What Not to Do to any bike
Discussion in 'XJ Technical Chat' started by taildragger, Nov 11, 2008.
  1. taildragger
    taildragger Member
    Here's some pics of previous owner's handiwork on his former XJ550.
    Best described as:
    "What Not to Do" to any bike.
    This could have been fatal ....
    See the melted blob below battery case.
    POS (+) Battery Terminal made contact on frame.
    Incorrect routing, wrong battery ...
    XJ550 Petcock control knob cut off at Prime (look carefully at small arrow on right). No vacuum, no problem ...
    Let's see, do a little a cut here, add a line there, fuel everywhere ...
  2. danno
    danno Member
    Union Springs,New York
    Re: What Not to Do on any bike
    The petcock in the photo is on reserve,not prime,but I get the idea.Looks like it is set up for terrorist activity.
  3. bill
    bill Active Member
    Raleigh, NC
    Wow is this the same bike with the modified loom? Amazing!
  4. taildragger
    taildragger Member
    Sad but true - its the same bike with the faked "Pseudo Harness"
    I did not try to ride it home ...
  5. bigfitz52
    look at the stops. It's on "PRI" alright, you were fooled by how the lever is cast. TD, welcome to the wonderful world of the PO. With everything you've discovered so far, beware of inappropriate fastener substitution, another common PO nicety.
  6. schooter
    lol is that the tank the pos cable was arcing one?
  7. danno
    danno Member
    Hey,chacal,what position is the pictured petcock frozen in? I am quite sure you can answer this. I still say that it is on reserve.
  8. manufan
    manufan Member
    Brackney,Pa
    If it's a vote, I say reserve.
  9. taildragger
    taildragger Member
    Arcing occurred under right frame rail just inches away from the leaking petcock. After finding the meltdown under the battery box I wonder how the PO stayed alive long enough to sell his bike.
    Also found 4 - 12 mm nuts rattling INSIDE the fuel tank. Petcock was "frozen" by PO using Gorilla type glue cause he would not (or could not) repair the petcock. Downstream from the always-on petcock was a Briggs & Stratton inline fuel shutoff valve (like ones found on lawnmowers).
    I'm rescuing this top-running bike from an early grave. Maybe its because this XJ550 has all of 2,940 miles on the clock and puts a big grin on my face.
  10. TIMEtoRIDE
    I vote "reserve". . .
    That's a pretty clean looking bike!
  11. organizedinsanity
    organizedinsanity Member
    Its definately on reserve. Look at the stop on the top of the petcock.
  12. danno
    danno Member
    Thank you!
  13. bigfitz52
    You're right. It's fully clockwise against the stops, so it is on reserve. I stand corrected. If no vacuum line and the bike would still run, then I suspect petcock's innards got buggered as well. I feel your pain. My '83 only has 7100 miles on it, which is why I snapped it up, but I have found all sorts of hidden surprises. Look at it this way: When finished, it's gonna be like having a brand new 27 year old bike which is an awesome feeling.
  14. Galamb
    Galamb Member
    Acton, Ontario
    I agree, it does look that it is on reserve. But if it would have been on prime, the engine oil would have been full of gas.
  15. taildragger
    taildragger Member
    Columbo ...
  16. bigfitz52
    Yep, it could have been reassembled incorrectly, or was just locked on "RES" for some unknown reason. The worst part of all of it is that installing an airbox (they're not hard to find) will mean yanking the motor. Remember that bright side: Less than 3K miles on that sweet little mill...
  17. taildragger
    taildragger Member
    Pull the engine to re-install an Airbox eh? hmm
    That sounds like fun.
    Got a clear Title on her today ... took it around the block last night. After a warm-up this bike runs fantastic. Though its no 750 - for a stock low-po xj550 it runs super.
    Blew 10A fuse in brake light circuit even though its wired direct to the battery so I ordered a new rear Brake Light Switch from Georgefix. There's also a possibility the Rear light fixture's ground (-) is no good.
  18. bigfitz52
    Once you get it running 100% it will damn near keep up with a 750, and the chain vs. shaft efficiency advantage gives it the edge over XJ650s.
  19. clhannah
    clhannah Member
    Portland, OR
    Wow -- and I thought one fuse soldered in place and another one shorted out was bad!
