coffin emblem
Discussion in 'XJ Modifications' started by tegulevi, Oct 28, 2008.
  1. tegulevi
    tegulevi New Member
    Im in the early stage of my bobber, and i found a 79 xs650 tank. but the yamaha emblem mounts are welded into a recess. Solution make my own emblem on the mill. so about 2 hours later i present.
    now i just need to paint a name in thee with some white script
  2. MaximXJ
    MaximXJ Member
    West central Wisconsin
    Neat idea! My tank is also lacking the emblems so I was debating about sanding/fillling with bondo when I repaint my tank this winter.
    I'll have to consider something like this
  3. Deathmetaldan
    Deathmetaldan Member
    Sunbury PA 17801
    if you use filler make sure that you use fiber reinforced filler other wise it will just crack out
  4. MaximXJ
    MaximXJ Member
    Thanks!
  5. turtlejoint
    turtlejoint Member
    just in time for halloween!
