Perf enhancement for that certain part of a man's motorcycle
Discussion in 'Hangout Lounge' started by wamaxim, Feb 12, 2009.
  1. wamaxim
    wamaxim Active Member
    Vancouver, USA
  2. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Might be fun untill you melt the pistons
  3. wamaxim
    Vancouver, USA
    Probably but talk about going out in a blaze of heavenly glory!
  4. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Re: Perf enhancement for that certain part of a man's motorc
    The subject line for this thread was HILARIOUS!!
    "Check out Bob!" "When he twists his wrist these days, things are more exciting... down there." "He's going to need new rubber." "His girlfriend is enjoying the new power between his legs."
    Thanks, i needed that.
  5. hammerheadx
    hammerheadx Member
    Binghamton, NY
    “All his friends can’t keep it up with him.”
    Somebody's GOTTA make this commercial.
  6. TwoWheelFiend
    TwoWheelFiend Member
    nitrous is absolutly safe and will not harm your motor if set up correctly.
  7. TwoWheelFiend
    In faact im going to put a 50 shot to my Seca
  8. sushi_biker
    sushi_biker Member
    Crack and Meth are perfectly safe if administered correctly too. :roll:
  9. TwoWheelFiend
    ignorance is bliss, huh?
  10. FLASH4
    FLASH4 Member
    On the back wheel, in AUSTRALIA!
    Its not the Nitrous (its not nos, nos is a brand :) ) that you have to worry about if its in small doses, say 50hp. Its the extra fuel needed to support the Nitrous. That's the biggest issue faced with carburetted bikes. How do you supply the extra fuel when you hit the nos when you don't have a fuel pump. It would be allot of stuffing around.
  11. Robert
    You could say that. These and other substances would not be the problems they are if folks would simply apply common sense. Too much of anything is bad for you, plain and simple. Moderation in all things is paramount to good living. Heck, even nuclear waste can be tolerated (though common sense tells me I don't want anything to do with it) by the human body. Ignorance may be bliss but it also injures, maims and kills countless people every day. Darwinism at its finest if you ask me. Knowledge is power!
    Live better... read a book.
  12. TwoWheelFiend
    not really, you use a solenoid valve and injector, for carb's bikes you use an adjustable preassure regulator, just run a t- fitting off your fuel supply line
  13. TwoWheelFiend
    I agree, moderation is key. I believe everyone should have the right to decided what they want to put into thier bodies. Wether is crack, pcp, pot, alcohol, or coffee.
  14. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Since i assume you're not going to reduce the compression ratio in your XJ, how do you plan to retard the timing when the NO2 hits, to prevent detonation?
    Or is that only with blown engines?
    I've never worked with NO2. Just big block chevy's and alcohol. (where you can actually get away with MORE advance.)
  15. TwoWheelFiend
    if your timing is set correctly you should have to adjust it. You can also adjust the ammount of nitrous going into the inlet during the combustion phase.
  16. FLASH4
    FLASH4 Member
    As i said im talking carburetted bikes, the don't have a fuel pump. The tank is gravity feed to the carburetors. Which wouldn't have anywhere near enough pressure to flow through an injector, it probably wouldn't even flow through the solenoid. Also how will you control the injector? will you have 1 per cylinder? are you going to run an ecu to drive the injectors?
    A Fuel injected bike is a different story.
    The Zex kit on my car requires a minimum of 48lbs of pressure and 200lpm flow to supply the correct amount of fuel, and that's only for a 75hp shot.
  17. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Crank the choke on, hit the button :)
    lol, i call it, RedneckNOS (c) ;)
  18. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Nice, I wonder would that dump enough fuel for a small shot of nitrous?
  19. TIMEtoRIDE
    The enrichment circuit (choke) really doesn't do much of anything at WOT, so, no it wouldn't work.
    (and it's N2O. . .)
