nagging question in the back of my mind
Discussion in 'XJ Technical Chat' started by etg29, Mar 2, 2009.
  1. etg29
    etg29 Member
    Normal IL
    ok this ones been on my mind for a little while:
    if your cams where shot and you bought a new set off fleahbay or craigslist how would you know how to reseat the cams so that the the exhaust/intake happens at the right time, because according to my mind logic(which is off a lot) if you did not get your cams in exactly the right position it would make your engine not run or run like s**t.
    am i off on my logic???
  2. Ltdave
    Ltdave Member
    dont the cams have witness marks for alignment with a timing chain gear?
  3. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    they should
  4. mykl8
    mykl8 New Member
    Slave Lake, Alberta
    Yes I'm pretty sure they have stamps... or the three bolts on the cam gear are offset.
    I cant remember, its been about 3 years since I overhauled mine.
  5. Zookie400
    Zookie400 Active Member
    Connecticut
    most engines i have seen have identifying/aligning marks, i have worked on KTM engines that have marks on the chain that line up with dots on the sprockets.......i have not cracked open the seca yet but i dont see why it would be any different
  6. MiCarl
    I believe the XJ cams have a punch mark that is to be aligned to a similar mark on one of the bearing caps. Then you align the correct marks on the timing plate and put the chain on.
  7. Robert
    ^^+1 MiCarl.
