The Ultimate Mileage XJBike, is ( )
Discussion in 'Hangout Lounge' started by protomillenium, Sep 22, 2008.
  1. protomillenium
    protomillenium Member
    New Buffalo, Michigan
    Hi Folks, Ever wonder how many miles your XJ will last?
    You guys who've put a lot of miles on the O, tell us the mileage on your still running XJ, we want to know how far an XJ can last. And, how long have you owned it too?
    Thanks!
  2. schooter
    23500, owned it since 23450, uhh some guy has like 65K miles on it idk who
  3. mikeg
    mikeg Member
    Milton, Vermont
    Mine is no record setter, unless it's for so few miles. I bought mine the end of April with 17,995 miles on it. I topped 19,600 this morning on the way to work. I don't know the history of this bike but somewhere in the past it must have sat for a while.
    btw, it was 34 degrees this morning. I need some warmer gloves!
    mikeg
  4. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
  5. NursePadawan
    NursePadawan Member
    Lansing, MI
    Wow, over 250,000 miles? Impressive, most impressive.
    Now we know who's really keeping XJ4Ever in business :wink:
  6. bill
    bill Active Member
    Raleigh, NC
    Mine has 41K miles but I know there are others out there with more
  7. Grynen
    Grynen Member
    Holland Landing
    I have 55,500 kms and i picked it up at 53,000 kms last fall.
  8. SyracuseXJ
    SyracuseXJ Member
    Wilmington, NC
  9. 85MaximXX
    85MaximXX Member
    S.W. michigan
    mine still has 24k and change on it as the the body and paint work took 3 weeks longer than I was told. But still running strong. This winter will be major maintence tho valce adjustment I believe the clitch disks will nee to be replaced rear brake overhaul.
  10. stereomind
    stereomind Active Member
    Tulsa, OK
    The Seca has almost 45,535 miles (~73,281 km) on it, still running like a top.
  11. bigfitz52
    And out of curiosity, Stereomind, how often do you check and adjust your valve clearances?
  12. stereomind
    Tulsa, OK
    The 550 was adjusted about 4K ago, so I'm not too worried about it (yet). The Seca was checked about 2K ago (it was still within spec), and when I first got it, at 39K. I like to keep the clearances a bit on the loose side... and it seems that higher mileage motors don't go out of spec as quickly as low-mileage ones.
    The replacement motor I just picked up for the Seca was adjusted as the first order of business. I had to get 3 new shims and swap 2 around. Luckily, we have a shop nearby that has just about every size shim imaginable, and they just trade me straight across.
    The hardest part is to keep the blasted valve cover gaskets from leaking after reassembly.. And for something that takes less than an hour, a clearance inspection should be on top of everyone's list (well, up there, anyway)...
  13. TIMEtoRIDE
    Don't tops eventually fall over ? :lol:
    '83 Seca 900 - 26,000 Miles
    '81 Seca 750 - 41,000
    '82 Maxim 750 - 30,000
    '82 Seca 750 - 20,000
    '82 Seca turbo - 2,440 (parts !)
  14. stereomind
    Tulsa, OK
    heheh yes they do, but then you just give 'em another good spin and they keep on going...
  15. Altus
    Altus Active Member
    London, Ontario
    Pretty sure the Norwegian one posted above is the current record holder - he used to be a member of the XJ email list too.
    I know for a fact that Dwayne Verhey's Seca is over 300k kilometers (Huntsville, Ontario).
    Anyone else in the 300k plus range?
  16. protomillenium
    Guy's, I'm glad to hear about all these high mileage bikes! I was worried when I looked at the Xj's listed on Ebay and saw only low mileage bikes. I'm a new owner you see, and I wondered, why people weren't putting more miles on these bikes. Who really knows.
  17. nsosh5
    nsosh5 Member
    oklahoma
    17,500 here
  18. Toreadorranger
    Toreadorranger Member
    Salem, CT
    I have 16500 on my bike.
  19. windlover
    windlover Member
    Vancouver USA
    Mine is just turning over 13,000.
    ~ 1100 per month since March except for 0 in August (on vacation).
  20. Kickaha
    New Zealand
    The two XJ550 Secas I have are at 106,230km and 86,770km, both are very rough and the 106,230km bike was using 1 litre of oil every 1000km before I pulled it to bits
    But neither of them looked as though they'd been looked after very well before I got them
