TCI. but am i supposed to have another fuse box with 4 more fuses in it? the reason i ask is because i just bought a wiring harness (used) to replace mine and it has a fuse box intact that my bike is currently without. (a likely cause of my turn signals shorting out.) I wanted to do the fuse box upgrade but i wasnt sure if im supposed to have 2 fuse boxes or 1.
  2. stereomind
    stereomind Active Member
    Tulsa, OK
    I'm pretty sure all XJ's have a single "quad" fuse box, although some models have individual fuses scattered here and there, like the 750 Seca or the XJ1100...
  3. turtlejoint
    turtlejoint Member
    well the way mine is set up is under the LH side cover i have the TCI box along with 4 screw in fuse holders. (the type where you put the AGC fuse in the cap that holds it and then screw the cap into a pocket. but there is no other fuse box or panel. ill take a pic and attach it asap.
  4. Altus
    Altus Active Member
    London, Ontario
    As far as I know, Yamaha never used that type of fuse holder on anything - which leads me to believe that's a custom job.
    The stock fusebox uses 4 glass fuses in standard clip-at-each-end holders.
  5. turtlejoint
    turtlejoint Member
    ok here is a pic of my tci box and rogue fuse box... does anyone else have this or is it a custom job?
  6. wizard
    LOOKS NEAT.
  7. scarecrow
    scarecrow Member
    Dunnville, On
    LOOKS GOOD BUT IT LOOKS LIKE AFTERMARKET
    THE FUSE PANEL IS NORMALY UNDER THE SEAT ON THE AIR BOX
  8. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    That's not stock. Nice job though. I assume from your question that you still have the stock fuse box on top of the airbox. If not then this is the po's relocation idea. And a pretty cool one at that! If you still have the stock box then I would check to see what wires these fuse. If the 3 white and 1 brown wire from the stator then he may have been having alternator problems.
  9. turtlejoint
    turtlejoint Member
    thanks. I dont have the stock fuse box. this is the only one. and until is saw pics of other peoples fuseboxes, i had thought that mine was stock because of its location and nice install. i had planned on changing over to a blade type box but i may just keep this one around.
  10. Robert
    Not stock but nicely done. I would not have gone with glass fuses though.
  11. turtlejoint
    turtlejoint Member
    me neither, when i do my rewiring im going to see if i can drop in a blade fuse box in the same location that this one is in now.
    is the location of my fuse box where one of the tool boxes would normally be?
  12. wizard
    the safest, dryest place for your fuse box is under the seat, just my 2c.
  13. Robert
    It was originally located on the airbox lid. Under the seat is the wisest location I can think of. All of the original wires terminated there.
