Horse power!!
Discussion in 'XJ Technical Chat' started by rotax74, Feb 27, 2009.
  1. rotax74
    rotax74 Member
    ROME,NY
    alright i got it in my head that i want pod air filters. despite everyone saying dont do it and reading other forums. i have a 4 into 2 exhaust with aftermarket muffler tips with only steel baffles. i believe a lot more air flow than stock mufflers. i have not changed jetting for this and runs good. when i buy the pods should i buy the dyno jet stage 3 kit also. and if anyone would like to fill me in on how this kit works. im planning on having my carbs all redone professionaly so i will have them install the jet kit. thanks for any info.
  2. midnightblu
    midnightblu Member
    Austin, TX
    i think i remember seeing a forum post saying that the YICS engines like to have a little back pressure. i also have been looking at the jet kits but you end up in a bit of a quandry. for my bike the XJ700 you cant find anything except a stage 3. i think your gonna kick your self later for the ammout of time and money you invest to get a possible marginal increase of power in doing so your going to kill your fuel mileage and your going to have to work with some starvation issues.
  3. sushi_biker
    sushi_biker Member
    (waves hand like a Jedi)
    "You do not want pod filters"
  4. dqnjuan
    dqnjuan Member
    bmore, md
    what bike are you riding?
    Pods and exhaust are def marginal hp improvements if usually any, and as you know a b*tch to tune. You will gain some improvements somewhere and lose some other places.
    If you have a good airbox maybe just try a k&n filter in that, unless you really like the pod look then have fun on your journey.
    You want more hp how bout an engine swap :D
  5. rotax74
    rotax74 Member
    ROME,NY
    i have a 1981 yamaha seca 750. i can care less about mileage i went all summer long averaging 32 mpg.
  6. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    I have a maxim 650 with a 4-1 exhaust that except for a little restriction at the end of the muffler for back pressure is wide open. Stock air filter and stock jets and it runs and sounds like a monster. I run right with my buddy on his hyperchargered, power commanded, and vance and hines piped VTX1300 with no problem. In fact, except for a very slight lag off the line that can probably be fixed with a little fine tuning, my 650 is faster than his vtx1300. I would vote no on pods and try a k&n filter. The results are probably close and you won't bog down if you get caught in the rain due to wide open pod filters sucking in water. Just my humble opinion.
  7. dinoracer
    dinoracer Member
    Chattanooga, TN
    The problem with a stage 1 or 3 kit from dynojet is that the jet numbers do not correspond with either Mikuni or Kehin main jet numbers. So if you find yourself a bit lean and go to the local parts house with a dynojet 132 that is too lean and get a 135 mikuni or kehin main jet, you might find yourself way to fat or still lean.
    Good luck with it
    Sean
  8. southpaw
    southpaw Member
    new york
    rotax skip the pro rebuilder and do it yourself #126 main jet,#43 pilot jet and shim the needle up .050" then sync it hit ti with a color tune if you have one take it and enjoy
  9. huckersteve
    huckersteve Member
    Seattle, WA
    I like southpaw! Hi-Five!!
  10. dawsoner
    dawsoner Member
    Boulder, Colorado
    I have pods and have gotten as high as high as 62mpg
  11. maxhog650
    maxhog650 Member
    Boulder, Colorado
    If your only in for the look why not build a pvc manifold like amcwood, i just did and it works great, easy to remove, clears up space, and looks tottaly b*tchen
