clutch 911
Discussion in 'XJ Technical Chat' started by chadly89, Jan 21, 2009.
  1. chadly89
    chadly89 Member
    brownsvalley california
    i need some help here on putting my clutch back together, i read on another forum that you can take the clutch out and clean up the friction disks , and since my bike was sitting for about 5 years before i rebuilt it i thought it would be a good idea to take the clutch apart and clean it up on the next oil change, so i took it apart and the friction disks were all gunked up and glassed over with old oil so i took some 400 grit sand paper to them and cleaned them all up, and i looked at putting it back together and i noticed that on the metal disks that go between the friction ones are not perfect circles, each one has a kind of taper on one edge and a tab on them, i am sure that this is for some sort of balancing and my question is... what pattern or order do they go in, and also there was a smaller black ring with three tabs on it, and this just seemed out of place because there was only one of them, and help would be great, thanks
  2. chadly89
    chadly89 Member
    well thanks for the help....... i just put it back together the way i would for my dirtbike, and ill find out tomorrow on my way to work if it will hold up or not
  3. RickCoMatic
    Hope it all worked out good.
    On Bikes that have done a full Rip Van Winkle ... it's good to get in there and do as you did for the Friction Plates ... but, ... also take a Dual-Action Sander and put a nice new surface on the Driver Plates, too.
  4. bigfitz52
    Here's how it goes together: That "tab" needs to be spaced every 72 degrees; in other words, the first one goes at the top, the next one goes at about the 2:00 poisition, the next one at 4:00 etc., all the way around. If you line them all up together the clutch will be horribly out of balance. That strange black "ring" you found (kind of like a giant wave washer) goes inside the one plate that has a larger ID to accomodate it. It goes in the "outer middle" of the pack, in the sixth position; in other words it is the third plate in from the outside.
    If this still doesn't make sense I can post up (or email you) a copy of the plate placement diagram. The "tabbed" plates were used in the 550s (which I have) as well as the XJ700 I believe, you didn't say what you have.
  5. chadly89
    chadly89 Member
    that makes perfect since, and strangly enough thes how i put it together... huh...
