Test for the alternator
Discussion in 'XJ Technical Chat' started by Blackhammer, Aug 15, 2006.
  1. Blackhammer
    Blackhammer Member
    Indiana, USA
    Ok, here is another question for you. I was riding on a 30 mile jog to home at about 11:30 pm last week. I turned on the brights, but the bugs were thick. So I turned on the bottom headlight. Great lighting. I then tried the brights too. BAD MOVE! I blew the fuse and was running about 65mph with a curve ahead in a rural area with no lights or farmhouses ahead. After slowing down and gearing down, I followed the curve and came to a church about 2 miles ahead. I had spare fuses, so I changed it and was back in business. Then on Thursday, the bike did not want to start and I ran down the battery. I put my main battery charger on it and I think it was bad. I was going to a funeral Friday night and the bike just died. I walked a few miles (don't wear cowboy boots when riding, my feet still hurt) and got a jump and limped home. When I used my trickle charger, it charged the battery right up. My son showed me in a magazine that if you have a bad cell in your battery, your motorcycle can miss out. I am not sure if the battery is bad or if it is the alternator.
    Any ideas on how to tell???
    ___________________
    82 XJ750J Maxim
  2. ChrisMoorley
    ChrisMoorley New Member
    Waterloo, Ontario
    A simple method to tell if your alternator is working:
    Start the bike, let it idle really low and see how bright your hedlight is. When you rev it, the light should get brighter. If not, you may have an alternator or regulator problem.
    Another simple test.
    Start the bike, disconnect the battery. With no battery and a bad alternator, it will die instantly.
    Hope this helps.
    Chris
  3. BlueMaxim
    BlueMaxim Active Member
    Central Mississippi
    Get multimeter and test the battery voltage with the battery connected to the bike. Should be somewhere around 12.3 volts. Start the bike and check voltage again with bike running. Should now read somewhere around 13.5 to 14.5. This means your charging circuit is working.
    If you still get 12.3 and the power is dropping then most likely the brush in the alternator cover needs replacing.
  4. Blackhammer
    Blackhammer Member
    Indiana, USA
    I tested the battery with my multimeter. It was showing 11.7 volts. I tested it running and it was between 13.8 and 15.2 volts. This morning, it will not start, and the battery is low again. So maybe I do need a new battery?
  5. BlueMaxim
    Central Mississippi
    Yep new battery. I usually take mine to Auto Zone and have it load tested just to be sure. The 15.2 volts maybe a little high. I am weak on most electrical stuff so I hope someone else let us know if that is a point of concern.
  6. BlueMaxim
    Central Mississippi
    I checked the XJCD and anything over 14.8 is indicative of a faulty R/R.
    (regulator/rectifier). What this means is that the charging system is being allowed by the R/R to over charge and therefore burn up your battery. So far I haven't found a way to send you the page from the XJCD. I will keep trying.
  7. RickCoMatic
    Brushes ... You really need to check the BRUSHES ... right away. If they are "Short - out of specs" ... don't run the engine until you replace them. Brushes not making good contact will arc and scortch the alternator rotor.
    Brushes are the #-1 cause for the all the symptoms you described. If there's evidence of the arcing ... "Bluing or dark spots" ... you can resurface the copper slip rings with "Glass Paper" ... lightly refinishing the surface following the rings in a circular motion.
  8. Blackhammer
    Blackhammer Member
    Indiana, USA
    Ok I will check on both items there tonight. When I went to start it yesterday, it would not start. So I bought a new battery. It fired right up today, but I kept the old battery. I will open it up and look at the brushes.
  9. Blackhammer
    Blackhammer Member
    Indiana, USA
    Ok so I put in the new battery. It ready 12.8 volts. When I started it, my multimeter read 14.5 volts. So I rode my usual Sunday 60 mile ride. When I got there, no problem starting again. I made a few stops in town, then I rode home (30 miles one way) Sunday night, I tried to start her and low battery (10.8 volts).
    So I do have a charging problem ( and 2 batteries now) How do I replace the brushes? Any idea where I can buy new ones? I am about 45 miles from a Yamaha dealer.
    Any and all ideas are appreciated.
  10. Robert
    Chris, your disconnecting the alternator suggestion unfortunately could fry the rectifier diodes. Under no circumstances should that step be taken. Older technology alternators on cars can handle it but bikes have very sensitive (gotta laugh at that one) components.
