Both coils gone at once?
Discussion in 'XJ Technical Chat' started by Pernig, Nov 6, 2008.
  1. Pernig
    Pernig New Member
    United Kingdom
    Hey guys.
    Since a couple of days ago the bike has been running ever so slightly funny when going slowish. Between about 2-4k revs it was a bit spluttery, hardly noticeable though.
    Last night I had no spark on plugs #3 and #4. Then no spark on any of the plugs. Called out the breakdown service and me and the mechanic had a look. The left hand side came back and it started. Managed to get it running and up to 8000 revs then it just died again. No spark whatsoever again.
    The mechanic started testing the connections and the bike is fine everywhere up to the coils. He said that it might be possible that both the coils have given up sort of one after another, but one thing he didn't check was the pickup coils. I'm gonna take a look at these today, but unfotunately I'm stuck 50 miles from home with a pretty limited set of tools. I'm pretty lucky I could crash at a mate's place nearby. Rang up the local Yamaha dealer and he said definitely check pickup coils first.
    Is there anything else I could check while I'm trying to get the bike going?
  2. kd5uzz
    kd5uzz Member
    I searched the forums for almost 20min looking for a link to a place that has XJ manuals online. I did this because I knew nothing about a '91 Maxim. After finally tracking the website down I couldn't find any mention of a '91. Did a Google search for a '91 Maxim. Nothing. Clicked your link, saw your description. Its an '84. -Please- change your sig. </RANT>
    http://www.manualz.info/Manuals_pdf/YAM ... Manual.pdf
    I would be very surprised if both coils died at the same time, and in the same way; they have lasted 24 years so far.
    Cyl #1 and #4 are on one coil, #2 and #3 are on the other. If you had spark on #3 and #4 (half of each pair) I would think your coils were good. You said that at first you had lost it on 3 and 4, then all, then 1 and 2 came back. Very odd.
    From what I understand (someone correct me if I'm wrong) Even though #1 and #4 fire at the same time, one of them is 'wasted', as that cyl is on the exhaust step of the cycle. So both sides of the coil fire at once. Why would the same 'side' of both coils go bad at the same time?
    The printed version of the manual linked to above (PG 143, section 1) says that there are two pickups, one for cyl #1/#4 and #2/#3.
    Figure out what 3 and 4 share, that 1 and 2 also share and you'll find your problem.
    In fact, the only thing I can think of that they share is the TCI.
    There is no way to test the TCI. But if the TCI is firing the coil at all then the coil should create spark on both #1 and #4 at the same time. That does bring it back to the coils.
    Basic debug methods... check the simplest things first. Connections (loose/shorting wire somewhere?), plugs (Maybe your plugs are damaged?) , etc.
  3. bigfitz52
    There is one way, and that's to swap it with another one or swap it to another bike. With that option unavailable it might at least be worth having a look IN IT. You can remove the screws and pop the cover and check for obvious signs of corrosion or broken/bad solder joints. I have read posts on here where folks successfully repaired a flaky TCI unit that way. You didn't mention whether or not it was wet, rainy, misty out when you experienced the issue. If so, it COULD actually be the coils...
  4. Pernig
    Pernig New Member
    United Kingdom
    Thanks for the replies guys.
    It was raining when the bike broke down. Was raining all day yesterday. And Saturday, when the bike started to show the first signs of going wrong. Perhaps I'm wrong about it firing on one plug of each coil. What I am certain of is that at times it was running on two cylinders, which was why the recovery mechanic suspected the coil(s) were at fault. When the engine was running, there's not really a way I could see which cylinders were firing. It must have been running on all four cylinders to rev to 8000 rpm. Maybe it's loose wires. I too find it very odd that both coils have gone bad at once. Not really an option to change the TCI box at the moment. I think the only thing I can do is check for corroded/missing/bad connections and see if I can bring the bike to life to get me home.
    There aren't any fuses in obscure places or anything I might have overlooked are there?
  5. kd5uzz
    kd5uzz Member
    If there was a low voltage condition from the TCI, etc could that cause only 1/2 the coil to fire? I've never seen a schematic for a coil so I'm not sure if that is possible. If the two plug wires are connected to the same place on the coil then that wouldn't be the case.
  6. SQLGuy
    SQLGuy Well-Known Member
    The coils have a single, not-center-tapped, secondary winding. To complete a circuit, current in the secondary winding must go through one plug wire, across the gap of the plug (firing it), through ground, across the gap of the other plug (firing it), and up the other plug wire back to the coil.
