I screwed up the electricals system (lights)
Discussion in 'XJ Technical Chat' started by 94xjboston, May 17, 2009.
  1. 94xjboston
    94xjboston New Member
    Boston, MA
    decided to replace my blinkers. Took all 4 stock blinkers off no problem. Put on rear license plate blinkers, they worked fine and blinked properly. Was hesitating whether to put on front blinkers since they aren't really needed. Wish I hadn't!
    The front blinker connectors have 3 wires, while the rear only have two. The replacement front blinkers I was using only have two whiles also. Somehow while messing around with the wires in the front, I made it so none of the blinkers work now, my neutral light doesnt work, and the turn signal on the dash doesn't light up. If I plug in the stock front blinker, both front and rear blinker lights up, but don't blink and just stay solid.
    What's going on?
  2. SQLGuy
    SQLGuy Well-Known Member
    What model bike are we talking about here?
  3. 94xjboston
    Boston, MA
    94 XJ 600 seca
  4. JoeFriday77
    JoeFriday77 Member
    North Texas
    The third wire was probably for using the turn signal as a running light. I have 3 wires on the front too. It may not be a problem, but double check your turn signal fuse first to rule that out.
  5. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Do yourself a favor and put them on. :x
  6. dpawl31
    dpawl31 Member
    NH, USA
    Fuse?...
  7. 94xjboston
    Boston, MA
    Where is the fuse?
  8. JoeFriday77
    JoeFriday77 Member
    North Texas
    Should be under the seat on that bike. There should be a black box the seat that has all of the fuses.
  9. 94xjboston
    Boston, MA
    What do I need to check or look for in the box?
  10. JoeFriday77
    JoeFriday77 Member
    North Texas
    See if you have any fuses blown. Probably not a source of the problem, but easy check to rule that out.
