head removal tips
Discussion in 'XJ Technical Chat' started by dqnjuan, Jun 1, 2009.
  1. dqnjuan
    dqnjuan Member
    bmore, md
    Any one got an "old skool" or new for that matter to remove this old head shes barely budging with about an hour of rubber mallets and short 2 x 4s.
    Hell Ive seen old cars pop easier.
  2. Hillsy
    Hillsy Member
    Are you sure you have all the bolts removed? Apart from the main head bolts, there are normally a few allen bolts hidden around the place to catch you out.
  3. coachholland
    coachholland Member
    Georgetown, KY
    I used a car body dent tool. A hard plastic one that had a flat rear that was around an inch and half or two inches wide and used that flat surface against the bottom fin. Don't hit too hard or it will break the aluminum fin. Main thing is to just do a little bit of one corner at a time. A rubber mallet has to much "give" to it and a 2x4 isn't going to concentrate the impact enough.
    But as Hillsy mentioned, make absolutely certain you've loosened all your bolts first.
  4. dqnjuan
    dqnjuan Member
    bmore, md
    Pretty darn sure I got all the bolts the 4 nuts on the rear 2 in the front and the 12 on top taken loose in order...
    My buddy prolly has one of those tools ill see if it makes life easier
  5. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Yes please make sure you have all the nuts/bolts loosened, even if you have a service manual look around.
    I ruined a shadow 500 crank cause there was an extra bolt the Clymer manual didn't show me when splitting the cases.
    Let me tell you, I was pissed! Never trust those manuals 100%
  6. bigfitz52
    It should pop off without excessive force; you probably do have a bolt in place still.
  7. Nighthawk
    Nighthawk Member
    Huber Heights, Ohio
    Just had mine off last weekend first time it was ever off with 22k on engine and 1 pop with rubber maller and it liffed off. Sounds like something not taken off.
