Vibration @ 4,000rpm
Discussion in 'XJ Technical Chat' started by knuts2a, Sep 17, 2008.
  1. knuts2a
    knuts2a Member
    Hi riders, i seem to be getting a vibration that starts @ 3,500 and goes to just over 4,000rpm in all gears. Runs ok otherwise, timing chain a little rattlely at start, but so am i at 6:30 in the morning. Planning a 1,600Km ride so want to get it all sorted before i head off. Any ideas?
    PeterN
  2. kontiki
    kontiki Member
    Columbia, SC
    My maxim has always had a slight vibration or 'resonance' at around 4500. It took me a while to notice it, I think it is the nature of these engines. Unless your mirrors go blurry I wouldn't worry about it.
  3. bill
    bill Active Member
    Raleigh, NC
    +1 there is a natural resonance - my 650 it is about 5k
  4. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    +2. Mine is between 4,000 and 4,500 RPM. At 5,000 RPM it is dead smooth going down the road.
  5. stereomind
    stereomind Active Member
    Tulsa, OK
    Ha! my Seca vibrates all the way from start to stop! Rigid motor mounts FTW!!
    The Maxim mill I got for it should be a bit smoother.. I hope. :mrgreen:
  6. RickCoMatic
    It only take about 25 or 30-minutes to do a Manual resetting of the Cam Chain Tensioner.
    That would be a good little project to do before hitting the road for a long haul.
    The Cam Chain Tensioner on the 900's is of the Automatic variety.
    Give it a go!
  7. rpgoerlich
    rpgoerlich Member
    Katy, Tx
    Keep it above 4k rpm, problem solved!
  8. G-Man
    G-Man New Member
    Same here.
  9. clhannah
    clhannah Member
    Portland, OR
    signed, except my exhaust rattles too :-(
  10. kd5uzz
    kd5uzz Member
    4.8k to 5.2k, helps keep me from going over the speed limit. My 'speeding' speed is right in that range, so I try to avoid it. Although sometimes I avoid it by going even faster...
  11. Harmonic
    Harmonic New Member
    My "harmonic resonance" is from 4k to about 4.5k. Annoying but what are ya gonna do?
  12. sagebrush
    sagebrush Member
    SO EVERYONE HAS A VIBRATION AT SOME CERTIAN RPM... I HAVE ONE TOO.. IT MAKES THE GAS TANK BUZZZ FOR ABOUT 2 SECONDS..
    BUT I THINK I HAVE A MISS IN THERE SOMEPLACE TOO... WORKING ON THAT ...
  13. RickCoMatic
    I think you should all take the batteries out of your vibrators and just ride the bikes and smile!
  14. knuts2a
    knuts2a Member
    Ok, in the morning its good (cool) on the way home it vibrates (warm), came home late tonight (cool) and it was good. Seems to like cool air better. New front tyre going on this week and some new Rjays riding pants as well, so when the budget catches up i might take to a dyno and see what they can find. Hate vibrations.