    BlackHammer, your alternator is getting there with the 14.5 volts, but your loss of battery voltage after some fairly lengthy trips is puzzling. My humble advice is to obtain a copy of the Haynes or factory manual and hit the troubleshooting matrix, it would help you more than my guessing. I'm rummaging through my Haynes now and the voltage at 2000 RPM or better should be 14.5 (+/- 0.3)VDC. The book lists the following points:
    Battery sulphation (you have already replaced it so this is moot, small note, make sure you put the new battery on a trickle charger, 1 to 2 amps max, for about 6 to 8 hours before placing it into service, it will extend it's life expectancy)
    Battery leads corroded, clean and cover with petroleum jelly or terminal preservative.
    Load excessive, got accessories? Too many of these and the alternator will not be able to keep up.
    Regulator/rectifier failure, hope this isn't your problem, they are pricey.
    Alternator generating coils open-circuit or shorted (I doubt this given your voltage output)
    Charging circuit shorting or open circuit, my take on this is that you wouldn't have the correct voltage at the battery if this was the case so I'd ignore this one too.
    Best I can sling at you without laying hands on the beast. Best of luck and keep posting details as you find them, we'll crack this gremlin.
  11. Blackhammer
    Blackhammer Member
    Indiana, USA
    Robert: I have the Yamaha Sevices manual. It lacks in the troubleshooting area for electrical. I remember a website that was dedicated to the XJ's electrical but I can't find it.
    Addressing the Hayne's issues"
    " The book lists the following points:
    Battery sulphation --NA
    Battery leads corroded, --I cleaned them
    Load excessive, got accessories? --No accessories
    Regulator/rectifier failure, ---- This is a possibility---
    I will search out the RR. I have a Motorcycle junkyard at the other end ot the county that I may call and see if he has any.
  12. Robert
    Don't just shotgun it, test it out. There is a fine check out in the Haynes (sound like a broken record, sorry) and I would hate for you to pop in a replacement only to find that something else is wrong and fry your new part. Here is the link I have, think it might help. Good luck. http://www.geocities.com/MotorCity/Speedway/7795/
  13. skippT
    skippT New Member
    Colorado, USA
    Another possibility could be eccessive electrical drain on your battery as your charging voltage appears good. There's an easy way to check:
    Connect a multimeter in-line at the battery to measure a key-off current draw, it should be less than 1A. If it's greater, remove your fuses one at a time untill the you see a big change in your reading, the last fuse that you pulled will help you identify the circuit causing the drain, and you can troubleshoot from there.
    HTH,
    -Matt, CO
  14. RickCoMatic
  15. Blackhammer
    Blackhammer Member
    Indiana, USA
    Rick
    I have been scouring the forum for how to check these brushes and where they are located. Can you help me?
  16. Robert
    Rather simple. According to the wonderful Haynes manual laying here, your brush lengths should be no less than 10mm but no longer than 17mm (doubtful they are this long at this point in time). Now for the how to. Page 216, section 4, Figure 6.1 shows the assembly. I would assume (yes, I know what that means, I'm rather used to it) that the brush carrier is immediately under the alternator cover, located on the left side of the bike, just behind the cylinder block and under the carbs. Three cap head bolts as I recall. Pull them out and pull the cover. Then simply unscrew the brush carrier and your in there. Any questions?
  17. RickCoMatic
    Left side of bike ... as if you were sitting on bike.
    Round cover to left of starter motor.
    3-Fasteners.
    Withdraw cover.
    Brushes mounted to inside of cover.
    Length: New = 17mm (0.67in)
    Service limit = 10mm (0.39in)
    Individual brushes have "Scribe" marking on them. (like tire wear bars)
    If inspection reveals brush to be worn to (or close to) wear limit - replace.
    Inspect rings on face of alternator for evidence of brushes at wear limit.
    Bluing, burning -- pitting from arcing ... etc.
    Clean-up rings with Glass Paper - (electric supply shop)
    Burned or severely pitted slip rings will do damage to your electrical system -- (regulator; particularly)
  18. Blackhammer
    Blackhammer Member
    Indiana, USA
    Sounds simple enough. I will give it a shot tonight. I have just remembered that I blew a fuse 2 weeks ago with all of the headlights and brights on. I read that a fuse problem can cause similar problems to what I am seeing, so tonight will also be the conversion to spade type fuses.
  19. Robert
    Rick, your write-up is so much easier to follow than my own. I'm going to try to emulate your style, with your blessing I hope. Nicely done. Don't think I could replace you, but I would love to be as clear.
  20. RickCoMatic
    Thank you very much for the kind words. Imitation is absolutely the most sincere form of flattery!
    I try to write it better than they do in the manuals. Sometimes, it has to get a touch wordy ... the manual is written for those who have wrenched a little bit.
