old school carb sync question
Discussion in 'XJ Technical Chat' started by moonfriedpotatoes, May 20, 2009.
  1. moonfriedpotatoes
    moonfriedpotatoes Member
    Montana
    so i FINALLY got my bike running off enrichment. Idles well, occassional popping noises from left pipe, but not very loud.
    trying to sync up my carbs, and i've made rick's old skool tool, but i can't figure out how to measure the vacuum on number 3...
    If i unplug the vacuum line from carb three to petcock, how do i maintain gas flow to the rack? prime?
    any help is much appreciated.
  2. greggvickrey
    greggvickrey Member
    Smyrna, Tn
    you can put on prime or move vac line to another vac fitting.
  3. TIMEtoRIDE
    You can put the vac tube on #1, or any other really.
    Or you can use "PRI".
    I recommend the 4 tube water filled Manometer as your next project.
    Do you want accuracy? Do you want to watch your engine breathe?
  4. moonfriedpotatoes
    Montana
    got a link for that?
    any ideas as to what would cause popping noises from the left pipe when i come off throttle? I'm going to sync and colortune regardless; i was just wondering if that would fix it or if its something deeper than carb adjustments and cleanliness
  5. TheHound
    TheHound Active Member
    Scotia, NY
    It should clear up with the synch and colortune.
  6. bill
    bill Active Member
    Raleigh, NC
    Agreed - you should be able to tune that out. I have been using Rick's old school method seems to work fine. I'd like to try the bottle method someday.
  7. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Yeah I got that pop too. Need a YICS tool and a Colortune.