    The only ways one plug connected to a coil can fire without the other firing are:
    1. If the gap of one plug is bridged
    or
    2. If one of the plug wires is shorted to ground somewhere
    or, maybe
    3. If the coil has an internal short to ground somewhere along its high tension winding
    2 seems fairly unlikely to me, but would be somewhat obvious if it was the cause. 3 seems extremely unlikely to me, as such a failure would be more likely to kill the coil entirely.
  7. kd5uzz
    kd5uzz Member
    If the gap was bridged, what would cause it to fail, self correct, and fail again? I eagerly away news of Pernig's progress.
  8. bigfitz52
    The reason I asked about moisture is that the stock coils are known to develop microscopic cracks that can allow moisture to affect the coil's performance. The problem ususally comes to light (at least initially) in damp, rainy, foggy and/or wet conditions. There have been a few posts about this, RickCoMatic has a "fix" but I don't remember what exactly it was. I'll try to find it.
  9. Turkey
    Turkey Member
    Wendell, NC
    I would be interested in finding that fix also. My bike runs like crap in the rain.
  10. RickCoMatic
    It's not a Fix.
    It's just "Open Case Surgery" to install New Plug Wires.
    I think the Coils are going to be like the Fuse Panels.
    There is something about the way they are made that deteriorates in all of them.
    And, we are probably entering the early part of when that deterioration process causes these Coils to misfire.
    I don't know how nor what they are made of. Earlier, a Member said there are PCB's inside the Coil Pack.
    That's enough to keep me out.
    Weather it's actually the Coils or the Wires is unknown.
    But, I think there is enough "Coil Not Firing" Posting to not get to the bottom of it and find-out what it is that's beginning to be a headache for so many.
  11. Pernig
    Pernig New Member
    United Kingdom
    Thanks for all the input guys. Not got to the bottom of this yet but I'm home safe and the bike's with me. I have a multitester and a better selection of tools and no pressure when I look tomorrow which will benefit a lot.
    The guy who I bought the bike off is an independent mechanic/dealer/racer. He gave me and the bike a ride home in his van. We tried to get it jump started as the battery is nigh on flat now, and for a moment it wanted to start when he was playing with the killswitch. I've seen this on single cylinder bikes before where the killswitch kind of lets the bike run if you bump or kickstart but not let the electric starter start when there is damp in the switch itself and have cured it by dismantling, WD40 and reassembling. I'm going to pore over wiring diagrams tonight.
    The fact that I've got it firing and I've had it running points to corroded or dodgy wiring to me. Cracks in the coil could be a possibility, but it seems very unlikely that the coils would both blow within a minute of each other and then start working again intermittently.
    So tonight I'm going to look at the wiring configuration for the ignition system, particularly around coils/pickup coils/killswitch areas, stick the TCI indoors to dry and whack the battery on charge. We'll see what tomorrow brings.
    Thanks for your input everyone, you've got my brain going and are keeping me going :D. I will keep you updated.
  12. Polock
    SQLGuy: would you run that by me again, something there just don't sound right
  13. SQLGuy
    Short story: when one of these coils fires, the completed HV circuit goes through BOTH plugs - they are fired in series, not in parallel. So, if you were to disconnect the plug cap from #1, #4 would stop firing too.
    However, if a plug's gap is bridged (as happened to me the other day) that completes the circuit for that side, so the other plug will still fire.
    Here's the full circuit:
    One end of HV Coil - plug wire - 5K resistor (in plug cap) - plug center electrode - arc - plug ground electrode - ground (through the cylinder head) - other plug ground electrode - arc - other plug center electrode - 5K resistor (in plug cap) - plug wire - other end of HV coil
    The energy in the HV winding of the coil comes from the collapsing magnetic field when the TCI module turns off the driver transitor that pulls the coil primary winding to ground.
    This reminds me, though: those plug caps are a bit problematic. Most bike shops stock the NGK LB05F (for #1 and #4) and YB05F (for #2 and #3) resistor caps, which are good replacements. They run $4 or so a piece, and screw on. You can't easily replace the wires, but you can replace the caps.
  14. RickCoMatic
    I don't think the Ignition Coils fire that way.
    That does not sound right at all.
