Relay ?
Discussion in 'XJ Technical Chat' started by texasfisherdude, Apr 1, 2009.
  1. texasfisherdude
    texasfisherdude Member
    Dickinson Texas
    Theres a relay under the rectifier that is missing on my 83 750. Does anyone know what it does? Every thing seems to be working so I dont have clue what it could be.
  2. texasfisherdude
    Dickinson Texas
    Ok I found out its a STARTER CIRCUIT CUT-OFF RELAY but I still dont know what this thing does. The starter seems to work fine
  3. goser
    goser Member
    Waterloo, Ontario
    This is only a guess, but would that be what keeps the headlight from coming on while cranking?
  4. texasfisherdude
    Dickinson Texas
    Well I dont have a headlight yet but I got one coming so I guess i'll find out.
  5. fuferman
    fuferman Member
    Kettle Falls, WA
    if it's the starter cut-off circuit relay i'd say it's the one that won't let the starter crank if you're in gear or with the side stand down. that's how it was on my xs650
  6. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    The relay (or whatever it's called) that keeps the headlight from coming on untill the engine fires, is inside the headlight housing. That's not what your missing there. It must be something else.
    Get a Clymer shop manual if your planning on doing extensive work on your bike. It will save alot of headaches along the way.
  7. bill
    bill Active Member
    Raleigh, NC
    +1 if it's gone it's been bypassed - assuming the bike starts...
  8. texasfisherdude
    Dickinson Texas
    It starts and I see no signs of anyone butchering the wires.
