spray bomb clear coat
Discussion in 'XJ Modifications' started by Ltdave, Mar 24, 2009.
  1. Ltdave
    Ltdave Member
    does the clear coat in a bomb include any kind of hardener so that it wont chip off easily?
    im also thinking for those moments when i might get distracted (like the 20 something flat-belly getting filling her car the same time im topping off the bike) and i accidentally spill a little bit of gasoline...
    im considering rattle canning my seca since it might be easier to to do while the panels are all on the bike (so i can get the lines to match up)...
  2. LoneWolf200242
    LoneWolf200242 New Member
    New Hampshire
    The clear coat in a spray bomb does not have that hardener to actually protect a fender or gas tank, its easily chiped and any little bit of gass will strip it. Tried it on a friends mini chopper once, was great till we spilled a little gass on the tank.
  3. Desinger_Mike
    Desinger_Mike Member
    Eastern Pennsylvania
    You gotta get this stuff
    http://www.uschem.com/index.cfm?page=pr ... =141&pid=2
    It has a cavity inside that you rupture and release the hardener into the can. Supposed to be same quality as the real automotive stuff.
    The nozzle is very good for a rattle can.
    It isn't cheap though!
    Best price I could find was $17.40 here:
    http://www.repaintsupply.com/pd_2_part_2k_aerosol.cfm
    I did mine last spring and it still looks like new (even after a couple splashes of gas).
    You only get about 6 hours before it hardens too much in the can.
  4. LoneWolf200242
    New Hampshire
    Mike thats some cool stuff, I'll have to give it a shot. Think they sell it at walmart?
  5. Desinger_Mike
    I looked far and wide to find it last year...only to be able to get it at amazon.com!
    Some of the body supply shops can get it, but I just found it a lot easier to order online and have it on my door step in a couple days.
    Very much doubt whether walmart would stock anything that cost them more than $1 a can and wouldn't sell 16 billion cans a month. (sorry, not a walmart fan)
  6. midnightblu
    midnightblu Member
    Austin, TX
    i have read that the aluminum and mag clear is harder and more resistant then regular clear... at $6.00 a can i'll have to test it... if nothing else i'll use it on the kiddo's pocket bike.