  15. SQLGuy
    Care to elaborate on that? My background is, admittedly, not a mechanic's one. I majored in computer engineering and worked for many years as an electronics tech and avionics tech (anything from component level repair of computers and monitors to black boxes on F-15's).
    On my bike I no-longer use the stock coils anyway, I've instead replaced them with GM Saturn coils that are being directly driven by Microsquirt:
    Nonetheless, I'm quite sure about the electrical theory and the current flow in these devices. The schematics from Haynes manual also backs this up. Which part(s) of my explanation don't ring right with you?
    Cheers,
    Paul
  16. Polock
    plugs from each coil are in parallel, if #1 wire is pulled off #4 fires alone
    the ground connection for the coil secondary is the mounting bolts, that's why the outer laminations are stainless, they need a good connection to the frame/ground
  17. RickCoMatic
    The Series part.
    That part.
    Losing #-1 causing #-4 to misfire.
    That must be incorrect.
    If that were true; then wouldn't pulling a Plug Cap off a running engine to detect a Bearing Knock cause the other cylinder to misfire?
    It doesn't.
    The Engine will run on 3 Cylinders just fine.
    As many of us know, who have had to deal with only one cylinder misfiring.
  18. SQLGuy
    OK guys, then, explain me this:
    I still have my old coils, and they worked fine before I removed them. I just measured one with my meter (a Fluke 89IV). From one plug cap to the other measures 22K Ohms. From either plug cap to the lamination core, or to either of the low voltage contacts, measures open.
    If there is no measurable connection between the high tension side and the core, how is the ground return for the spark supposed to be through the core?
    Look at the schematic in the Haynes manual: there's no electrical connection between the HV side and anything else.
    Pulling a cap off a running engine doens't cause the other cylinder to misfire; it causes the other cylinder to not fire at all. The engine will run on three cylinders, like with a bridged plug gap, and it will also run on two cylinders. I wouldn't call either of these conditions "fine", but it will run.
    I just tried a simple little experiment, that you can try as well: pull one cap and put a spare plug in it. Let that plug sit against the block and crank the engine. You should see a strong spark there. Now pull the corresponding other cap and leave it as far from everything as possible. Crank the engine again... you may see some very weak spark on the loose plug (since it's hard to insulate 40KV) but you certainly won't see the strong spark you had when the other cap was connected; you may see no spark at all. If the plugs were firing in parallel, removing the other cap would actually make the first spark stronger.
  19. wizard
    You should remove the plug caps when testing the coils.
  20. Polock
    while i ponder that tell me how the voltage jumps one gap goes through the engine and out the other plug without electrocuting you, since the head is at
    coil secondary potential
    is the engine isolated from ground?
    once the path to ground is made the circuit is complete, it can't come back out and keep going
  21. SQLGuy
    I'm afraid that's a bit beside my point. My point is that the coils are wired exactly as shown in the diagram RickCoMatic posted: there is no electrical connection between the secondary winding and the primary winding, nor is there any connection between the core and either of the windings.
  22. SQLGuy
    To electrocute you current has to flow through you. There is no circuit path through you that has anything to do with the secondary of the coils. Electricity will take the path of least resitance to complete the circuit and that is the path I explained earlier.
    Now, there is another experiment you can try if you don't believe me on this one (OK, don't really try this, it's just for illustration):
    disconnect the caps from two corresponding cylinders (like 1 and 4)
    put spare plugs in the caps
    hold the ground part of the plugs in each hand
    crank the engine
    Now you are taking the place of the cylinder head and the coil WILL electrocute you.
    Another way you can analyze this is to use Ohms law: A good igntion coil might peak out at a .25A or so on the high voltage side. The resistance of the cylinger head between the two plugs is probably about .01 Ohm. .25A over .01 Ohm means about .0025V difference between the two plugs through the cylinder head when the plugs are firing. You'll never feel that.
    Also, ground is not some worldly absolute. It's just a convenient way of saying a bunch of stuff is connected together at that point. Current certainly can flow THROUGH ground. Look at the schematic again. There's a potential between the two ends of the secondary coil when the coil fires. That potential results in current that wants to flow from one end to the other of that coil, and it will do so through any conductor, even if that conductor is an aluminum cylinder head labelled as ground.
  23. wizard
    Quite so.
  24. Polock
    ok i think i see the light, it's a isolated system and there is no ground
  25. SQLGuy
    Yup. That's exactly it.
  26. RickCoMatic
    No.
    That's incorrect.
