FS: Throttle Shaft and Pilot Screw Orings
Discussion in 'For Sale, Trade/Swap, Wanted' started by OfficerXJ, Jul 29, 2006.
  1. OfficerXJ
    OfficerXJ New Member
    Iowa
    I rebuilt my carbs and purchased from McMaster Carr more seals than I needed, so here you go. Shipping and handling is included in each price. I do take PayPal. I have some Buna-N and some Viton material types. The difference is Buna-N has good resistance to fuel and Viton has excellent resistance to fuel. PM me for your needs
    Pilot Screw orings (Viton): $3.00 for set of 4 (5 sets available)
    Throttle Shaft double seal rings (Viton): $6.00 for set of 8 (5 sets available)
    (Buna-N): $3.00 for set of 8 (1 set available)
    Throttle Shaft stack oring (Viton): $6.00 for set of 8 (2 sets available)
    (Buna-N): $3.00 for set of 8 (11 sets available)
    The throttle shaft stack oring I place next to the double seal rings. Since the double seal ring is thinner than the original seal, there is a gap between the double seal ring and the plastic washer on the throttle shaft. I stack this oring outside the double seal ring to keep it in place so it seals against the carb housing. I don't use any adhesive to hold the double seal ring in place. So far so good.
  2. faighaigh
    faighaigh Member
    Malaga . Spain
    What bike what carb?
    Mick Faighaigh
  3. Hired_Goon
    Hired_Goon Member
    Oz
    Have to be Hitachi carbs from 650 onwards as Mikuni don't use orings under the pilot screw.
  4. OfficerXJ
    Iowa
    That is correct, Hitachi carbs and the bike is a 650 Maxim.
  5. Joel07
    Joel07 Member
    Durham, NC, USA
    Do you still have these? I'm in need of some for my bike. Thanks!
  6. OfficerXJ
    Iowa
    Parts are still available, the Vitons are getting low.
  7. Joel07
    Joel07 Member
    Durham, NC, USA
    I'll vouch for OfficerXJ, just bought a set of all the seals from him, arrived quickly and everything worked perfect!!
  8. guywithbike
    guywithbike New Member
    arkansas
    hey OfficerXJ do you still have the viton double seal o-rings.
    i need a set if u still do. will do paypal email is scorpio2876@gmail.com.
    thnx.
  9. chacal
    I got mine, too, and they were just what the idle screws needed! Thanks!
  10. OfficerXJ
    Iowa
    I'm out of the pilot screw orings. I still have two sets of double seals for the throttle shafts.
  11. dgmid61
    dgmid61 Member
    Winchester, Va
    Do you still have any throttle shaft seals? If so, is that all I need to seal my throttle shafts? You say in your first post that you had to use another o-ring to make it seal properly? do you also have that o-ring available??
