Suspension question
Discussion in 'XJ Technical Chat' started by CampinCracker, Dec 5, 2008.
  1. CampinCracker
    CampinCracker New Member
    North Texas
    I was thinking about doing some suspension like this and I was curious if this would work alright. The only problem I can really see is finding a spot for the battery and the electronics but here are some pics of what I was thinking about. Helpful comments are welcome.
  2. mozark
    mozark Member
    Springfield, MO
    This could be a real safety issue without redesigning the swingarm to handle the additional stress
  3. TIMEtoRIDE
    Measure the distance from the swingarm pivot to the lower shock mount.
    If you cut that distance in half, you need to double your spring.
    Cut it in 1/4 and you need 4 X the spring.
    Then the shocks don't dampen enough due to the small travel.
    You'd need the monoshock from a big bike, and stiffen the swingarm to take the load, or install the back half of a chain drive cruiser from a junkyard. Your welds would be under the motor and under the tank.
  4. MiCarl
    This is an excellent point that can't be stressed too much. Normally the shocks carry the weight of the bike and the swingarm just keeps the wheel in the correct position.
    In addition to the swing arm you might also have to beef up the frame in the swing arm pivot area.
  5. RPCVFR
    RPCVFR Member
    Sioux Falls, SD
    you are going to need some very very stiff springs to hold things up that close to the fulcrum / front pivot. A pushrod pivot point ould be ideal here take a look at the VFR800's setup that might give you an idea of what you could work with.
  6. TIMEtoRIDE
  7. xj650ss
    xj650ss Member
    Calgary, Alberta
    that is very cool!
  8. Zookie400
    Zookie400 Active Member
    Connecticut
    i think it looks badass, and has the potential to ride much nicer pending the shock valving/spring rate you use is correct for the geometry.
    this is where you may want to look closely at MX bikes. things like swapping out the swingarm bolt with a stronger one, and gusseting the frame around the shock mounts as well as the swingarm for the different stress you will pe butting on it may be things to consider.
  9. wizard
    this will not improve the bike at all, you can't use those springs, you need a big diameter coil, best to pick up a frame with these features & mount your lump in it.
  10. CampinCracker
    North Texas
    Thanks for the thoughts guys, it seems it will be to much trouble so I am just going with the hardtail hope to have it done this week
  11. bigfitz52
    Hardtails LOOK cool but can be a TAD uncomfortable to go any real distance on...
  12. Zookie400
    Connecticut
    PICTURES PLEASE!!!! :)
  13. Kickaha
    New Zealand
    Every bike has the potential to ride much nicer with the correct shock valving/spring rate but how many people actually bother with it
  14. Zookie400
    Connecticut
    well....no arguing that :)
  15. TIMEtoRIDE
    You have 7 days. . . 8O
  16. xj650ss
    xj650ss Member
    Calgary, Alberta
    before you start chopping check out other bikes forum there is a 1983 gr650 project that has a factory rear like you want don't know if it will help but it's always more satisfing to built what you want rather than what you know how! just a thought
    S.S
