idle quality
Discussion in 'XJ Technical Chat' started by jim123, Sep 25, 2008.
  1. jim123
    jim123 Member
    Chicago,Il
    How smooth can the idle quality for an old xj get? I have heard some sport bikes that idle so smooth it sounds like a single note on a tenor sax. (BBBBRRRRRRRRRRRRRRRRRRRRRRRR) No skips, popps, burbles, etc. Please post vids of your bike idling.
  2. jim123
    jim123 Member
    Chicago,Il
    Picture 032.avi
  3. jim123
    jim123 Member
    Chicago,Il
    [video=picture 032.avi,200]http://[/video]
  4. jim123
    jim123 Member
    Chicago,Il
    [video=250,200]picture 032.avi[/video]
  5. jim123
    jim123 Member
    Chicago,Il
    How do you enter a vid to this site!!!
  6. jim123
    jim123 Member
    Chicago,Il
    http://s89.photobucket.com/albums/k230/ ... rrent=Pict<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i89.photobucket.com/player.swf?file=http://vid89.photobucket.com/albums/k230/jimz123/Picture028.flv">ure028.flv=Picture028.flv[​IMG]
  7. jim123
    jim123 Member
    Chicago,Il
    Here's the right vid. D[​IMG]oes t<embed width="448" height="361" type="application/x-shockwave-flash" wmode="transparent" src="http://i89.photobucket.com/player.swf?file=http://vid89.photobucket.com/albums/k230/jimz123/Picture032.flv">he idle get any smoother than this?http://s89.photobucket.com/albums/k230/jimz123/?action=view&current=Picture032.flvhttp://s89.photobucket.com/albums/k2 ... ure032.flv
  8. kordasn
    kordasn Member
    Toronto, Ontario, Canada
    Mine used to be, I'm trying to get it there again
  9. kordasn
    kordasn Member
    Mine used to be as smooth as a sport bike and I'm trying to get it there again :)
  10. jswag5
    jswag5 Member
    Saint Joe, IN
    ive had mine smooth as a babies bottom, but since the last carb cleaning i have yet to get it as smooth, having trouble with sync because when i rebuilt the carbs i think i ruined the throttle shaft seals.
  11. jim123
    jim123 Member
    Chicago,Il
    Funny thing now after fattening the mixture adjustment (too lean? the cooler it gets the worse it runs?) and the sync (which it seems like it could benefit from every time you feel like doing it) it needs starting fluid after it sits for a few days. Used to be able to start it by letting it sputter a few times and after that start to turn up the idle adjuster until it starts and runs, but roughly. After it begins to run smoothly (a minute or so) the choke lever becomes operational. Add some lever and the idle instantly speeds up. If I try to start it cold with the choke, it will just crank and the headlight will not come on and it will not start.
  12. TheHound
    TheHound Active Member
    Scotia, NY
    I've come to the conclusion that weather, heat, cold all have a great effect on the setting of the pilot mixture screws.
    I will get it perfect, like you said no, blurbs, pops, misses.
    Then run it at 50 degrees instead of 85 and it's off just a bit.
    Very humid days, not just rainy, humid, it has the same issues.
