550 Owners chacal and I would like your input please
Discussion in 'XJ Technical Chat' started by bigfitz52, Dec 31, 2008.
  1. bigfitz52
    We're especially interested in LATE 550 owners, especially Seca but Maxim too. If you could post your MODEL year, "shortie" VIN (the model/serial off the top of the motor will do) and DATE OF MANUFACTURE (month/year on the label on the steering head) it could be very revealing and greatly appreciated. For example: "83, 4U8-100960, manuf 5/82" (my bike.)
    We are really looking at 550 Seca numbers but 550 Maxim numbers will help too; the LATER the better but really, the more responses the better.
    I'd really like to find a later 550 Seca than my '83, and we'd REALLY like to figure out when they were made.
    No ulterior motives, this is a "production history" research effort.
    If we can garner enough responses to produce some real data I will post the results.
    Thanks in advance---Fitz
  2. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Mine is one of the first ones off the line. Manufactured 10/80. Serial # 4U9000109. I believe that makes it the 9th unit produced for the Canadian market. It came stock with a block heater and winter antifreeze. :lol:
  3. bigfitz52
    Wow. My '81 was made in 12/80, it's in the 5xxx (I forget I'm at work it's at home.) Apparently my '83 is the HIGHEST serial number for the 83 MY that chacal has found. Looks like there weren't many 550 Secas made for the 83 model year.
  4. kd5uzz
    kd5uzz Member
    RangerG,
    My first impulse was to ask you about the block heater..then I saw the mention of antifreeze...
  5. lostboy
    lostboy Well-Known Member
    Tillsonburg, Ontario, Canada
    RangerG
    Mine was not too far behind yours on the assembly line 4U9-000193! But located on the other end of the country. I do not have the manufacture date.
  6. schooter
    now, puttin a block hearter on a bike is dumb, imo, if you need that to start up your bike then you shoudnt be riding, unless you have studs and are riding in a circle..
  7. stereomind
    stereomind Active Member
    Tulsa, OK
    My Maxim is an '83, 5K5-100977, manuf. 6/82.
  8. fjpish
    fjpish New Member
    New Jersey
    My '82 Seca is #4U8-025011; Mfr date: 0/82
  9. bigfitz52
    And it's a "true" 82? What color is it and did it come with a fairing?
  10. chacal
    Fjpish......could you look again at that VIN decal, and double-check the build date? "0"/82 is not really a good number, since there is no "0" month!
  11. fjpish
    fjpish New Member
    New Jersey
    Oops! Sorry guys. My bad. 82 Seca #4U8-025011 Mfr date is 3/82, not 0/82.
  12. Captainkirk
    Captainkirk Member
    Northeast Illinois
    Mine is an '81 XJ550R with VIN 4U80016(XX)
  13. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    not sure if this helps but it was in my service manual i just picked up.it's a seca 4u8-001259. I'll post my maxim vin's if they will help any.
  14. 550maxim
    550maxim New Member
    mississippi
    mines a 1982 550maxim.......#5k5-025822......I'm having trouble getting a title because the title is lost and the dmv needs a 17 digit #....two digits are missing......jya5k_ _01ca025822....HELP!!! the _ _ are the 2 digits missing...how can i figure this out???? any suggestions?!?! the guy i bought it from is not the original owner(on the title)?!?!
  15. chacal
    550---those two digits will be 50 (five zero)
  16. 550maxim
    550maxim New Member
    mississippi
    you the man!!! THANKS!
