starting problems
Discussion in 'XJ Technical Chat' started by cowboy5, Apr 5, 2009.
  1. cowboy5
    cowboy5 New Member
    hello, started having problems with my xj1100 maxim the other day. will not start without a boost. i have charged it up says is good but when i try to start it it just clicks. is this probably a dead battery issue. i am not a mechanic and no way to get it to one. i think the battery is old but i am unsure as i just bought the bike last year. please help as i miss my ride
  2. switch263
    switch263 Member
    Austin, TX
    pull the battery and take it to autozone or the like, have them test it. If its bad, replace it. Seems a likely candidate to me.
  3. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Yeah. Probably cant hold a load. Thats one of the first steps when you get any new vehicle! Plugs, battery, oil change, fuel filter.
  4. 85MaximXX
    85MaximXX Member
    S.W. michigan
    also pull the cover and check your brushes there is a wear line and a wear limit 10mm I believe is the minimum. But if the battery looks old it probably is. Did you pull the battery over the winter and keep it charged up? Even with a new battery this to me is a must in any long period of storage.