    The Cylinder Head is the Ground.
    The schematic shows the Coil's Secondary Wiring to be Parallel.
    There is no indication suggesting anything other than BOTH Spark Plug Wires firing simultaneously.
    The Path from the Coil shows that the Output from the Coils go only to the Plugs straight to Ground.
    There's absolutely no indication other than the Path terminating at Ground.
    No additional path indicating that the sequence is in any way a Series.
    Isn't that exactly what the Ignition System Schematic shows?
    All four paths to the Spark Plugs terminate at Ground.
  27. kd5uzz
    kd5uzz Member
    It looks to me like the TCI creates a HV loop on the primary coil. This creates a magnetic field. When the TCI stops the HV the field collapses, inducing another HV in the 2nd coil.
    For current to flow there has to be a loop, and it flows in ONE direction in that loop. This is fact, no way around it.
    When the field created by coil 1 collapses, a current spike is induced in coil 2. Think of it as pushing all the electrons that are part of the actual wire that makes up coil 2 to one end of the wire. They create a HV potential at that point. The voltage is great enough that it jumps across the air gap of the plug and eventually to the engine block. Now those electrons want to get back to the other side of the coil, so they jump the other gap, thus maintaining the balance that must be. The engine block IS ground, but only for the 12volt circuit that the lights, starter, etc are a part of. This HV circuit is totally separate.
    I just learned why these (and most) bikes are so noisy electronically... the entire bike is part of the ignition system. Joy. It is going to be fun if I ever get around to adding a ham radio to the bike.
  28. kd5uzz
    kd5uzz Member
    Just to clarify, they do fire at almost the same time, the electrons complete the loop at the speed of light. I guess this means that one plug fires from the electrode to the tip, and the other fires from the tip to the electrode. Interesting.
  29. wizard
    when you say coil 1 & coil 2, do you mean primary & secondary windings ?
  30. bill
    bill Active Member
    Raleigh, NC
    kd5uzz has given a great explanation. His coil 1 is the primary and 2 the secondary.
    Let me add a couple of points. You may not need the loop to fire either plug. Current induced in the secondary coil will flow in one direction when induced by the primary field building and the other direction when the primary field collapses.
    I'm not sure how the TCI works but my assumption differs from his in that I believe it pluses the primary - thereby having a building and collapsing field for each "firing".
    Back to his explanation - current flows as the field builds and the spark happens, as the field collapses the current flows to the other end and the other spark happens.
    So I contend one plug can indeed fire without the other. It may be a weaker spark because the air gap in the plugs in not infinite resistance so in a good system there is some of the looping described which could provide more current. But for our purposes we are only concerned with a spark hot enough for combustion.
    I will admit that so far I have only seen fuel issues causing 1 cylinder to not fire but I don't have the wealth of experience others here do.
    By the way this is a great discussion!
    EDIT - thought of a good illustration. You build up static on a cold day and touch a door knob. You get a spark because of the difference in potential energy. The knob is in a wooden door - no ground - same if you touch a person. If you touch something grounded you get a bigger shock/spark because the potential difference is greater. kd5uzz mentioned the HV build up at the plug - same thing.
    A vandegraph (sp?) generator is a similar device - you can have on rubber soles and still draw a spark - again potential energy differences.
  31. bill
    bill Active Member
    Raleigh, NC
    I should add that this points to one fact - If one side is firing and the other is not the fault is in the Wire, cap or plug not the coil itself. At least IMHO
  32. flash1259
    flash1259 Member
    W.R. Wisconsin
    I would check the SIDESTAND RELAY and the STARTER CIRCUIT CUTOFF RELAY
    Both stop spark.
  33. SQLGuy
    You're still hung up on a misconception about ground. For the secondary of the coils, ground is just a connection between the bodies of the two spark plugs. Period.
    A transformer, such as these coils are, is an isolation device. The fact that one end of the primary coil is intermittantly connected to ground means nothing to the relationship of the secondary coil to ground.
    TCI charges and discharges the coils just like a Kettering points system. It simply does it with transistors instead of points.
    I assume you didn't actually try the first experiment I suggested. Please do and let me know what you actually see.
    What the schematic shows, and you highlighted, is that the secondary side of the coil has only one possible circuit path. Here are four equivalent circuits to the secondary side that might make this clearer (keep in mind that the arrowheads represent the spark plugs):
    When the coil discharges, its secondary side has a potential difference between one end and the other, just like a battery has a potential difference between the + and - terminals. And, just like the battery, current can't flow if one of the terminals is disconnected. If you disconnect one of the plug caps, you've opened the circuit and current cannot flow.
