Universal Cafe Fairing
Discussion in 'XJ Modifications' started by murphyreedus, Aug 18, 2006.
  1. murphyreedus
    murphyreedus New Member
    midwest
    I'm installing a universal cafe fairing on my maxim, and i'm wondering if anyone has any tips for getting the v brackets properly adjusted (or does it just require a long and tedious trial and error session?)
    this is the fairing in quesiton, though from what i've seen, all the 'universal' cafe fairings are about the same:
    http://tinyurl.com/kz6kj
  2. thedude
    thedude Member
    Columbus, ne U.S.
    ask hessenroots.... or check out his posts on the subject, he just did the same thing, good luck!
  3. geebake
    geebake Member
    Audubon, NJ
    Are you sure that faiing will fit your headlight? I thought the XJs used 8" headlights, though that may just be Secas. It looks like that one on eBay wants a 7".
    Hope I'm worng,
    Greg
  4. geebake
    geebake Member
    Audubon, NJ
    Hope I'm worng,
    Greg
  5. murphyreedus
    midwest
    no its a 7" headlight. i've already fit it on the bike, so i know it fits.
    the problem is with the v brackets that mount on to the bolts that hold the headlight assembly on.
    i looked at hessenr00ts's post about his fairing, but he didn't go into detail on how to mount it. mine looks exactly the same, though, so i'd imagine they have similar mounting kits.
    tomorrow i'm going to give it another go and try and get it mounted.
  6. pbr_street_gang
    pbr_street_gang Member
    Los Angeles, CA
    When I put my fairing on I did use the same blots that hold the headlight assembly on. I had to do alot of tweaking with the V brackets. You can bend the V brackets and get it so that the fairing sits really snug with the headlight. I can try and get you some pics if that helps. Remember to put the headlight back in the right way. I put mine in sideways so that was a little annoying until I noticed what the problem was. Good luck.
  7. murphyreedus
    midwest
    after a lot of gruntwork, some help from my friendly neighborhood vice, and a lot of swearing, the fairing is on, the headlight reassembled, and I a much happier person.
  8. woolsac
    woolsac Member
    Sparta, NJ
    Slap some pix up when you get the chance. I would love to see how it turned out...
  9. murphyreedus
    midwest
    there it is
  10. pbr_street_gang
    Los Angeles, CA
    Sweet dude. You got it together. Looking fast and shiny.
  11. richard03
    richard03 Member
    Texas
    How does it help with wind? Where does the wind hit you? On the helmet or below?
  12. JPXJ
    JPXJ Member
    Webster, NY
    Cool!
    I need to spring for a round headlight...
  13. murphyreedus
    midwest
    it helps with the wind a little, but its certainly not a windjammer. Does cut down on bugs slamming into my chest, though.