    For those who are diving-in to a project for the first time; it helps to be comprehensive without confusion.
    I'm happy to know the information that I am passing along is doing some good!
  21. Blackhammer
    Blackhammer Member
    Indiana, USA
    Ok I have good news and bad news. I pulled off the cover to the alternator and started to remove the brushes. I got the 2 screws off and my wife called me to answer the telephone. One brush is 12 mm long and one is 3 mm long. So I need new brushes. The ring on the alternator was fairly clean. Some oil on the outer part (copper wire with tape outside of the ring) The ring had a few ""skid marks" on it with clean copper sections in between. I am ordering new ones from Oldbikebarn. Am still looking for the glass paper.
    Here is the bad news. I don't remember which way they go back on. I am assuming the brushes face toward the ring, but I could not remember how they looked when I took them off. The brushes spring out toward the ring, like a small block of carbon it looks like.
    I took this time, since it was down, to replace my fuses with inline ones. I will have to work some more on that one, since when I put the seat on, it ripped off the fuse for the turn signals.
  22. Blackhammer
    Blackhammer Member
    Indiana, USA
    By the way, Thanks Robert for that web site. That was the one I was looking for. I check out the regulator and all of the diodes checked out OK.
  23. Robert
    Always glad to help where I can. Very hopeful you get this alternator item ironed out. I could use some brushes as well, ought to order them up. Where have you sourced your brushes from and how much is the shipping?
  24. Blackhammer
    Blackhammer Member
    Indiana, USA
    Old bike barn. I called because I could not find them (Was on hold forever) On the web site, you go under Starter Brushes. Once you pick your model, starter brushes are on top, alternator brushed are on the bottom of the list. 24.97 was the cost. Total with shipping is $33.00.
  25. RickCoMatic
    RickCoMatic ... called-it! Brushes. Now your battery will be getting a little juice!
    I'm pretty sure that the new brushes will only go in their housing one way. They are both very slightly rectangled. The mount ought to have a "Footprint" ... or "Pigtail memory." If not; the mounting plate has to line-up such that the two brushes will make contact with the two rings on the alternator.
    You can give some of your wifes copper cleaner a shot. Or, you can try some Mothers polish. Either might work if the scortch is more of a tarnish than a severe burn.
    Clean off the whole works, in there, with a spray can of Electronic Parts Cleaner or Contact Re-new.
    I'm hoping it cleans-up nice without a spot on there that's burned off. If that's the case ... you'll need an alternator rotor; because the "spot" will cause the new brush to arc and you'll be way up the river if that happens.
    Finger crossed; everybody.
  26. Blackhammer
    Blackhammer Member
    Indiana, USA
    Thanks Rick, I have copper cleaner and Mothers and contact cleaner. I am not sure how long it will take for the brushes to get her but this electrical work, installing new fuses in my Maxim and trying to get my son's CBR600's carbs drained, I will be pretty busy the next few days. Pity too, it is perfect riding weather and me without a running cycle.
  27. Robert
    Have you tried taking your one good brush to an ACE Hardware (or similar DIY place) and comparing to their parts bin? I'm fairly certain you could score a set close enough to perform for just a few dollars. Wouldn't want you to miss out on valuable riding time.
  28. BlueMaxim
    Central Mississippi
    Well I learned some electrical stuff on this one. Now I know that the brushes CAN cause a voltage surge and it can do it with the R/R working well and not burn it up. Got a little more faith in Yamaha's R/R's now!
  29. MacMcMacmac
    MacMcMacmac Member
    Ottawa, Canada
    If you're stuck, you can pull the carbon post out of the center of some "d" cell batteries and shape it to fit.
  30. RickCoMatic
    Or ... buy a really shabby-looking alternator cover off ebay for short money and roll the dice on the brushes and holder being good.
  31. Blackhammer
    Blackhammer Member
    Indiana, USA
    The brushes finally came. I put them in last night and she runs great. Between the new brushes and my changing out the fuse box, the headlight is much brighter. And my turn signals really flash. Now I need to look for a new turn signal switch that will really self cancel. The only downside to this is now I have a new battery that I really did not need.
    Thanks for all of your help.
  32. RickCoMatic
    I'm carving a notch in my gun.
    Nice work on the brushes. Nothing like having to stick a new set of brushes in the bike. I'll bet you could sell rebuilt brushes!
    Returned to flight status!
