XJ700 non X GEARSHIFT
Discussion in 'XJ Technical Chat' started by littlegiant, Apr 18, 2009.
  1. littlegiant
    littlegiant Member
    Toronto, Canada
    Hi folks, On My XJ700 i cant remember how smooth the gearshift was B4 (owned since Feb09), Now i went with Mobil full Synthetic -JASOMA rated (Maxim-X dot com says its good for clutch) with about 10% Lucas stabilizer, She starts with full choke like a jem on 5`Celcius idles well 1050 RPM No issues on GEAR shift, No slippage, while shift do you usually feel like you are moving gears metal to metal..? Because on my Vstar 650 Normally i would feel much softer no such feeling of metal to metal..i dont know if you guys follow what iam saying....thanks
  2. JoeFriday77
    JoeFriday77 Member
    North Texas
    I'm running Mobil synthetic 10w 40 for motorcycles and haven't noticed any transmission issues. I'm not running any stabilizer though. I do have the 2nd gear problem, but it's not oil related.
    I haven't noticed the issue you described, but next time I get on I will pay a little closer attention. It's been raining here the last couple of days, so hopefully I can ride some today.
  3. switch263
    switch263 Member
    Austin, TX
    my 81 750 seca kinda clunks into gear fairly firmly, but really not much more than any other bike i've ever ridden...
    maybe your clutch is out of whack a bit? I know I need to dial mine back in.
  4. JoeFriday77
    JoeFriday77 Member
    North Texas
    Just got back from a ride and didn't notice anything out of the ordinary. Could the the comparison you are making. The XJ's are high reving, so the tranny has to pop on over. I don't know anything about the Vstar, but I am guessing that the engineering is completely different.
  5. littlegiant
    littlegiant Member
    Toronto, Canada
    Thanks Joefriday for giving attention on the ride and input, Maybe like switch263 said i donna if clutch needs a little bit adj., When i put on 1st gear while running on cntre stand wheel starts spinning but when i stop the wheel it then stops and dont move..does clutch still need adjustment..?
    LIKE SOMEONE IN OTHER TOPIC MENTIOND I HV TO SAY SILKY Gear shift.
  6. JoeFriday77
    JoeFriday77 Member
    North Texas
    Little... Yes, if you put it in gear on the center stand and the wheel starts moving, your clutch could need some adjusting. It could be some other things, but I would start with an adjustment first.
    Search for RickCoMatic's feature on clutch adjusting. I followed it to a T and it worked perfect. I knew mine was not working right although it was working. After following Rick's instructions, it is flawless....
