I Joined a Bike Gang
Discussion in 'Hangout Lounge' started by RangerG, May 29, 2009.
  1. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I have been thinking this over for a long time now. This isn't something that I ever really wanted to do. I have heard horror stories regarding the gang initiation and didn't know if I had the balls to go through with it. But I did. There were a couple of rough spots but overall it wasn't too bad.
    What Gang did I join?
    If I tell you, I'll probably have to kill you!
    OK, I'll tell.
    I joined the XJ BIKES CLEAN CARBS GANG
    Who do I have to contact to get my colors? Rick-o-matic? Robert? Maybe Chacal since he has everything else.
    Was it worth it?
    Yes. It passes the clunk test with flying colors. The enrichment circuit is 100% clear. All new seals and o-rings. New bowl gaskets. New throttle plate screws. New upper mounting rail screws. New bowl drain screws. I am 100% confident in my work and the carbs.
    Problems?
    Mangled a few mounting rail screws. Setting float levels is a royal pain. How the heck does anyone with bigger than size small mitts get their hand in the airbox to push the boots back out? THAT was the biggest pain of all.
    Did it help?
    As far as power and performance........no. The bike is still the same as ever, which was very good. It does start, cold, a little quicker. It still seems to flood itself when it is hot and sits for 20 minutes or so. I can live with that. I still have just a couple degrees of tuning to do on the idle jet screws. I'd say the bike is at about 97%. Where a big gain was made, is that when I end up 2,000 miles away from home, which I do on a yearly basis, I know that none of my throttle shaft seals or fuel rail o-rings are going to start leaking. I rebuilt the petcock as a preventative measure as well.
    I would, and often do, strike out for far off destinations and I am very, very confident that the bike will not let me down. It never has in the past and I'm sure it won't in the future. What more can you ask for?
    How about those colors?
  2. a340driver
    a340driver Member
    Langley B.C. Canada
    Congratulations! ... now you need a colortune and vacume test
  3. Robert
    The colors you want are on Sno's swag-for-sale page. I'm jonesing for a golf tee myself (mommy wasn't receptive to the idea this evening...).
  4. chacal
    The T-shirt that would be most popular would be the one that reads:
    AFTER THE THIRD ROUND, AND TRYING EVERYTHING ELSE INSTEAD, I FINALLY GOT MY CARBS CLEAN.....
  5. schmuckaholic
    California
    ...with a picture of a carb body and a guy in a clean-room suit.
  6. jgb1503
    jgb1503 Member
    Near Utica, NY
    ......with carb cleaner in his eye
  7. bill
    bill Active Member
    Raleigh, NC
    HA I would definitely buy that one! It could also say I FINALLY did it right!
  8. grutz
    grutz Member
    Akron, Ohio
    Hows this?
    :lol:
  9. bill
    bill Active Member
    Raleigh, NC
    I love it that would be a cool T shirt
  10. RangerG
    RangerG Member
    What? No three piece patch for the back of my jacket? I already have the hat and t-shirt. Maybe I'll just have to have the exploded picture of a Mikuni carb put on the back of a shirt.
    Some of you belong to the "XJ BIKES CLEANED CARBS SEVERAL TIMES" gang. Sorry but I don't want to join that club. My motto was "one and done".
  11. SnoSheriff
    SnoSheriff Site Owner Staff Member Administrator
    MB, CAN
    Hmmm, it could be done. Maybe we need a slogan thread started for some Ts?
  12. bill
    bill Active Member
    Raleigh, NC
    That would be cool. Even better if the profits help support the site. I like TShirts - always room for more....
  13. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    I'd buy that.
  14. RangerG
    RangerG Member
    Update. I had a slight stumble just off idle that I've been trying to work out. I went about 1/16 to 1/8 of a turn leaner on the idle jets today and I think I have it! Stumble seems to be gone and the plugs look great.
    Biggest improvement was the installation of stainless steel brake lines on the front.
  15. RickCoMatic
    This is the kind of Post I'd much rather see more often than ones from somebody who is starting-off Summer with a slipping Starter Clutch.
    That's for sure.
    Congratulations.
    You have a License to TWEAK!
    1 Down ... 4,999 to go!
  16. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    My carb bowls are so clean I poured some cheerios and milk into one to celebrate!
    Yay! 8)
  17. bill
    bill Active Member
    Raleigh, NC
    Now you have to clean them again! :D
  18. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Yeah, but that was gooood cereal. :)
    Note: Don't add sugar to your cereal while it sits in the bowl, no matter how clean the fuel bowl may appear. Also, dried milk is not affected one iota with carb cleaner, carb dip or high powered air pressure.
  19. bill
    bill Active Member
    Raleigh, NC
    LMAO - I don't think I will need that information as I don't intend to put milk in my carbs :D
