Filing a complaint to Yamaha
Discussion in 'XJ Technical Chat' started by midnightblu, Mar 4, 2009.
  1. midnightblu
    midnightblu Member
    Austin, TX
    on my way to work yesterday the my 1985 xj700 went from ok to poor running after about 30mi. i nursed the bike home at the end of the the day only to find that cyl 1,2 and 4 were leaning out. checked the compression and all was good (within 1 -2 psi) pulled the carbs all clear there too. hmmm time to check the intake boots .... i pulled them off to find the factory original seals installed ( missing some chunks) and nearly welded to the boots. i had to boil the boots for 40 min before i could cut them loose with a razor from the metal plate on the boot (it was like cutting rocks with a butter knife).
    I am thinking of composing a letter to them letting them know about this substandard equiptment i found on my bike failing after 24.5 years
  2. bill
    bill Active Member
    Raleigh, NC
    I'm sure they will promptly refund your purchase price :lol:
  3. midnightblu
    midnightblu Member
    Austin, TX
    You know your probubly right they would probubly send me a check in the ammount of 16 cents and ask for the seals back to inspect the reason for the failure :D
  4. hammerheadx
    hammerheadx Member
    Binghamton, NY
    Do you think a soldering gun, with the attachment used to cut poly rope would have knifed through the boots? You know, the flat blade attachment that burns through the rope and cauterizes it at the same time?
    I've used my to cut rubber and small plastic pipe before.
    That's literally a hot knife!
    Just a thought...
  5. midnightblu
    midnightblu Member
    Austin, TX
    well they are paper gaskets that i was having difficulty with so i dont think that would have worked.
  6. oldskoo11
    oldskoo11 New Member
    Islamorada, Florida
    wow. its kinda funny. i have an 85' xj 700 and the same thing happend to me last month. couldnt figure out why the damn thing was idleing at like a million rpm. that could blow a motor up. they should deffinatly hear about this.
  7. midnightblu
    midnightblu Member
    Austin, TX
    it reminds me of a buddy of mine that had a 88 mazda pickup that had its first chutch change at 248,000 miles, it had been used for the first 10 years of its life as a landscape company truck by his brother.
    These Japs just dont know how to build with quality parts.
  8. hammerheadx
    hammerheadx Member
    Binghamton, NY
    I'm sorry mid.
    I thought you were saying that the boots themselves were so hardened with age that they were impossible to work with.
    Never mind.
    Subtract 5 points from my score for not paying attention...
    :lol:
  9. midnightblu
    midnightblu Member
    Austin, TX
    Note Taken..... :D ... its ok man i think i am becoming infamous for not providing enough information :D
