Front wheel bearing seals
Discussion in 'XJ Technical Chat' started by goser, Mar 27, 2009.
  1. goser
    goser Member
    Waterloo, Ontario
    I think it's time to replace my front wheel bearings, and I'm a little unsure about reusing the seals. If I replace the bearing with a 6302RS, the bearing is already sealed so are the other seals redundant? Thanks!
  2. Robert
    The redundancy is a good thing, get the new seals. Full kit for your front should run you under $40 from Chacal.
  3. goser
    goser Member
    Waterloo, Ontario
    Thanks for the reply, one of those areas not to skimp on i suppose.
  4. TheHound
    TheHound Active Member
    Scotia, NY
    Yes, buy the kit with the seals included you are talking change to get the seals with the bearings.
    The speedo drive side is lubed if nothing else it will keep dirt from the dogs.
    Give yourself some time an room to curse.
    I just did mine and it sucked with a capital S.
    I would do ten steering head bearings before I did another wheel bearing.
  5. Robert
    It is a PITA to remove them I'll agree but the right tools make quite a difference. I purchased Harbor Freight's blind hole bearing puller (http://www.harborfreight.com/cpi/ctaf/d ... mber=95987) and, after following the included instructions, got them out with a minimum of fuss.
  6. TheHound
    Scotia, NY
    A puller is the way to go.
    Definetly!
