Foot clutch and jockey shift on a maxim?
Discussion in 'XJ Modifications' started by chopper716, Jan 13, 2009.
  1. chopper716
    chopper716 Member
    Victorville, CA
    Has anyone here done it?
  2. Deadulus
    Deadulus Member
    Dufur, Oregon
    Re: Foot clutch on a maxim?
    I havent seen a foot clutch, but I do remember someone using a spare set of handle bars as a suicide shifter and incorporating the clutch on it.
  3. chopper716
    chopper716 Member
    Victorville, CA
    I saw that as well, but I'm more into the foot clutch.
  4. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    That would be a tricky one to ride. I remember seeing a foot clutch on some of the older bikes (from way back) and I appears to be quite unsafe to ride one. Why would someone even want to go that route? Why do you think they use hand operated clutches an all bikes now?!
  5. chopper716
    chopper716 Member
    Victorville, CA
    Well for one it's different, B.) less of my friends will ask me if they can ride it, and three I think it looks cool. :D
  6. PainterD
    Ya OK. I guess you'll find out how 'cool" it really is. To each his own.
  7. chopper716
    chopper716 Member
    Victorville, CA
    oh and D.) it will be harder for the punks around town to steal. They'll hop on and not know what the hell to do. :lol: :lol:
  8. bigfitz52
    THINK ABOUT YOUR RIDING "RHYTHM" foot clutch has to also include hand (tank) shift. You can't clutch and shift and brake with your feet. If you "reassign" a function from hand to foot, something else has to be reassigned.
    The reason hand-shift on the tank and foot clutches went away is high-RPM motors that require a QUICK shift. Both of those functions, when changed as being discussed, TAKE LONGER. The tank shift lever would have a LONG-A** throw compared to the foot lever, and a foot clutch would be the same.
    It worked great on a '26 Indian, but I dunno about your XJ...
  9. grmeyers
    grmeyers Member
    Asheville, NC
    If the rider doesn't have a left arm. :lol:
  10. TIMEtoRIDE
    Chopper- - how about a right foot clutch, left foot shift, left hand rear brake???
    That should meet the need to be different and keep it reasonably simple.
    Just don't do this to impress the Harley croud, because they won't be. . .
  11. Turkey
    Turkey Member
    Wendell, NC
    I think it would be cool. I think you would need to find one and make it work. I imagine you would be the first to put a foot clutch on a maxim. I don't see why it wouldn't work just fine once you learn to ride it
  12. bigfitz52
    ummm...front brake? You know, the one that's like 70% or more of your stopping power? if you're gonna DO AWAY with anything, do away with the rear brake or LINK the brakes to work from one control.
  13. alkasmeltzer
    alkasmeltzer Member
    Lincoln, NE
    I think Turkey means to leave the front brake with right hand controls? Rear brake and clutch would essentially change postions with his idea. I may be wrong. It's happened before.
  14. chopper716
    chopper716 Member
    Victorville, CA
    I'm looking to do a jockey shift with a foot clutch, I know it can be done. Just trying to get ideas. Thanks for all the input.
  15. T0MCAT
    T0MCAT New Member
    CRACKIMA, WA.
    Speakin strictly as an old harley cat who has ridden jockey shifts
    for years, im here to tell yall that its not that hard to ride and is actually
    quite comfortable once yer used to it, and preferred by many.
    That being said im in complete agreement that it has no place on an XJ.
    The difference here being the ridiculous power curves of the motor....
    Fitz is right chop, ya gotta bang the gears too fast to make a jockey
    practical with an xj motor....ever see one on a crotch rocket?
    ....Bout the same. Fast power, not sluggish like a twin.
    Hell, im even throwin a friggin front brake on mine!!! 8O
  16. Turkey
    Turkey Member
    Wendell, NC
    http://cgi.ebay.com/ebaymotors/HARLEY-J ... ccessories
    might be able to rig this to work.
    It might not be the best Idea, but the fact is it will work. If you have problems with the long through you can rig it for a shorter throw. Connect the bottom of your jocky shift to the shifter similar to the picture below.
  17. Turkey
    Turkey Member
    Wendell, NC
    the joint between the shifter and jocky shift would have to be able to slide up and down, longer and shorter
  18. TIMEtoRIDE
    I meant keep the front brake, of course. . .
    Mount a mechanical starter button, where you kick some contacts closed.
    Hide all switches under the lip of the tank.
    Honda made a throttle where the cable stayed inside the handlebar, on an old dirt bike. Just an idea if you want impossibly uncluttered bars.
  19. XJ89
    XJ89 New Member
    Langley BC
    is there anyway to do a dual clutch leaver one on the bars as well as the shifter ??
  20. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    Foot clutch and suicide shifters are sweet. Post pics of yours when you are done
  21. Kickaha
    New Zealand
    In that case he puts the hand clutch on the right hand side with the brake, two guys here have bikes set up like that as although they have left arms due to nerve damage they dont work
