wont stay runnin plz help
Discussion in 'XJ Technical Chat' started by 86xj700_indy, May 31, 2009.
  1. 86xj700_indy
    86xj700_indy Member
    I had to jump my bike today and it would start and idle. but it did not do so without the choke and as soon as i would shut the choke off it would die also as soon as i would give it any throttle it would die too any suggestions would be helpful as i am a novice when it comes to this bike
  2. Stamplicker
    Stamplicker Member
    London Ontario
    Fuel problem? Battery not charged?
  3. 86xj700_indy
    86xj700_indy Member
    well the battery was dead and it was smelling like it was fludding so both. would a dead battery make it do that?
  4. Gamuru
    Gamuru Guest
    Granite Falls, WA
    It's possible. You could jump the bike again from another battery, but leave it hooked up so that your bike is getting plenty of current. If the flooding problem goes away while hooked to the other battery then you have your answer... weak spark due to dead battery.
  5. 86xj700_indy
    86xj700_indy Member
    and if it dont help with the flooding i probably need to rebuild and clean my carbs?
  6. Gamuru
    Gamuru Guest
    Granite Falls, WA
    That would seem the likely next step, yes.
  7. 86xj700_indy
    86xj700_indy Member
    could anything else cause these bikes to act like this?
  8. JoeFriday77
    JoeFriday77 Member
    North Texas
    There are other things, but the two mentioned are the most likely candidates. The battery is the easiest to troubleshoot before you go farther. Check your plugs too to make sure they are not fouled from the flooding. Then go to the carbs.
  9. 86xj700_indy
    86xj700_indy Member
    where is the best place to get carb rebuild kits from?
  10. Robert
    Chacal, our beloved supporting vendor has all the parts you need to make your carbs happy (and at reasonable prices with quick shipping).
