Mechanic's gas tank?
Discussion in 'XJ Modifications' started by ddibling, Aug 22, 2008.
  1. ddibling
    ddibling Member
    Peachtree City, GA
    I once had a mechanic come to the house to work on a bike. One of the things I asked him to do was sync the carbs. He had a cool little gas tank that he used to feed the carbs while he did this. It was almost like an IV bottle that he could hang up out of the way so he could run the bike but still get at the carbs for tweaking. Does anyone know what that's called and where I might get one?
    Thanks!
    Dean
  2. Polock
    mine's called a old can of Sea-Foam with a nipple soldered in the bottom side
  3. wizard
    thinners can.
  4. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    I use an old Lawnmower Tank hung from the left bar with a tie wrap. Carb Sync Pro hung on the right bar.
  5. Robert
    JC Whitney sells them. Chaparral sells them. J&K sells them. They are simply auxillary fuel tanks specifically made for this task. As you can see, you can fabricate an auxillary tank from a lot of different things so don't be limited, go for it and build one for yourself.
  6. mlew
    I made mine from a metal coffee can. Soldered a on/off valve to the bottom to attach the fuel line and a hook on the top to hang from a ladder. Took me 30 minutes to make it. I have never seen one in any catalogue for sale.
  7. schmuckaholic
    California
    Mine: alcohol bottle with a 1/4" hose barb screwed into the bottom.
  8. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I use a 1 liter plastic water bottle with the bottom cut out and a plastic nipple glued to the cap to feed the carbs for synchronizing the carbs on my bikes. I hang it from the handlebars with a piece of wire.
  9. samlives
    samlives New Member
    Looks like it made to smoke out of 8O
  10. ddibling
    ddibling Member
    Peachtree City, GA
    Thanks for the great advise! This group is really creative!
    Dean
