clutch questions (I did somethin' silly)
Discussion in 'XJ Technical Chat' started by JoshL, May 11, 2009.
  1. JoshL
    JoshL New Member
    St Cloud, Fl
    I've been having a little trouble with clutch drag lately which cable adjustment wouldn't fix. So I pulled the clutch assembly off today and did something silly. The final plain plate is held in by a retaining wire and since the rest of the plates weren't warped or damaged I decided to check the last plate. When removing the wire retainer I broke it. So question #1 is how important is this retainer and can I live without it? Then I pulled another silly. Behind that final plate is a diaphram spring and I took it out and didn't pay attention to how it sat. Question #2 is should it fit so the inner or outer edge is against that last plate. Any help is appreciated.
  2. Thee_oddball
    Thee_oddball Member
    this is for my 82 1100 but im going to guess they are very similar
  3. JoshL
    JoshL New Member
    St Cloud, Fl
    That looks very similar. Looks like the outer edge of the spring is against the plate. Thanks
  4. chacal
    "very" and "no".
  5. bigfitz52
    The posted diagram is from an 1100; your 650's clutch is quite a bit simpler, but Len is absolutely correct.
    You need the retainer. Don't put it back together without it.
  6. WesleyJN1975
    WesleyJN1975 Member
    Bellmawr, NJ, USA
    Is there a blow up pic anywhere like that for a 650 maxim?
  7. Andreas
    Andreas Member
    Amsterdam (The Netherlands)
    Here's the diagram for the 650 seca, i suppose they're the same