    Rick Massey
  33. gavi_omen
    gavi_omen New Member
    Wisconsin
    Wait wait, so the starter brushes give charge too? I thought it was just the alternator stator responsible. I'm a bit confused now. My bike isn't charging my battery as I ride either. It runs fine, but starts horribly as a result of this (I do have a new battery that I charged up initially). I have to charge the battery almost every day before I go riding so as to make sure I'm not hill starting the bike at some point in my day. It isn't always a guarantee even. Anyway, perhaps someone could be of some help?
  34. RickCoMatic
    Battery losing charge / Not charging.
    Check system.
    Hook-up Voltmeter to Battery.
    Battery @ 12V (or above)
    Start Motorcycle. Monitor Voltage at Battery.
    Battery low. Charge for 12V Min test value.
    Start bike.
    Watch the Voltage at the battery. Reading should be above 12V.
    Rev-up engine watching Voltage at battery. Voltage should increase to 14V when engine reaches 1,100 rpm. As engine rpm's are raised the voltage should rise; too. At 2,750 or so ... you shoud be up to 14.2V
    The Voltage should rise from 14V to 14.2 (maybe 14.3) as the rpm's are increased ... and then remain constant at 14.2 (above 14) but, STEADY beyond 2,750.
    No charge.
    Check the alternator brushes and connections.
    Brushes bad; replace.
    Brushes Good. Check Voltage Regulator.
    (Since you already stated that you "Jumped Started" it ...
    Inspect:
    The terminal ends inside the plastic quick-connection -- Voltage Regulator to wiring harness. Look at spade connected to RED wire.
    Plastic looks overheated, melted or spade inside this connector looks blued. Red wire appears to have been subject to heat ...
    Write a nice Obituary for your Voltage Regulator.
    Remove Voltage Regulator from motorcycle.
    See how far you can throw a fried Voltage Regulator.
    Cuttent World Record: 87 Yards 2 Feet 3 Inches.
  35. gavi_omen
    Wisconsin
    I can't find a listing for alternator brushes on oldbikebarn.com. Any help?
  36. RickCoMatic
    Are they short out-of-specs?
    You can measure how much of the brush is remaining. There's also a line on them ... like "Wear bars" on tires.
    I don't know if they are available in the aftermarket. The brushes might be something you need to go to a Dealer for. Some people fabricate new ones from the wide assortment available for power tools ... and "shave" them down to fit the slightly rectangled shape needed for the housing.
    Needing brushes every twenty years or so ... I'd say pop for the Genuine Article!
    Google: Zanotti Motors --- they're an online Yamaha Dealership offering a real discount for ordering from they're web site.
  37. gavi_omen
    Wisconsin
    I just checked the alternator brushes on my bike, and they aren't short. They are right around 10 mm, or maybe even a little over. I checked the voltage at the battery when the bike's running, and it's reading 11.3 at an idle and 11.5 at roughly 4000 rpm. I don't know what in the system could be the trouble, but something certainly is. I don't have an way of checking resistance or anything, so I suppose I'm just looking for some ideas. Is it possible that with correct length brushes the alternator may still not be giving out enough power?
  38. RickCoMatic
    Did you check the plastic quick-connection where the Voltage Regulator is attached to the wiring harness.
    Let me know what the condition of the inside of that plastic connector looks like ... particularily the condition of the spade connected to the Red wire, the plastic red covering on the wire near the spade terminal ... and the condition of the connection block.
    I'm betting a dollar there's some evidence of overheating. You probably need a new Voltage Regulator.
  39. gavi_omen
    Wisconsin
    Good news annd bad news. I broke the fuse for the ignition, and, because the dumbass before soldered in teh fuses, I had to bypass it by tying it together with copper wire. Low and behold, the amount of voltage the battery recieves has gone up over half a volt at low idle to around 12.1 or 12.2 volts. Which means, sadly, that I have to replace my fuse box or at least do a bypass on all my fuses for the time being. So, I found the problem.
    "Hazaa's are in order."
    -Futurama's Professor Farnsworth
  40. RickCoMatic
    Select any prize you like off the bottom shelf.
    You'd have gotten a prize off the top shelf ... but, soldering the copper wire across the terminals and leaving the ignition circuit unprotected by a fuse cost you some points.
    The judges took into consideration your good intentions to place some temporary inline fuses in there until you install a new fuse panel.
    www.wirewerks.com Get the 6-place one for less than 10-bucks!
  41. gavi_omen
    Wisconsin
    I was gonna go out and just try to Jerry-rig an automotive box in there. Hmmmmmmmmmmmmmmm...I do like that price though.
  42. gavi_omen
    Wisconsin
    ...please provide a link to the product you are talking about. I can't seem to find it on the site.
