Carb intake boots
Discussion in 'XJ Technical Chat' started by jamings67, May 10, 2009.
  1. jamings67
    jamings67 Member
    CT USA
    I just got my 1982 xj1100 running today! Thanks to some help here. I bought it last year after the guy hacked the main harness and removed some parts. I was able to put power to it today and it started right up and purred like a kitten and was smooth as any engine I have heard. I didn't even have to clean the carbs! Anyway I am happy about it.
    The carburetor boots have the usual cracks and I will replace them this year.
    I was thinking about what I could put on them to seal them until I get new ones. I think that I could use liquid wire insulation stuff. It should work to prevent leaks. What do you think? Have you used anything on you boots that worked?
  2. JoeFriday77
    JoeFriday77 Member
    North Texas
    Look for a post that Fitz did. I think he used RTV sealant, but I'm not 100% sure.
  3. jesso123
    jesso123 New Member
    Minnesota
    new to the site- but from a forum here it said use a silicon sealer- i got some BLACK stuff that is used for gasket making...cant think of the name right now, but it is flexible and works up to 625F ....worked great for me...
  4. alkasmeltzer
    alkasmeltzer Member
    Lincoln, NE
    Black Perm-a-tex should do the trick until you can get some new boots. You can find it at fine automotive retailers near you!!
  5. jamings67
    jamings67 Member
    CT USA
    THANKS GUYS!
  6. bigfitz52
    Yep; high-temp black RTV gasket maker. Others have had good results with liquid electrical tape too.
  7. Thee_oddball
    Thee_oddball Member
    Mine were cracked on the outside but good on the inside...but i slathered them in black liquid gasket just tobe on the safe side.