    Does this progression of equivalents make it clearer why this is a series circuit and not a parallel one?
    One other thing to think about is: What happens to th 12V side of the electrical system if you disconnect the ground strap to the battery? Does the starter still work since it's got +12 on one side and it's still connected to "ground"? No. It doesn't work because the electrical source is no-longer connected at both sides (+ and -) to the load (starter).
    On the 12V side, when the bike is not running, the battery is the source of electrical energy. Current flows from the battery's - terminal, THROUGH ground, through a load (like the headlight), through a closed switch or relay, and back to the + terminal of the battery. Ground is not a destination, it is just a connector between the - terminal of the battery and one side of the load.
    On the high voltage side, the secondary of the coil is the source of electrical energy. Current flows from one end of the coil to the other. Ground is in the middle of this circuit, not at one end.
    If you search on wasted spark and "in series" you'll find several articles that describe how it works. Here's one: http://findarticles.com/p/articles/mi_q ... i_n8876015
    Paul
  34. kd5uzz
    kd5uzz Member
    Bill,
    I think you are correct in that the plugs can fire as the TCI 'charges' the coil, but I don't think that 'fire' will be nearly as strong as when the field collapses. And yes, it would 'change directions' based on the charge/discharge cycle of the primary coil.
    When the TCI 'charges' the primary coil it does so at a fixed voltage and current (lets just think of it as power), simply because the XJ's electrical system can only supply a specific amount of power. And it 'charges' at a finite rate (don't make me get my circuits textbook..).
    On the other hand, when that field collapses there is nothing, except the resistance of the wire, holding that charge back, so it all 'dumps' instantly.
    Think of it as walking up a mountain that has a sheer cliff on the other side, with a rock. You walk up, one step at a time. Each step is getting you higher and higher until you are at the top of the mountain. Once there, you drop your rock down the sheer face of the cliff. It drops much faster than you climbed.
  35. Pernig
    Pernig New Member
    United Kingdom
    Fixed it guys :D. Full battery and a dry, windy day later and everything is back to normal. The coils weren't a problem after all. Think I'm going to spend my next day off putting a blade-style fuse box in and tidying up/winterproofing the wiring under the seat.
    Cheers for all your help people, and sorry for leading you off on the wrong trail. I will continue to monitor the condition of the coils, and am gonna do the resistance checks stated in my workshop manual to check that they're up to scratch.
  36. SQLGuy
    Good to hear.
    I'd still check the spark plug boots and replace them if they don't look too good. If they do look OK, they may still want a bit of dielectric grease to help keep moisture out.
    Cheers,
    Paul
  37. bill
    bill Active Member
    Raleigh, NC
    Agreed - collapse greater than charge given the systems resistance. I was thinking of a standard transformer with no real difference in the charge vs discharge which will have relatively equal but opposite in phase currents.
    Given the nature of the TCI (which does not match my original assumption) and the circuit then I have to conceede I don't see a way for one to fire without the other.
    Paul's explanation is very good. I was coming from a different prospective, which doesn't make it any less wrong :D
    I learned something new today.
    I did pull something out of Paul's reference
    The voltage capacity of a DIS coil is high enough, however, to ensure that the available voltage is always high enough to fire the plug with reversed polarity when it's on the compression stroke.
    Is it possible with a weak or wet coil that there is enough voltage to fire the "normal" plug but not the reversed plug?
    Obviously we are seeing strange things that indicate this and the solution to this problem appears to be a dry day and charged battery....
  38. kd5uzz
    kd5uzz Member
    I've always had problems getting my XJ to start after it has been sitting in the rain. That said, I did once make the drive from Stillwater to OKC (~70 miles) during a downpour (my first time to ride in the rain...lets hope it was the last.) The bike ran great, but it was already running when the rain really started. This was after I got 20miles froms Stillwater and had a quick connect ground itself against the altenator cover, getting me stuck on the side of the road without any idea as to what was wrong. An hour+ later, after getting a ride back to STW to grab the truck, gas it up, and get the bike back home, it took 5min to find the problem and get back on the road. Without that delay I would have made it to OKC without the rain. I'm pretty sure that was the last time I drove the truck. It won't start now, the battery is dead.
