lets help each other out
Discussion in 'Hangout Lounge' started by 86xj700_indy, May 9, 2009.
  1. 86xj700_indy
    86xj700_indy Member
    now i know you guys have extra parts laying around that are just collecting dust lets do some tradin to get these bikes on the road where they belong
  2. Screaming650
    Screaming650 Member
    Washington Court House, Ohio
    What are you needing?
  3. PaintIt(Flat)Black
    PaintIt(Flat)Black Member
    Sterling, MA
    I would be willing to do some trading. I have a spare '83 750 engine. I'm rebuilding the carbs and keeping them and I'm cleaning the various engine covers and keeping those too. All else is sellable/tradeable including; a seca instrument cluster with 6,000 miles, the handlebar switch housings, driveshaft, and much more. Plus I have some other spare parts from my bike including a seat in great condition, another gauge (Not as nice), and the rear tail pieces including light.
    I'm not really looking for anything in particular. But I would at least listen to any offers. I kind of want a master cylinder that would mount on my bars. PM if your interested.
  4. 86xj700_indy
    86xj700_indy Member
    I am in need of a left side cover to start with
  5. Screaming650
    Screaming650 Member
    i HAVE A WHOLE PARTS BIKE COMPLETE!! I need a TCI box pretty bad.
  6. tomandjerry00
    tomandjerry00 Member
    Washington DC/Philadelphia
    I'll have an extra original right mirror pretty soon if anyone needs it. Anybody have a rack or cases that fit an 82 XJ750 Maxim? I'd love to buy it off of you....
  7. faighaigh
    faighaigh Member
    Malaga . Spain
    I have a large box of parts not even sure what's in there but there's a complete headlight at least 4 indicators a pillion seat and a sissybar all for an 85' xj700. Somewhere I have a list and photos, also have 2 ignition coils for I think an xj700x.
    Faighaigh.
  8. dmschuler
    dmschuler Member
    Tonawanda, NY
    I have an '82 XJ550J almost complete.
    Can anyone recommend a shipping service to send a used gas tank that won't cost an arm & a leg?
  9. bigfitz52
    UPS shouldn't be too bad, that's how the salvage shop sent mine. Probably under $20.
  10. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    I've got some extra Jets, Main and Pilot (110s and 40s) and a Y-10 Diaphram needle for a 650 engine. O-rings for mixture screws, washers for mixture screws. Some Float needle seats for an XJ700, no filters though.
    -SLK
  11. Tiny
    Tiny Member
    Battle Ground, Wa
    I have some parts for a xj700 including a engine that was suppose to be running when the bike was tore apart. Cant see any reason for the PO to lie to me since the engine was in a package deal and I didn't really wanna take it (didn't know there was a place like this devoted to these old xjs then). I also have a almost complete 1980 650 parts bike. I really need pickups and a cdi unit.
  12. bigfitz52
    If anybody needs turn signal GUTS (bulb holders, wiring, the rubber stalks) I've got a bunch of extras from parting out scruffy indicators. Plus an extra 550 Seca headlight shell or two. I've also got an extra 550 Seca seat with good foam but split cover seams that I can part with.
    I don't really NEED anything right now (unless someone has a pristine #2 header pipe for a 550.)
    So: turn signal bits free to good home for postage cost; PM me if you need a headlight shell.
    Isn' this what the "Buy, Sell, Trade" forum is for?
  13. dwcopple
    dwcopple Active Member
    bay city, michigan
    I've got a bunch of XS400 Maxim parts!
  14. airborne82
    airborne82 Member
    ATL
    fitz i need a turn signal lense if you got one
  15. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I have some 750 Maxim parts
    Front fenders some with small dents.
    Rear fenders
    Tripple tree Bottom
    Ignition, Gas cap lock cylinder, Seat lock sets (2)
    Partial wire harness (couple of connectors cut off)
    Some turn signal lights
    Cylinder head with broken studs
    Calipers for 750 (Frozen)
    Brake Rotor for 650 Maxim
    Misc Bolts and fasteners for 750 Maxim
    Rear Shocks for 750 Maxim
    Square Headlight Housing (small crack in bottom) (2)
    750 Engine Side Covers Round Yamaha YICS ones. Scuffed up but useable.
    Some other small parts to much to list.
    Just PM me with your needs I'll see if I can help you out.
    Also send zip code so I can figure shipping
  16. johntc
    johntc Member
    South Dakota
    I have a trunk, license holder, and tool kit for a 750 Maxim. I believe it is an 82.
    I could use a brake master cylinder and handle for my 82 Maxim as somewhere along the line mine got changed to one off a Honda. Fits & works ok but just doesn't look right.
  17. Beanz
    Beanz Member
    Anybody close to Toronto who has the LH silencer? Mine just cracked just in front of the mounting bracket :cry:
  18. PainterD
    PainterD Active Member
    St. Cloud, Minnesota
    I have a 750 Maxim engine and frame (no carbs or starter)
    also,
    Square headlight off of a 750 Seca in perfect shape.
    Complete wiring harness for 750 Maxim.
    Master cylinder with hose and brake caliper for 750 Maxim
    Cheap! I won't ship the engine or frame, pickup only. >PD<
  19. helmet
    helmet Member
    I need a seat for my 85 xj700. mine is pretty torn up. anyone have a gas cap for it? also, I need to replace my master cylinder. the glass eye appears to have cracked from age.
  20. ktcubed
    ktcubed Member
    St. Augustine, FL
    Don't replace the MC. Glass eye is replaceable. Order part from Chacal. I did and it looks like new...
  21. helmet
    helmet Member
    I love this place
    :D
  22. ktcubed
    ktcubed Member
    St. Augustine, FL
    Good. If the eye is bad, imagine what else may be bad in there.
    After 26 years, I would drain system and clean and rebuild MC and Calipers (you'll be draining the MC any way to do the eye). Perhaps even replace the lines with stainless. You'll be amazed at the difference and its not terribly expensive (the lines are the most).
  23. Lisak
    Lisak New Member
    I am in need of a right front foot peg for my 83 - 750 Midnight Maxim. I bought a pair from someone on ebay last fall, but they don't match up to my bike. If anyone can help me out, it would be appreciated, and if anyone needs the pegs I have, we can make a deal. If you need a picture of them, just let me know.
  24. Lisak
    Lisak New Member
    I could also use a headlight ring for the 83-750 Midnight Maxim, mine has a rather large ding in it and it looks off kilter.
  25. MN-Maxims
    Saint Paul, MN
    Lisak,
    Is the headlight the same as a 82 650 Maxim? and Chrome Plated or is yours black. Not sure about Mightnight trim on an 83.
    MN
  26. 86xj700_indy
    86xj700_indy Member
    it should be black
  27. chacal
    Midnight Max headlight buckets are black, and the front trim ring (bezels) are golden-tinted chrome. Hen's teeth hard to find.........
  28. Robert
    Screamin650, do you have a bad TCI or is it missing? If you have a box and it isn't working, I can fix most problems on them. Parts and shipping for repair.
  29. DatzBull
    DatzBull New Member
    Austin
    I have a rear wheel (hub and drive shaft included), full set of carbs that I believe came off a 650, yamaha hi-way pegs, original handle bars from a xj700, tank for an xs400. I'm looking to change the look of my 700 and want a new seat. wondering if the 750 would fit or do I have to change the rear frame.
