1983 Seca Turbo
Discussion in 'XJ Technical Chat' started by Kingsshadow, Aug 22, 2008.
  1. Kingsshadow
    Kingsshadow New Member
    Having a problem with the front brakes. Small amount of pressure in the lever, and I am not getting any fluid down in the calipers. I also need a new fuel pump. Any idea where I can get one for real checp besides a wrecking yard?
  2. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
  3. phillyturbo
    phillyturbo Member
    Philadelphia PA
    bleed the brakes with a hand vac pump from the calipers that should help the brakes alot it did wonders for mine
  4. Kingsshadow
    Actually I thoroughly cleaned the master cylinder and cleaned the pistion, works great now, and I have gotten a Carter fuel pump that will deliver the appropriate psi to the motor. Now I am having carb problems since the professional idiot I took my baby to decided a bench synch would be "good enough to help stabilize the rpm's, had a nice chat with him and didn't have to pay since he didn't do what he promised. Irritated and frustrated to get my baby back to road potential now. Any ideas on this now?
  5. 82XJTurbo
    82XJTurbo Member
    South Texas
    How old are your brake lines? Did you rebuild the master cylinder? The below images are what happens when you take a shortcut and just "clean out" the master cylinder instead of doing the job properly. Don't fool around and take any chances on the brakes, these bikes had sub-standard brakes to begin with.
    This is what happens when a small piece of crud suddenly blocks the return port of the master cylinder.
  6. devo
    devo New Member
    82xjt, What did you do to fix that chin fairing? I just bought a seca turbo and the chin fairing is gone. If I could even find a broken one I could fix it.
  7. JeffK
    JeffK Well-Known Member
    Just North of Annapolis MD
    keep an eye on ebay...I saw one there the other day. Amazingly, there is still a pretty good selection of parts. Heck, I'm buying some parts that I don't even need but I'm afraid they won't be available in 10 years.
    jeff
