i took her for a quick but "SLOW" spin
Discussion in 'Other Motorcycles' started by stevetibb2000, Apr 5, 2009.
  1. stevetibb2000
    stevetibb2000 Member
    bakersfield
    ok this weekend i have repaired my radiator on the R1 fixed the big dents on the tank fixed the lights front and back
    work i still have to do front mater cylinder i KNOW I KNOW no front brakes its this pay check coming up
    here is the trick
    i took her for a spin when i wanted to go left she wanted to go right
    when i wanted to go right she wanted to go left
    when i take a slow turn to the left i had to push back really hard on the left handle bar to keep the bike from wanting to push the handle bar to the frame
    and visa verse with the right
    i think the forks are bent is it true?
    and if so how do i fix them and can anybody fix them
    and if you can fix them will some one here fix them for me
    but on the GOOD NEWS I TOOK MY CHP TEST TODAY AND IT WAS EASY hopefully ill be come a chp officer in 6 mos to a year from now
  2. Polock
    loosen the triple clamps top and bottom till you can spin the fork tube, if the tube binds it's probably bent
    if it spins ok then maybe the wheels are out of alignment
  3. bigfitz52
    If a fork tube is bent REPLACE it do not screw around with attempts at straightening even though there are those who say it's possible.
    Other possibilities: steering head bearings, did you check the AIR in the tires? A tire with only 18lb in it LOOKS fine but the bike will handle real weird...
  4. Hvnbnd
    Hvnbnd Active Member
    St. Johns, Arizona
    Congrats on passing the CHP test
    Good luck with the career and all
  5. schooter
    whats a chp officer?
    and ya, could be tire pressure, bad tires, bad bearings, bad forks.
  6. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    Schooter. California Highway Patrol.
  7. stevetibb2000
    bakersfield
    well i loosened them and tried to square them up a bit its rides a lot better but it still has that tug and pull i didn't think to check the tire pressure the tire looks badly warn
    work to do
    MASTER CYLINDER------------------------------$70.00
    CYCLOPS FRONT HEADLIGHT ASS-------------$139.00
    MIRROR'S-----------------------------------------$40.00
    FRONT TURN SIGNALS---------------------------$40.00
    ALINE THE FORKS--------------------------------$?
    UN BEND THE OUTER SHELL OF THE TANK ----FREE
    A LITTLE MORE JB WELD ON THE RADIATOR--$7.00
    UN BEND THE RIGHT HANDLE BAR A BIT------FREE
    BLEED THE FRONT BRAKES---------------------FREE
    NEW FRONT TIRE FOR BOTH BIKES------------$300.00
    REGISTER---------------------------------------$700.00 THE GOVERNOR TAX
    INSURANCE--------------------------------------$500.00
    TOTAL $1796.00
  8. stevetibb2000
    bakersfield
    ok i spun them around they don't look bent at all and they don't feel bent maybe just out of lineament as i move them and get them squared it rides better and better and it defanantly needs a new front tire it looks like this
    \_/ on the top just turn you head upside down
    it has a good air pressure also
  9. SecaRob
    SecaRob Member
    Cincinnati, Ohio
  10. Polock
