1982 xj650j maxim intake manifolds
Discussion in 'XJ Technical Chat' started by corgitwo, Mar 30, 2009.
  1. corgitwo
    corgitwo Member
    GRAND RAPIDS, MI
    I'm confused. I'm trying to replace the cracked rubber intake manifolds for #1 and #2 cylinders. My Yamaha xj650j parts list shows 1 part # for cylinder 1 and 2, and another part # for cylinders # 3 and 4. However the drawing shows all 4 tilting the same way. On the bike, this is not the case. The #1 and 2 the bolt pattern is tilted to the left and #3 and 4 is tilted to the right.
    Is this making any sense to anyone?
    Yamaha parts list shows part # 5G2-13586-01 for cylinders 1 and 2
    it shows 5G2-13596-00 for 3 and 4
    I keep seeing ones with the part number 4h7-13586-02-00 being listed on Ebay as the left side. However, looking at the picture of it, it is clearly the right side.
    Maybe there is a difference between years?
    I'd order a set from chacal if I knew positively that they would be the right ones, but his hcp # doesn't tell me if it is the same as the factory manual #, so I'm a little hessitant to drop $100 fot 2 without knowing they will be the right ones.
    Any help would be greatly appreciated.
    Signed: confused and frustrated
  2. Polock
    if you order them from Chacal they WILL be the right ones !
  3. ethanch
    ethanch Member
    Spokane, WA
    yes, get them from chacal, he will answer all your questions with clear answers, and his shipping is super fast.
  4. corgitwo
    corgitwo Member
    GRAND RAPIDS, MI
    Sounds good. I've ordered carb drain screws from Chacal before and they were here so fast, he must have used a Star Trek transporter to send them :)
    I think I got them in like 2 days.
    I've located his part # for the left side intake manifolds ( HCP536LH).
    I'm having some difficulty locating the link for placing an order.
    Anyone have it?
    And thanks for the help guys.
  5. wamaxim
    wamaxim Active Member
    Vancouver, USA
    I just pm him. Not sure when the dude sleeps as I have pm'd him @ 2:00 a.m. PST and received a reply within 10 minutes! I think he sleeps with an alarm attached to his inbox.
    wamaxim
