matte black
Discussion in 'Hangout Lounge' started by airborne82, Mar 6, 2009.
  1. airborne82
    airborne82 Member
    ATL
    does anyone know were I can buy some matte black paint. Or is it just black then a matte finish
  2. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Should be able to get some from an auto parts store in a spray can.
  3. jdrockin
    jdrockin Member
    WI
    Hardware stores in WI sell 500* ceramic engine enamel by DupliColor in "Low Gloss Finish" Check around, you should be able to find it.(If this will work for you)
  4. dwcopple
    dwcopple Active Member
    bay city, michigan
    matte is usually called satin, flat is flat...there is a difference
  5. Ace_Frehley
    Ace_Frehley Member
    NS Canada
    Its good to keep in mind that the flater the paint the less durable it will be, so the prep work becomes even more important
  6. Hack
    Hack Member
    Ontario, Canada
    I really like the flat black look, and found this in my local auto parts store:
    Dupont
    Hope this helps,
  7. 85MaximXX
    85MaximXX Member
    S.W. michigan
    you could go either way a matte black or black than do a matte clear coat over it to help protect the paint.
    http://www.krylon.com/products/matte_finish
    Here's krylons version but I am sure others make a version as well
  8. bigfitz52
    Duplicolor's "low-gloss black" engine enamel is a DEAD RINGER for the semi-gloss black Yamaha used on things like valve covers and wheels.
