Will a set of 11.5 in shocks off of a sportster work?
Discussion in 'For Sale, Trade/Swap, Wanted' started by Strick, Mar 11, 2009.
  1. Strick
    Strick Member
    Ft. Eustis, Va
    I have found a set of shocks off of a sportster and i was wondering if they will work on my 1985 700 Maxim? I want to lower the back just a little. These shocks are only 50 bucks.
  2. flash1259
    flash1259 Member
    W.R. Wisconsin
    If the shock has the same mounts eyes it should work . question how long are your stock shocks? Don'r drop too much your bike will most likely bottom out
    I have a single( monoshock ) shock on my xs400j want to lower the rear about 1.5" my stock shocks ar 13 3/4 " gonna be hard to find a shock thats 12"
    I found a guy who chops shocks as a business but he says its impossible to do my shock as it is designed. maybe I will try to find a dirt bike mono shock and send it to him to chop for me.
    http://www.skullmanonline.com/shock-shortening.html
    his prices are reasonible since shock new are about 400 dollars a piece
  3. mlew
    Harley shocks have larger eyes , the width of the eye and diameter of the mounting hole is much larger. The spring rate is much strongeralso. Remember that a Harley is much heavier that your Maxim, It takes more spring pressure to hold it up. I purchased a pair for a project and had to modify the eyes and change the springs. You can try them but be prepaired to do some work on them, bettef off finding the right pair.
  4. mopheos
    mopheos New Member
    I bought some Harley shocks off ebay that are 10.5" eye to eye, and with a few mods I got them on fine. I had to replace the metal sleeves inside the rubber grommets, as the stock sleeves were a hair too small to fit on my stock shock studs. Half inch copper water line worked perfectly. I also had to shave the right bottom shock eye to get a good fit in the U shaped bracket on the swing arm. Other than that, they fit sweet.
